Question about Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
If i put any cd/dvd the laptop gets stuck - Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner
    Genius:
  • 1,354 Answers
HI
you have problem with your opticle drivers replace your drive your problem with solve
Posted on May 16, 2010
It is stuck. I have tried putting a straightened paper clip. does not work. no light, no response. stuck, stuck, stuck
Shutdown the PC and try to insert straithtened paper clip in the small hole provided in front of the CD/DVD ROM drive.
Dec 04, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Toshiba laptop stuck
try to use the restore cd.. .. select boot from the cd/dvd and boot the repair features with the OS
look at the boot screen that initially shows up and get in the setup.... switch the cd/dvd to be the boot device that starts first...
run the cd/dvd installation normally until you find a repair feature.....
then follow the standard repair method
Sep 30, 2009 | Computers & Internet
DVD stuck, computer won't turn back on
If you look at the door of the CD/DVD tray/shelf, you should see a little hole. Stick a paper clip into the hole and it will pop out the CD/DVD tray/shelf and you can get your DVD back. I would call Gateway support to fix the rest of it. If it is still under warranty, they can send out a tech to fix it.
Sep 28, 2009 | Gateway MX8711 Notebook
I am using DELL Vostro 1510 Laptop.recently a dvd got stucked up inside the Drive .The thing is that the drive is not having manual Eject Button. At this time the system got hanged up,Even i tried clciking...
Mechanical you need to take the drive out and disassemble the casing. I seen one that the CD actully broke into millions of pieces. I was not there to experience the happening but was there to help save the drive.
Jul 27, 2009 | Dell Vostro 1510 Motherboard System Board...
CD STUCK IN THE THE DVDRW DRIVER
Is it that the cd drawer will not open? If so-go to my computer and rightclick on the cd drive and select eject.
Jun 11, 2009 | Dell INSPIRON 6000 CENTRINO...
Laptop Disk Drive want reject.
If you mean the CD or DVD drive,,,then you can take a paper clip and bend it straight,,then put the paper clip into the tiny hole in the front of the CD tray and gently push,,,this will open the tray enough for you to grip it by hand and pull it out the rest of the way.
Jan 19, 2009 | Sony (DW-D56A-10/20) (DWD56A1020) DVD...
Dell xps m1330 cd/dvd problem
there is a small hole on the CD door. use a small paper clip, and strighten out one end and inssert it into the hole and push. the door should open halfway. pull out the cd and push the door close. it wil not damage the CD, or the drive.
Oct 12, 2008 | Toshiba Satellite A135-S4527 Notebook
Dell XPS m1330 Loud CD/DVD Drive Problem
Good day,
try to look for a very tiny hole near the cover of your cd/dvdrom drive. if you locate this one, you can use a thin wire (straigthened paper clip will do) and push the wire through the hole until you fill some resistance. at this point, your cd/dvdrom drive cover should dislodge and you can eventually open it and get your stuck cd.
i hope this helps.
You did not under stand
If you are able to remove the cd drive form the laptop on top there are 3 very small screws remove those and then you can remove the stuck cd
Aug 03, 2008 | Toshiba Satellite A45-S150 Notebook
Acer (91.42R37.001) CD-RW/DVD-ROM (Combo) Burner Logo
60 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
