Question about Dell Inspiron 1501 Notebook
Bottom cover of laptop won't come off.
Hi. I was trying to remove the bottom cover of my Inspiron 1501. I removed all the screws, however something is holding it in the rear centre, just under the power button and in line with the VGA port. No more screws are visible.
  • 93 Answers
Hi
yes there is some locks under the screen u have to open car fully
go to folowing link it will help to how to remove kayboard
http://www.google.co.in/search?hl=en&rlz=1W1SKPB_en&q=dell+inspiron+1501+youtup+for+keyboard+&aq=f&aqi=&aql=&oq=&gs_rfai=
Posted on May 16, 2010
Testimonial: "now I know what the problem was. thanx!"
How to remove bottom cover on inspiron 1510
There is no such model as Inspiron 1510. If you are talking about Inspiron 1501 then click this ftp://ftp.dell.com/Manuals/all-products/esuprt_laptop/esuprt_inspiron_laptop/inspiron-1501_owner%27s%20manual_en-us.pdf link to get user manual for the system 1501. This contains the removal of bottom cover.Goto page 92 and check under Memory how to remove cover
Oct 08, 2013 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Power Button won't turn on ....
I would remove the hinge / power button cover again and make sure the little pip that presses the button down it not broken, also check the little circuit board with the switch on to make sure it's not disconnected.
Try switching on with the cover removed.
Feb 02, 2012 | Dell Inspiron 1501 Laptop
I need to change a keyboard on an dell inpiron 1501, but not sure how?
Using a flathead screw driver, pry up the hinge cover(plastic above keyboard) to remove it. Remove the two screws securing the keyboard to the chassis. lift and pull the keyboard to lcd from the chassis. Rotate the keyboard cable lock, and then remove the keyboard.
Dec 31, 2009 | Dell Inspiron 1501 Notebook
Spacebar not working on dell inspiron 1501 laptop
ensure no liquid has spilled on it.
remove keyboard (should be perhaps a screw on the bottom to undo, as well as clips around the keyboard on top, slightly hidden... search for "how to remove keyboard" on your model) -be very careful as the cable connecting the KB to computer can be fragile. Now try removing and then re-connecting the cable.
Probably none of this will fix it (if the KB wasn't wet and then dried now, by a miracle ;) and you will be able to find a very good price for a used, or new, KB online! ..for the time-being, use an external KB.
Aug 31, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron screen coming off at hinges
It's a common problem with Dell Inspiron 1501 / 6000 / 6400 models. So tighten all screws on the bottom, on the back (where power cable connects), then remove cover on top of the keyboard and tighten screws there, then remove screen bezel and tighten screws there - here is how:
http://support.euro.dell.com/support/edocs/systems/ins6000/en/sm/display0.htm#wp1020174
then put everything back.
Aug 05, 2009 | Dell Inspiron 6000 Notebook
How do I put my new dvd rewritable driver in my dell laptop 1501
All of the below is from your Inspiron 1501 Manual, which if you do not have a copy, you can obtain
a PDF document Here
You will find all below under Adding and Replacing Parts--Optical Drive
Optical Drive
CAUTION: Before you begin any of the procedures in this section, follow the safety instructions in the
ProductInformation Guide.
Turn the computer off.
Turn the computer over and remove the optical-drive locking screw.
Insert a scribe into the notch and push it to the side to release the drive from the bay.
Slide the drive out of the bay.
Apr 10, 2009 | Dell Inspiron 1501 Laptop
Only have half screen on my Dell Inspiron 1501
What your describing is a failure of the LCD or possibly the inverter cable connection to the LCD. Most likely an LCD replacement will be required.
LCDs run around $150 on Ebay
Jan 25, 2009 | Dell Inspiron 1501 Notebook
Computer Shuts Down Randomly
is the fan running.... check how hot it is on the bottom.... could very likely be thermal shut down... if it gets to hot it shuts down before there is any damage.... see if you can remove the shield around the fan and clean out the dust and dirt and in my case cat hair. if you can't figure out how to get the cover off let me know... i should be able to find the service manual for you
Robert
Dec 19, 2008 | Dell Inspiron 1501 Notebook
Cd rom not working
Try reseating the CD drive. Remove the battery and make sure the AC adaptor is not connected. Turn the laptop over and locate the locking screw. It will have a little "Pad Lock" symbol next to the screw. Once phillips screw is removed, pry the securing screw tab to push the drive from the chassis with a screwdriver. Re-insert the CD drive and fasten the screw back into the bottom of the laptop.
If you still have an issue with the CD drive, please feel free to contact me for futher diagnosis.
Your responses are intended to improve the level of service provided. Please rate this solution.
Thank You.
Oct 17, 2008 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
113 people viewed this question
Alun Cox
