Question about RCA F26645 TV
Instant on/warm up feature doesn't work hence tv
Instant on/warm up feature doesn't work hence tv is dead. Is there a tube that is causing the problem?
TV is at least 20 years old sold with Sears name
  • RCA Master
  • 8,457 Answers
The tv still have picture?No,time to recyle the tv.20 years old electronics devices are impossible to get parts for or not worth the money to fix.
Posted on May 16, 2010
Lancia delat hpe was running fine,suddenly it stopped.tried to start it for hours using a booster.nothing...no sparks from plug or coil.the car was left to cool down for 2 hours.and then it started...
hi thats a common problem i would replace the crankshaft sensor first there bad for working when cold then breakdown when hot hence the reason no spark when warm
Nov 23, 2013 | 1995 Lancia Delta HPE
My Pioneer Plasma PDP-503PU HD went out. It made a broken glass sound
Dear bob_bitt,
I am very sorry to say this but,looks like your TV is dead for ever.
Plasma TV's have a glass tube inside them that fires the pictures onto the screen. The tube in your TV must have reached its EoL (End of Life) and hence,would have shattered.(That should explain the shattering glass)
Before you throw out your TV though,try to get it checked by a professional technician. But if you bought your TV around 10 years ago,you will be better off buying a new TV.
Oct 19, 2012 | Televison & Video
Possible water damage to the picture tube/ window was open when it was raining and possible wet the picture tube, television was off but still warm, when we cut the tv back on the picture begain to...
Any pop or loud noises sound when tv turn back on possible have water damages into it circuits boards components.No.Tries take the tv aparts leave it closed by to the portable heater unit turn it on high like 1-2 hours.Might get the tv work again,if tv have no components parts damages or dead.
Jul 26, 2011 | Televison & Video
We own a 50 projection tv and when turned on the picture fades in and out then after a bit is fine. this happens everytime we turn it on what is the prob;em and how can it be fixed if at all
Hello
The symptoms you describe are not uncommon in old sets. The loss of high voltage can be from a leakable path around the picture tube caused by dust and dirt; it can be caused by a weak flyback transformer that gives out after a long warm up; it can be from an overheated output transistor in the horizontal output stage; and others.
The fact that is occasionally comes back on would tend to indicate the problem may be from too much dust and dirt around the picture tube; hence somewhat dependent on humidity and environmental factors.
But, it really requires a hands-on analysis by someone who can take a look inside the set to determine the exact cause but if you wish to get inside the tv yourself don't do it without careful instructions as the high voltage can stay around for hours after the set is turned off
Jun 09, 2011 | Televison & Video
What can i do if tv's lamp no good?
This T.V. doesn't use a lamp. If you're referring to the picture tube, there is no fixing this other than making slim adjustments on the knobs on the flyback. Don't tweak it too much or it will cause retrace lines. However, in most cases a bad picture tube means its time for a new T.V.
Jun 07, 2011 | Sony KV-32FS12 32" TV
I have an older Sharp TV. The color of the screen all of a sudden has darkened some. Is there a way on the tv to lighten the screen? Thank you!
This problem can result from the aging of various components within your set, in general with older TVs, particularly sets of 15 years or older for example tend to suffer from capacitors that degrade - effectively reducing the maximum level of picture illumination available. Another issue for old sets that have been used extensively is that of the picture tube's electron gun aging, over time the gun produces fewer electrons to fire at the phosphor coating hence causing less "glow" - this can be sometimes improved by adjustments to the tube. All in all the set may require a decent service to ***** what aged components need replacing. Some later TVs do have a trimpot on the flyback transformer to allow the tube's brightness to be increased, but most older sets lacked this feature. SHARP did have this feature on many of it's 90s TVs but it needs to be adjusted with care by suitable techs due to the dangerous voltages present.
Hope this info is of some help, Regards.
Aug 01, 2010 | Sharp 32C-240 32" TV
I was wondering if about the flash feature.
Hi Amber,
Yes, you would need film. The film pack contains the battery that powers the camera.
For reference, see:
http://www.polaroid.com/media/document/one600jobpro_ug.pdf
Thanks for using Fixya.
Feb 25, 2010 | Polaroid One600 Pro Instant Camera
Sony KP-53V35 - red tube issues
In my computer the red tube is working properly. all pictures are not playing continuesly
Jun 19, 2008 | Sony KP-53V35 53" Rear Projection...
Toshiba television
If the glass picture tube is cracked it is not repairable. In some cases it would be possible that the tv would still work if it has a cracked glass but it would not be advisable to use it as it could allow x-ray radiation to escape. The tube is a vacuum and a cracked tube would lose it's vacuum (**** air inside) and cause it to instantly burn out when turned on. Sorry :(
Mar 11, 2008 | Toshiba CF36G40 36" TV
Picture bigger than screen
This can be caused not enough high voltage going to the picture tube. If the picture seems to get larger and smaller depending on the brightness of the scene on the screen that is probably what it is. IF that is the problem, there isn't much a normal consumer can do.
Nov 08, 2007 | Samsung TXF2899 28" TV
Televison & Video Logo
56 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
