Question about Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC
EZCD 5.0 and EZCD 6.0
Yes. I´ve downloaded the updates but 5.0 did not work too. All other features of version 6.0 work, except the Creator Classic (the most important for me). I've just installed another burning software now, in order to assert that the CD/DVD-R/RW drive is well. It worked, but that's a simple and small shareware software called burnatonce.
If you have any other suggestion, aceppt please my thanks in advance!
Herminio Trujillo
Brazil
  • Herminio Trujillo
    Herminio Trujillo Mar 31, 2008
    Thanks for trying. I will check again everything to find out any conflict that may cause this fail in the 6.0 initialization. The version 5 is no longer installed. I have removed it thru Control Panel and then reinstalled the version 6 and updates. Will check the last time I burned a CD and will try to remember about any possible change made in the machine in the mean time. Soon or later the version 6 will work because it´s really very good, mostly with regard to the authoring of DVD´s. I also have the Adobe Première installed in this machine to edit videos and Roxio provides a professional finish.
    Thanks a lot!
    Herminio
    Novelist:
  • 141 Answers
I don't think that 6 and 5 are compatible 6 is an upgrade from 5. I have just 5 on one of my old XP computers and it works fine, but that's all I have. I went to the website and they are not giving any support for Roxio 6 anymore.
I will tell you that Roxio Easy Media Creator is fantastic. The things you can do with that are unbelieveable. I got it at Sam's Club for about $70. But I know that does not solve your problem.
Roxio 5
To burn data files, Open project selector, make a data cd, click data cd project. WhenEasy CD Creator 5 opens and you choose your files to burn, try this: Select Disc at Once Radio button, click okay and click burn.
ID Number: 000008GN Products: General Information
OS: Issue When burning a CD or DVD, you receive an error, burning does not complete, or your media is rejected. Resolution Burning errors can happen for a variety of reasons. Roxio has found that doing the following steps resolves about 80% of all burning issues. Please give all these steps a try and see if it fixes your writing problems.
  1. Update your drive's firmware/drivers. Most companies regularly update their firmware and drivers. If you are unsure what model your burner is and its firmware, click here to find out.
  2. Enable DMA. Direct Memory Access enables better efficiency of data. For more info, check how to enable DMA.
  3. The media. Check the following:
    • The disc is clean and unused.
    • The media is recommended by your burner's manufacturer or try a different brand, preferably a name brand, if you continue to have problems.
    • Make sure that media (-R/+R, -/+RW, dual-layer compatibility) is supported by the burner by checking burner's manual or manufacturer's website. This is especially true for some Blu-Ray burners which do not support CD-R/RW media.
  4. If your burner is external, make sure it is connected directly to the computer via USB/Firewire and not a hub or other other device like a sound card.
  5. Update to the latest PX Engine. The PX Engine improves compatibility with newer burners on the market.
  6. A reinstall of the burner's drivers may also help.
    • Windows XP: Go to My Computer and choose Properties.
    • Windows Vista: Go to Start --> Control Panel --> System and Maintenance --> Device Manager.
    • Click on the Hardware tab.
    • Select Device Manager
    • Expand DVD/CD-ROM Drives, then select your burner and uninstall it by right -licking on it.
    • Reboot.
Roxio 6
OrangefoodJSLib.events().registerNativeEvent("mousemove",document.getElementById("rating_img"),highlightRating); OrangefoodJSLib.events().registerNativeEvent("mouseout",document.getElementById("rating_img"),ratingExit); OrangefoodJSLib.events().registerNativeEvent("click",document.getElementById("rating_img"),ratingVote); Article Details ID Number: EE6000132 Products: Easy CD Creator 6.x Platinum Suite
OS: Windows 98 Second Edition
Windows ME
Windows 2000 Professional
Windows XP Home Edition
Windows XP Professional Edition
Issue Roxio does not recognize the blank CD/DVD media in the recorder drive.
Resolution Follow the listed procedure to ensure that the CD/DVD media you are using is supported by your CD/DVD Recorder.
On Easy CD and DVD Creator:
  1. Open Creator Classic.
    1. Launch Roxio Easy CD & DVD Creator 6.
    2. Click on the Creator Classic icon.
  2. Check the supported media types.
    1. Click on Tools on the top left hand corner of the window, then select Drive Properties.
    2. Under the Devices section, click on your CD/DVD Recorder drive.
    3. Under Supported Media, click on down arrow to see a list of supported media your CD/DVD Recorder supports.
    4. Ensure that media type that you are using is listed here. If it is not listed then your CD/DVD Recorder does not support that type of media.
On Easy Media Creator:
  1. Launch Disc Information.
    1. Launch Roxio Creator Home menu.
    2. Click on the Tools tab, then select Disc Information.
    1. Under Supported Media, ensure the media type is listed.
    • Reboot.
I do know if you have Roxio5 you cannot installed Nero 6 InCD, not compatible. Other than all of the above, I have no more suggestions. I am really sorry, wish I could work on your computer to figure out the problem. This is my specialty. Reloading computer and figuring out problems. It is so much easier hands on.
Good Luck
Posted on Mar 31, 2008
6ya staff
SOURCE:
I have an ipod classic 160 gig but keep gettin the error code 1439 wen i try to restore what should i do?
Hi, now, when you restored your 80 gB classic, did you upgrade the firmware to 1.1.2?
If so, do not.
I refuse as my firmware 1.1.1 works the ipod great and the only trouble started (twice) on trying to update the firmware.
