Question about Lexmark JetPrinter X1185 All-In-One InkJet
Adding printer X1185
Trying to add the lexmark X1185 on my comp found all lexmark but the X1185 help
disconnected and reconnected usb powered off the printer and restarted the pc
  • 1 more comment
  • dotskie Apr 04, 2008
    i cannot install this printer cause i dont have any drive for this
  • fowlgame Apr 28, 2008
    Can I download a driver for my used X1185. My computer indicate that the printer is connected, but I have no driver in my computer list. Is it possible to get a free driver on my computer?
  • babygirl88 May 11, 2010
    my printer works but i cant get my icon so that i can open my soultion center so i can scan things
    Guru:
  • 1,463 Answers
Drivers for the lexmark 1185 all in one printer can be found from here Windows Vista --
riz.
Posted on Apr 25, 2008
Adding my printer back on my computer without the disk
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Jan 04, 2012 | Lexmark Z600 InkJet Printer
My laptop cannnot locate my lexmark x1100 series t
Make sure the Lexmark X1100 Printer Driver is installed on your computer.
If the printer driver was already installed and working with your computer, please follow steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
Aug 30, 2011 | Lexmark JetPrinter X1185 All-In-One InkJet
My lexmark 2600 is ON and rdy but my comp doesnt see it after making a USB connection so i cant use it to scan and print
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
4. Reboot your pc.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/aNGYmW. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 30, 2011 | Lexmark X2600 InkJet Printer
Hello. i am trying to get my lexmark x1185 printer to print, after replacing both cartridges/
Normal 0 This sometimes happens after changing ink cartridges, or
Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 01, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
I have a lexmark x1185 all in one printer and when I open the top to replace the cartridges they do not move to the center??? Any help???
First of all, I would suggest you to disconnect the power supply from the back of the printer and reconnect it after 60 secs. Once you are done with this, try turning on the printer. If the carts doesn't come to the middle, then there should be something wrong with the printer hardware. Do you see any lights flashing on the printer? If you are hearing a slamming noise when powering on the printer, that is an indication that the encoder strip (the strip which holds the cartridge in position) is off! This needs to be fixed by a hardware specialist. Incase if the printer is under warranty, you could ask for a repalcement.
Merry Christmas!
Dec 18, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Printer not working
Through Add/Remove programs, uninstall all Lexmark items.
Next, make sure that the printer is deleted (Control Panel-Printers)
Disconnect the USB cable from the PC.
Reboot.
Insert the Lexmark CD, If yo uhave the correct OS drivers on the disk,and let it run. When it tells you to, connect the USB cable form the printer to the pc. __________________
Nov 20, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
We have the lexmark x1100 series and it will not print or scan. we disconnected the usb cord from both ends, restarted the comp. and reconnected the usb. still nothing. Then we tried to uninstall the...
Go to start>run. Type msconfig. Click on the Services Tab. Look for lexbce server in the list. Check it if it's not started or uncheck it if it is.
Go to control panel>printers and faxes. Double-click the lexmark printer icon and check if there are documents in queue. if there are jobs waiting to be done. right click each and delete them. Wait until they are clear. If it doesnt clear out even after a long time, restart the computer. Try to print afterwards.
If this doesn't work, try adding the printer again. Go to control panel>printers and faxes. Click on 'add a printer' on the left pane. Make sure 'Automatically Detect and Install my Plug and Play Printer' is checked. It should detect the printer is it is connected and turned on. Otherwise, try connecting it to another usb port or to another computer. If possible try using another usb cable or installing a known good printer to the computer to check if the cable or printer is bad.
Oct 03, 2008 | Computers & Internet
Go to www.lexmark.com Go to the drivers and download toolbar, then drivers and download a driver,,and type in your product name. The drivers are there. I just checked. All OS seem to be there.
You will simply need to download the driver from the Lexmark site.
Its pretty straight forward.
Feb 22, 2008 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark Z645 Printer
i have a problem of Lexmark Z645 Printer i want a software of this .
Feb 09, 2008 | Lexmark Z645 InkJet Photo Printer
Lexmark JetPrinter X1185 All-In-One InkJet Logo
75 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
