Question about Bosch 1 - 1/8" Reciprocating Saw RS5
Bosch reciprocating saw blade stuck in chuck
I have a bosch reciprocating saw and the blade is stuck in the chuck. The lever to release the chuck won't open. I tried WD40 to loosen it up, but no luck. Any ideas?
  • 35 Answers
SOURCE: blade stuck in the chuck
If you have the lock released and can't get it out try pointing it towards the ground and running it. the piece should fall out unles it is still locked in
Posted on Dec 01, 2008
SOURCE: dewalt recipr. saw keyless chuck tab used to
We had to send our saw to repair center to install new lever. Fortunately, still under warranty.
Posted on Aug 10, 2009
SRF518
  • 232 Answers
SOURCE: Where to get a replacement quick change blade
have you tried Sears?
Posted on Oct 20, 2009
jrox55
  • 66 Answers
SOURCE: The blade lever on my sawzall is stuck in the up position
oohh, that a tough one. you gotta, very carefully peal back the hand gaurd, the rubber where you hold onto it, at. Then releas the screws undeneath. Seems like you should be able to cycle the saw to its furthest out position, then remove the blade gaurd, uning some pliers of some sort you should be able to make the release, release.
Hope this helps
Posted on Mar 09, 2010
  • 94 Answers
SOURCE: Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Posted on Apr 21, 2010
How do i remove a broken blade in the bosch rs 325
Open the chuck and try gripping the bit of broken blade with some tweezers or flick it out with a small screwdriver.
Nov 30, 2012 | Bosch RS325 Compact Demolition...
How to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
The lever that releases the blade is no longer working. In other words the old blade is stuck and the lever doesn't release it any more. Any thoughts on a fix?
Sometimes plaster and drywall dust, or other abrasive materials cause these parts to stick... Try some WD40. I spray mine as routine maintenance! (You might have to let it soak for a few minutes the first time) Hope that helps!
Sep 24, 2011 | Dewalt DW304PK reciprocating saw kit with...
I have a Bosch RS20 recip saw. A blade broke off in the chuck and I can't get it out. What should I do to get it out of there? Thanks for your help. Dan
Getting a broken blade our of the sawzall chuck can be difficult and require some ingenuity and patience...
Sometimes there be enough blade left so that you can grab it with a needle nose pliers... othertimes it is flush and that makes it more difficult... holding the chuck in the release position and rapping the saw against a table or with a hammer can jiggle the piece out....of course you have the chuck pointed down while you do that...
Also moving the piece around a bit with a stiff wire and also soaking the chuck and blade with WD-40 helps also....
Usually it will take a combination of these things and some persistance to get the job done...
heatman101
Aug 17, 2010 | Bosch RS20 13 Amp Reciprocating Saw
How do i change the blade in a reciprocating saw?
heatman101
Aug 05, 2010 | Skil FactoryReconditioned 920501RT 85 amp...
Blade not releasing
heatman101
Jul 05, 2010 | Dewalt DC385B 18v. Cordless Bare...
Blade stuck in reciprocating saw
The pin is probably stuck in the blade. This happens from time to time after they get dirty. Take some WD-40 or some other type of penetrating oil and spray a little in the blade holder while working the release lever. It will probably free right up.
Apr 24, 2010 | Craftsman 8.0 amp Reciprocating Saw
Hope this helps
Mar 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
How do you unlock the quikrelease when it is stuck open on the bosch recripcating saw
when you look at the front of the quick release, you should see 2 arrows, the arrow on the right faces up, the arrow on the left faces down. that is the open position, now all you need to do is insert a blade and it will lock closed by itself. then just turn it back to release the blade.
Jan 22, 2010 | Bosch 1646B 18V Cordless Reciprocating Saw...
Bosch 1 - 1/8" Reciprocating Saw RS5 Logo
938 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
