Question about Nikon D80 Digital Camera with 18-135mm Lens
I have a Nikon D80. Whilst at Yosemite National Park a few weeks ago, where it was extremely cold I noticed that my camera would not take photo. After a few tries, it started working fine again. However, yesterday the shutter started sticking, and the ERR message showed on the screen. Then I can take one photo, and same thing happens again. Is there something I can do with settings, or do you think there may be something wrong with the camera body? I took to a camera shop and they say the lens is OK, and that problem is with the body? I look forward to hearing from you. Many thanks, Ros
    Brigadier General:
  • 4,090 Answers
Changes in temperature should not affect it unless its about 15 below or at above 55-60C Then there is some delay in taking the picture due to shrinkage in metal part causing lt to be sluggish or in heat to expand the metal and cause some slight jamming. Is it possible the body has been dropped or bumped? By you or some other user? Take off the lens and check that the shutter responds quickly when pressing the button. check it is set to say 1000/sec then at 500 and finally at 2secs, It should be a lot slower at 2 sec than at the other two settings. If there is very little difference then I would suspect an electronic component or a faulty battery level or the whole battery. If it all seems to work OK with the lens off Place the lens back on and do the exercise again. If it fails then the fault IS in the lens mechanism. Thanks for using FIXYA
Posted on May 16, 2010
Camera constantly takes blurred pictures
Appears that the auto focus mechanism is not working, This anomaly is most obvious in lower light situations when focusing is much more critical.
If the camera was new and two months old I would either return it for another one or have Nikon repair the lens assembly under the terms of its warranty.
Aug 30, 2017 | Nikon Coolpix S4300 16.0-Megapixel Digital...
I now have a Nikon D80. I have a National Flashgun Model PE300SWG Can you advise me if this 'gun is safe to use with the D80?Nikon tell me that as long as the trigger flash voltage is o--250volts it is...
A flash trigger voltage in the 250V range is fine for most film cameras, but not for most digital cameras. The PE-300 has a trigger voltage in the 33V range, which I (and most others) would consider much too high for the D80.
BTW, "National" is a brand name used by Panasonic.
Oct 21, 2011 | Panasonic Cameras
My D80 suddenly stopped taking photos while I was in Auto mode. I noticed the flash stopped releasing. I've changed lenses, reset the camera's green buttons, switched out the card, reset the clock. It...
Hi, Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
May 13, 2010 | Nikon D80 Digital Camera with 18-135mm...
FEE error code on nikon d80
To solve this all you need to do is turn the lens' aperture ring (the one nearest the camera body) to the smallest number (probably 22 or 32).
Jun 21, 2009 | Nikon D80 Digital Camera with 28-80mm Lens
I have a Nikon D80. I used fine the night before, took the battery out to charge it, and the next morning...NOTHING. No power, no lights,no picture, no sound...Notheing. I checked the camera wit another...
Surprising. I can only think that the camera may have caught some condensation if you took it out from a cold place to a warm place (e.g. indoors). You can try to dry it out by putting it 24 hours in a dry box then try again. Also, make sure you are using Nikon batteries when testing it out. Generic batteries are known to die out suddenly after only a few months of use.. and especially if they are subjected to extreme cold
NOTE: Please rate our help to keep this free service online
Jun 05, 2009 | Nikon D80 Digital Camera with 18-200mm...
On playback screen of my nikon d80..
When viewing the images you've shot, spin the sub-command knob (front right of camera) to change the photo information you will see. There are a few modes so keep spinning the knob until you find the viewing mode you prefer.
Apr 26, 2009 | Nikon D80 Digital Camera with 18-135mm...
My camera will not take multiple shots
Ok, what you need to do is look at the top of your camera, around that smaller LCD screen. On the right side of the screen, you will see a button with three boxes stacked on top of each other.
You need to press that button until it displays the same icon in the TOP RIGHT corner of the smaller LCD screen right next to the button you are pressing.
That button switches the camera from Single shot mode to Multiple shot mode ( as well as a few other modes).
Jan 18, 2009 | Nikon D80 Digital Camera with 18-135mm...
Red, white, horizontal and vertical lines showing up in some of my prints
Send it in for a quote. It should cost the equivalent of $10 USD, more or less, wherever you are. No expert, however talented, can bring a broken sensor back to original shape.
Mar 26, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 - Continuous shooting
I will need more info on the settings you are using. It might be that the camera is in a specific mode which is not allowing you to take continuos shots.
Mar 22, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon D80 Digital Camera with 18-135mm Lens Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
