Question about Medion MED-1511 PC Desktop
Mmc reader does not work, no led lite, worked ok then quit. do i get a driver somewhere and install it?
  • 64 Answers
There may be more to this story....
when it worked ok what size stick were you reading?
are you trying to read a different size now?
it may not be HD compatible if you are.
Posted on May 16, 2010
I cant open my sd/mmc card reader and writer.
Some SD and MMC have a security feature in them. If so you will need the disk that came along with it. After you install it then that's the time you can fully utilize your SD/MMC. SD means Secure Data / MMC means Multi Media Card.
If your card reader is not appearing in the My Computer then check if it is detected in the Windows device manager. Go to START > CONTROL PANEL > DEVICE MANAGER. Usually it is under the category of Disk Adapters or Human Interface Device. If it's not present then unplug and plug the device back in. Or try a different USB port to see if that will work. If it doesn't then most likely the reader is defective. But if it is detected and still not able to read the SD/MMC and the SD is being read by a different computer then the issue could be that the SD is not compatible with the reader.
Jun 08, 2011 | Computers & Internet
Sd.ms/pro.mmc.xd
Well if the inbuilt card reader does not recognize the SD/MMC card then we need to perform certain troubleshooting steps which are as follows:
1>click on start
2>In start search box type DEVMGMT.MSC
3>As soon as the device manager window opens up locate an option which reads as UNIVERSAL SERIAL BUS CONTROLLERS
4>There would be a + sign next to the same, click on it and then try locate a driver which reads as REALTEK SD CARD READER driver or JMB38X MS SD SD/MMC xD Card Reader Driver.
5>Right click on that driver and then click on uninstall
6>Locate a tab which reads as ACTIONS at the top, click on it and then click on then click on SCAN for HARDWARE CHANGES.
7>try installing this driver:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=ob-73184-1&lc=en&dlc=en&cc=us&product=3818852&os=2093&lang=en
or
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=ob-79371-1&jumpid=reg_R1002_USEN
Restart the computer and then check
Hope this works.
REGARDS
KEN
Mar 19, 2010 | Compaq Computers & Internet
The buit in sd/mmc card is not able to read on dell inspiron 1525
Try to do system restore,
If that doesn't work download the latest driver for that built in card reader then install it,. if it still doesn't work run the hardware diagnostics of the computer then if it passes without any error you'll need to do operating system reinstallation so that means erasing everything in the computer,.. If that doesn't solve your problem get that card reader replaced.
Hope this helps!
Feb 08, 2010 | Dell Inspiron 1525 Notebook
Sd ms/pro mmc sx card reader does not work
Hello, you are quite correct a driver is required for it, go to www.hewlettpackard.com and search for support/downloads you'll get all the required drivers there. If not try www.cnet.com
Good luck! and a very Merry Christmas to you.
Paul 'W'
Onyer~EDson(:0)~[><
Dec 14, 2008 | Computers & Internet
Sd mmc corrupted after formating also it show mmc corrupted so how to reprogramme sd mmc file system or how can it will be repair
bro... i'm warren from philippines... try my solution... insert you mmc to your reader and connect it to your personal computer (USB).. if your computer is having a problem to open that removable drive its ok.. don't worry about that i have solution with that later... then if your computer is having a problem detecting your removable drive be sure that you reader is working correctly.. if your reader is working maybe your mmc is broken...things you do.. REPLACE IT..!!! lets go back in other solution, if your computer is having a problem to open that removable drive (it means your memory detects by your computer) try LOW LEVEL FORMAT YOUR MEMORY CARD..install a low level format to your computer then format that mmc, then insert to your cellphone and format it to FAT..
here's the link for low level format tool...
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
i hope this solves your problem..
e-mail me at squeeker_2314@yahoo.com.ph if theres anything.. ^_^
i post this solution to another problem here in fixya..because his problem ad your problem has the same solution..
Oct 28, 2008 | Nokia 6680 Handheld
N70 mmc corrupted and can't be formated
in ur phone go to Tools ,memory,options and Format memory card.....
It will work......!!!!!!
Oct 01, 2008 | Nokia N70 Cellular Phone
good day
try replaceing it with a new mmc from a reliable brand. be sure not to scratch the contact points of your mmc card
MMC card support in compaq
Well basically what you do is
1.) connect your memory card reader
2.) install the necessary drivers
3.) insert the memory card and it should show up as a removable disk in my computer similar to that of a pen)flash) drive
If the card reader is built into the computer then simply ensure the necessary drivers are installed (right click computer and select properties, then click device manager , it will show up in the list, if it has a yellow maker then it has a problem if its a question mark then it aint installed) if you dont have the drivers get them from the manufactures web page. IF everything checks out ok then put in the memory card and it will show up as a removable disk in my computer..
If you dont have a memory card reader or dont have the card reader built in then you will need to purchase one.
Jun 29, 2008 | HP Compaq Presario V6000T Notebook
Query to remove write protection from the MMC card
I have a Nokia 6230 and recently each time I put my MMC card in my card reader for my computer it says : "Cannot copy "X file" The disc is write-protected
Remove the write protection or use another disk
I already tried formating the card and even putting tape on the card like I read somewhere but it doesnt work and I dont have the cables or installation software, any help will be appreciated.
Apr 06, 2008 | Kingston flash memory card - 256 MB -...
Medion MED-1511 PC Desktop Logo
44 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
