Question about Acer Aspire 3000 Notebook
Stuck in loop
Working on laptop-removing spyware. it went into a sort of hibernate state, and will not come back out. I have tried hard crashing it, and when I remove all power, then plug it back in, (leaving batt. out) it turns on automatically, but nothing comes on then screen.
  • mcgeheejer Mar 31, 2008
    tried. monitor not problem. removed cmos batt. tried jumper reset. nothing is pulling it out. each time, when I add some sort of power, it turns on automatically, and just runs. pulled HDD to see if it was the prob, but booted fine on my dell.
Your drive is split in 2 in half just hit acer key thats one them 4 keys up buy the switch just under it will set computer back just like new with out haveing to do a disk reformat you will lose your saves stuff tho its easy fast thats why hey split the drive
Posted on Apr 08, 2008
  • 1,006 Answers
Try with EXTERNAL monitor...Remove MAIN BATTERY RAM AND CMOS BATTERY then see if it works!
Posted on Mar 30, 2008
Hibernation partition
Make sure you have the HDD in the same state as it was on Hibernating. If it was removed after Hibernation, it will not be 'seen' by the PC. Everything that was connected during Hibernation MUST be connected again when starting the machine so the O/S can follow the route.
Nov 22, 2013 | Western Digital Computers & Internet
Acer 5733z-4633 is stuck in a sort of boot loop. Won't enter bois setup or boot device options screen. Is this a hard drive issue?(it kinda makes a funny clicking noise then starts all over to try
Yes! it does sound like the hard drive is bad, remove hardware to see if you can enter bios and boot device, if yes the hard drive needs to be replaced, if no change there is a secondary problem.
Jun 11, 2012 | Acer Computers & Internet
I have a seond Aspire 5742Z laptop which has been working perfectly fine until just now. I switched it off and went to log back on. The power button and the power indicator have lit up but seems to be...
Sometimes these laptops get stuck in a loop. Try removing the battery and the AC power cord. With these still removed, open the lid, and hold down the power button for 30 seconds.
Replace the battery, and plug it back in to the mains, and press the power button again. Hopefully this will clear the issue.
Jul 23, 2011 | Acer Aspire 5742Z-4200 Notebook
My laptop battery/preparing to hibernate
remove the battery and adapter. press power button for 30 sec. then connect the adapter. press power button. if this didnt work. you need to ask for an help of a local tech to check for the video card and cable.
if it boots up to your operating system
control panel---->power options--->change plan setting--->
Turn off the display-never
Put the computer to sleep-never
control panel---->power options--->change plan setting--->advanced power setting
-set hard disk "turn off hard disk after" to never
-set Sleep "Sleep after" to never
-set hybrid sleep setting to off
-set hibernate after setting to never
Restart pc
Mar 07, 2010 | Samsung NC10-14ROBL Notebook
I was trying to install a webroot spyware application to my acer aspire 3000. once it asked for product code and i typed it in, my pc went into hibernation and I cant get it to turn back on. please advise....
Hibernation usually happens when the battery goes flat. It may have nothing to do with the software. Please ensure the laptop is well connected and the battery is charging. And then try to turn it on again. If I'm wrong and the application you purchased is actually a malware in disguise, then I'd suggest you try to boot with a recovery CD and then uninstall the application. Unless there is physical disc damage that the malware caused it should be able to turn on. Hope it all goes well. If my ideas help you, please do rate me. Thanks
Feb 05, 2010 | Acer Aspire 3000 Notebook
My laptop has went into hibernation and shows a small moon and that the battery is in use. I took out the battery and it still shows it in use. It won't come out of hibernation and won't go back to...
The moon means Sleep or standby mode, if the laptop attempted to enter hibernation and sleep mode at the same time it could just be stuck in a hibernation loop and unable to load.
To test this, remove the battery and AC adapter, then hold your power button down for thirty seconds. Once you've done this replace the battery and power cord then try turning it on.
Let me know how you make out and if it doesn't work provide any other details you can including anything that comes on the screen and any beep codes you hear as it fires up.
Thanks and good luck,
Chris
Aug 10, 2009 | IBM ThinkPad T20 2647 Notebook
Auto hibernated, will not power back up
It's possible that the laptop is stuck thinking it should be resuming from standby but cannot find the data in memory. Remove the battery, unplug the power cord, and hold down the power button for at least 10 seconds. Then plug JUST the power cord back in and try to boot the system. If you still get no response then it's possible that one of your RAM sticks is going bad. With the battery and power cord removed try removing both sticks of RAM. Then try to boot the system again with only the power cord in use and no RAM installed. See if you get some sort of response from the BIOS. Hold down the power button to turn the computer off again, remove the power cord, and then try booting the system with just one of the memory sticks installed. If you can isolate one of the sticks as causing the failed boot, then that stick is most likely faulty.
May 13, 2008 | Acer Aspire 3000 Notebook
Can't get it out of Hibernation...
my toshiba laptop went into sleep hibernation mode,& all i could get was the cursor on screen but nothing else, omg could not get it out of this mode for about 5-10 minutes,so i held the on/off button down for 10 seconds until it definately switched off,then was able to be reboot the laptop,but took some time doing this......
Oct 30, 2007 | Toshiba Tecra 8100 Notebook
Acer Aspire 3000 Notebook Logo
62 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
