Question about Sony DAV-C450 System
DVD Repair or replacement of Receiver
When we watch a DVD, the picture shows wavy lines sporadically.
Also when the DVD gets 1/2 thru, it stops/locks and restarts from the beginning.
Is it worth taking this to a repair shop or should I buy a new receiver?
Better question is...can I purchase the receiver by itself?
    Novelist:
    Champion:
  • 236 Answers
You can definitely have it repaired, probably need to replace the optical lense only. But something dat will be done by a tech expert
Posted on Mar 31, 2008
Samsung 50 HLN5065WX has wavy lines on analog input
this is an inherit problem of this set - - search 'wavy line' and you'll see many samsung sets have this - there is no cure ! use the set with component or hdmi good luck
Jul 16, 2010 | Samsung SP50L6HX 50" DLP HDTV
Mitsubishi rearTV has intermittent wavy lines running throughout
Do you have anything to test it in 1080i? Does it do it on all connections or just one? I had a similar problem with my TV that turned out to be a bad input board. Mine would only display 1080i through the Component connections. All others would show pink and green wavy lines. It cost me around 500 to fix it. Unplug the TV. Remove the back cover for the TV. Using a NON-metal object, or gloves, wiggle the input board (that has all the video connections on it) slowly back and forth and see if the problem comes and goes. You will have to have someone watching for you. If something is loose on that board, the problem should show itself. Narrowing down the problem will probably save you money on repair bills.
May 13, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Wavy lines and no stereo
this is a tv problem, needs to be chekout, normaly is TV HV circuit defective, and shows the some lines. go to repair shop to repair.
Nov 22, 2009 | RCA DRC8030N
DVD picture is crystal clear, but wavy lines when using cable. Connected a different tv to same cable and picture is fine. internal coby tv to cable connection must be bad?
you can get a standard RF (cable) male connector to AV (the yellow,white and red colored) adapter at radio shack for a few bucks...if it is a internal connection, that will bypass it...you will just be watching cable on AV-1 or wherever you plug it in
Aug 28, 2009 | Coby Televison & Video
Samsung HLN567W wavy lines
Check to see if your DVD player is outputing a progressive scan and turn it off if you are using the S-Video cable, it does not support progressive scanning.
Apr 18, 2009 | Samsung HLN567W 56" Rear Projection HDTV
WD62825 Mits DLP ~ Lines in picture
the DM board and the FMT board need to be repaired. it is not the 4 caps. it will cost about $250.00 plus shipping. go to
www.tv-techs.com
Nov 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wavy lines
Are the wavy lines horizontal or vertical? If they are horizontal and up near the top of the screen it could be 60HZ interference from a power cord running over the cable from the DVD player to the TV. There could also an internal breakdown of the shielding by the power supply of the DVD player. If the lines are vertical it is likely the cable or maybe the input jack on the TV. Could be a number of things.
Nov 09, 2008 | Sony DVP-S500D DVD Player
Wavy lines on photo's
Check if it is a dirty lens problem.
If lens are ok, then is either the camera optical sensor defective or a fault in camera main board.
You will need to take your camera to a computer shop or to send it in for repair.
You can call the number listed on the camera user manual to get repair service.
If camera is less than one year old, it may be covered by factory warranty, check warranty terms.
Sep 14, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Cannot record thru line 1
If you could but now you cannot then this is a circuit break down- although check your set up , but I feel it is the machine beginning to die
Jun 15, 2006 | Sony RDR-GX315 DVD Recorder
Sony DAV-C450 System Logo
106 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
