Question about Proform Sport 1000 Folding Treadmill PFTL91205 - !
The treadmill is loose. How can this be fixed?
    President:
  • Proform Master
  • 832 Answers
If the problem is in the drive belt, either the drive belt will stop when stalled or the front roller will stop when stalled. Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud, then find the motor mounts. Many motors in Icon treadmills have a main pivot joint in which a bolt runs the full length of the motor mount. This bolt will require loosening to provide maximum adjustability.
If your treadmill is not equipped with a bolt as described above, the drive belt must be tensioned by hand. While one person applied increased tension to the drive belt, the other person should tighten the motor set bolt Tighten the bolt and test. If the problem is not corrected, repeat steps above and retest.
If the motor, drive belt, and front roller continue to turn when the walking belt is stalled, the problem is with the walking belt slipping on the front roller. Follow this procedure:
First remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn both rear roller adjustment bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each side of the walking belt 3 to 4 inches off the walking platform. Be careful to keep the walking belt centered. Plug in the power cord, insert the key and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened. Rear Roller Adjustment Bolts
If the drive belt continues to turn but the front roller stalls, you may have a broken front roller pulley and front roller must be replaced.
Follow this procedure: First remove the key and UNPLUG THE POWER CORD. remove motor shroud. Loosen the rear roller and remove the two adjustment bolts. Some models have a spring loaded tensioner on the right hand side so be careful when removing these bolts. After the bolts have been removed, remove the rear roller end cap(s). The rear roller should now simply slide out of the walking belt.
Remove the motor hood. Using a black permanent marker, make a mark on the front roller adjustment bolt on the motor compartment side at exactly where it fits flush with the roller so you will know where to retighten it later. The adjustment bolt is on the right hand side of the front roller. Then remove the bolt with a 7/16” wrench. then remove front roller and replace with new reverse procedure mentioned above
Posted on May 16, 2010
I have a gold gym vx 5000, the motor does not keep a consistent speed and jerks a lot, is there any way to fix this?
You have to check the treadmill belt. is it properly tightened or not. If the belt is loose the this type of problem can occur. check the video and tighten the belt and the check is it jerking of not .
Almost all the treadmill have the same belt tension procedure.
Treadmill Running Belt Tensioning
www.electro-medical.blogspot.com
Sep 21, 2015 | Exercise & Fitness
How to fix "The equipment is blocked (com)" error on technogym treadmill's display?
Equipment is blocked can be a number of things.
Not sure what MOSFET is.
First, and usually the most popular thing is the electronics.
Other usual things to look at:
-the emergency stop can be malfunctioning. Does it move or is it fixed still? That's something I just had to repair on a treadmill recently.
-A cable could be loose. Try taking a Cat 5 cable from the lower kit directly up to the display and see if that does anything. This isn't a common issue, but worth a shot.
May 20, 2014 | True Technogym Excite Run 700 Treadmill
Squeaky Nordictrack C1900
see the video attached. lube the rollers bearing front+back . Test the drive belt motor for to loose or faulty belt, and fix it.
However if the problem persist, TIME to replace the old board deck.
God bless you
Oct 20, 2013 | Nordic Track Nordictrack C 1900 Treadmill...
LifeFitness F3 treadmill loses power to console board when pressure is applied in/on buttons
Now RUN THE SOFTWARE CALIBRATION for diagnostics,
troubleshooting, and fix it.
However adjust and fix it the REED switch, clean it, and tightvery well
the plug or connector see the diagrama attached.
God bless you
Sep 24, 2012 | Exercise & Fitness
Where can i find replacement wires for treadmill
go please to www.treadmillpartszone.com or www.fitnessrepairparts.com
God bless you
Jul 02, 2012 | New Balance Balance 1500 Treadmill
Turns on and then shuts off before it will start even after hitting reset
Dear Sir:
This problem is frequently.
1) Check the breaker from your home and reset.
2)Inspect the wires from your outlet in the wall and tight it.
3)Do not use any extension cord!
4)Examine the power cord and see if some wires is loose and tight it.
5)Test the ground from your outlet wall, and fix it.
6)Reset the c. breaker internal from the treadmill.
7) Inspect any wires loose and tight it.
8)Lubricates the treadmill between deck vs walk belt, this can cause to shut down the treadmill, since the complex electronic is designed for to protect the electronic components.
9) Lubricate the treadmill in according with your manual instructions.
10) The ball bearing from motor can be faulty+ball bearing from roller deck.
11) The main motor board can be faulty. ( this is last step)
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Feb 15, 2012 | Epic 425 Mx Treadmill EPTL88105 !
Wires under to 495cw treadmill can a loose
Dear Sir:
I thing was situation out of control.
Answer.
1) Do you now what wires cables are?
2)Where did you get loose?
3)Upper or lower wires?
4) There is a connectors or simple wires with colors?
please reply carefully for to Assist you.
Last questions: Would you please tell me exactly what is your model, mark,serial number of your Fitness Treadmill?. That will help us.
Do not worry. Take control, and will fix it.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA.
Nov 25, 2011 | Proform 495cw Treadmill Walking Belt
The resistance belt on my nordictrack 1300 woulnt tighten. How do I fix it? Thanks for you assistance.
When using the NordicTrack in manualmode, you can adjust its resistance by twisting a resistance knob, locatedeither in the corner of the console or on the upright support. If the treadmillbelt slips from side to side, you need to adjust its tension via bolts locatedin the back of the machine frame. First find the treadmill adjustmentbolts in the rear end of the treadmill frame, to either side of the belt. Now putin an Allen wrench into each bolt, one at a time, and turn each bolt aquarter-turn clockwise. Slip one hand among the belt and the treadmill deck. Ifthis doesn't pull the treadmill belt taut, it's still too loose. Tighten thebolts another quarter-turn. Continue testing the belt tension, then adjustingthe bolts as needed, until the belt is just loose enough for you to slip yourhand between it and the deck with no extra slack. Step onto the treadmill andwalk. The belt shouldn't bind or slip side to side. If it does, dismount andre-adjust the bolts until the belt tracks correctly. AV
Jun 11, 2011 | Exercise & Fitness
Hey we moved my treadclimber tc5000 and now it won't power on. Cord is plugged in and outlet is good
there could be several reasons why but i think that you have bumped a wire loose somewhere else. look and see on the control board that wires havent come loose. also check the wires from the console down to the control board. i have fixed several treadmils from people complaining about this same problem.
Jan 28, 2011 | Bowflex Treadclimber
Proform Sport 1000 Folding Treadmill PFTL91205 - ! Logo
329 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