Try a hard factory reset:support.apple.com/kb/HT1339
Then, charge fully with AC charger (this was recommended to me twice in an Apple store)
After wards, use USB to connect to your computer and do not allow it to upgrade to 1.1.2
(See incidental article about ipod touch: rupertgee.wordpress.com/2007/12/02/downgraderestore-ipod-touch-firmware-to-version-111-using-os-x/ this might even work on ipod classic - you've got nothing to loose); also have a look at Apple's updates: apple.com/support/downloads/
This seemed to work for me:
1. Download latest version of iTunes
2. disconnect from internet (I did this by removing my wireless adapter).
3. Put iPod into disk mode (hold select and play until display says "disk mode" at the top).
4. Connect iPod to computer
5. You should be prompted to restore, click yes.
6. Message will appear saying can't connect to internet, do you want to restore to latest version "2.0.1" instead? (Something along those lines).
7. It should start restoring and work this time.
Hope this helps.
Jan 10, 2011 | Apple iPod classic MP3 Player
In roxio 10 suite when I start the classic view for a data burn ..Roxio start trying to install the update manager. A total pain.
open your task manager find the process that is trying to update, remember the name, stop the process and then search for it in your c:\ directory and delete it maybe that will work
Oct 10, 2010 | Roxio Easy Media Creator 9 Suite (227100)...
Hi Name is Joe.
Resolution
Installing on a Windows Vista computer
Creator 2010 requires a minimum of Windows Vista Service Pack 1 for installation. You can either perform a Windows Update (recommended) or install Service Pack 1 for Vista here.
Installing on a Windows 7 computer
The issue might be caused by the Creator 2010 setup package running in Windows Vista compatibility mode on Windows 7. Please use the following steps to turn off Vista compatibility mode for the Creator 2010 setup package:
  1. Right-click on the setup package and choose Properties.
  2. Click on the Compatibility tab in the Properties window.
  3. In the Compatibility mode section, uncheck the box that is labeled Run the program in compatibility mode for Windows Vista.
  4. Click OK to save the changes.
  5. Re-run Creator 2010 the setup package.
May 04, 2010 | Roxio Creator 2010 Full Version for PC...
Getting a blank McAfee SecurityCenter window
Yes you do need to uninstall .Its beta and still buggy .Follow these instructions
1. Click the Start Button and select Control Panel.
2. Select Add or Remove Programs.
3. Find and select Windows Internet Explorer 8 from the list of available applications.
4. Click the Remove button.
5. Restart your system.
Removing IE8 on Windows Vista::
2. Select Programs (Programs and Features if you’re using the Classic View).
3. Select View installed updates (it will be under the Tasks column if you’re using the Classic View).
4. Find and select Windows Internet Explorer 8 from the list of available updates.
5. Click the Uninstall button at the top of the list.
6. Restart your system.
Nov 06, 2008 | Compaq Presario Notebook
I have just intalled Roxio creator 2009 but much of it will not open. To date I have found advice on Media Cretaot 5, 6, 9 and several other items but not Creator 2009. Can you help please?
are you sure is the full version of the program.. If some or most features are not avaliable (greyed out) you may have a demo version, a shareware version or most likely a system requirement has not been met some some features may not be avaliable to you.
did you check the system requirements before installing the app?
http://kb.roxio.com/content//kb/Creator/000199CR
for advise on how to use the app check out roxio's website or their user manual for roxio creator 2009>
http://kb.roxio.com/content//kb/Creator/000204CR
Sep 26, 2008 | Computers & Internet
Cannot Initialize API
1. Try to launch Creator Classic to see if it can repair the engine files. a. Double click on the "Roxio Easy Media Creator Home" icon. b. Click "Creator Classic" under the "Applications" section. c. The Windows installer should launch and ask you to insert your installation disc
Try this and see how it works, if it does not, contact me and give me more details
Mar 25, 2008 | Roxio Easy CD & DVD Creator 6...
Driver
Download and install adobe reader for manual, if needed
use Get Adobe Reader button on this page
http://www.adobe.com
Manual link (two choose based on directions)
http://www.bushnell.com/customer_service/manuals/binoculars.cfm
There may be no driver required for vista for the USB access to the camera.
However one of the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
This Vista support link may help
http://kb.roxio.com/content/kb/General%20Information/000004GN
This Update is PhotoSuite Version Specific, you will need to find the version of PhotoSuite installed on your system before selecting the update.
To find the version of PhotoSuite that you have installed first open PhotoSuite and then Go To "Help" and then to "About Roxio PhotoSuite", once the About box opens you will find the version at the bottom center.
If you have version 5.1.2529.0 or higher this update is not needed.
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1366.0 only.
Note: The latest Easy CD & DVD Creator Engine update should have already been installed.
(This update will take 5 to 20 minutes to install, there is no progress bar, so you should not interrupt it.)
Download
Updates the PhotoSuite components of Easy CD & DVD Creator 6 PhotoSuite version 5.0.1419.0 only.
Download
Update PhotoSuite 7 Platinum to 7.0.430.0 (English Only)
Important Note:
This updater is intended only for the stand alone version of Roxio PhotoSuite 7 Platinum. If your version of PhotoSuite 7 was included with Easy Media Creator 7 then please (use those listed above) for the correct updater.
Download
Dec 22, 2007 | Bushnell ImageView 11-8200 Binocular
Driver
Manual link (two but these appear to be the same)
However the manuals indicate Roxio may provide updates for photosuite. No assurances there are that either link to provided software is applicable to your version however generally updaters will not update the incorrect software. There is also no notation that these are or are not Vista Compatible.
Download
Download
Important Note:
Download
Dec 22, 2007 | Bushnell ImageView 11-8321 Binocular
Roxio Easy CD & DVD Creator 6 (cdrvlpe6101250) for PC Logo
238 people viewed this question
Top Roxio Computers & Internet Experts
Peter Dragonetti
Thomas F. Schneider
Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
