Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Our 42inch panasonic plasma tv screen is peeling?? any reasons why
zjut
  • 106 Answers
SOURCE: LG 42INCH PLASMA TV BLANK SCREEN
Open the back cover and check the fuses on Y Sus Board and X Sus Board. If you can find a blown fuse, just replace that board and your problem will be fixed.
Posted on Feb 23, 2008
SOURCE: hyundai 42inch plasma tv
have got 2 or3 1inch thick black lines running top to bottom of screen how do i get rid of the black line
Posted on Jan 23, 2007
SOURCE: plasma tv screen has green pixelating into pictures
NO. Return for exchange. Green and Red Dots are Common with Akai/Viore. Google Viore 42 plasma and read. Same Company = Same TV = Same Problems
Posted on Mar 19, 2008
snakehead
  • 1074 Answers
SOURCE: Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Posted on Jul 25, 2008
SOURCE: Panasonic Plasma T.V.
It can if you leave the picture paused for extended periods.
Posted on Aug 06, 2008
Need a remote control for a gva 42inch plasma TV. Have tied to remotes all ready none worked.
http://www.ebay.co.uk/sch/i.html?_odkw=remote+control+for+a+gva+42inch+plasma+TV&_from=R40&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.TRS0&_nkw=remote+control+for++gva+42inch+plasma+TV&_sacat=0ub5kip
May 06, 2015 | Televison & Video
Need remote codes for panasonic 42inch plasma tv
you can go to http://www.discount-merchant.com/ and we sale remote controls of your brand that you're looking
Said
Dec 18, 2009 | Panasonic Televison & Video
Green vertical line on videocon 42inch plasma tv
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Jul 27, 2009 | LG 60PS60 60 in. Plasma HDTV
Orion 42inch plasma screen tv problem
most likely a bad Plasma Display Panel. Costs more than a new TV
Jul 22, 2009 | Televison & Video
New 42inch plasma turned off while watching, can't turn on
Panasonic requires an authorization number first from them. Our parts suppliers require that before we can even order the part. I recommend calling a svc co. to have it looked at, preferably an authorized panasonic service center, it will be much faster.
May 31, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Hi all i have a samsung 42inch plasma and i have sound , no pic ?
Your info doesn't indicate if you have a good onscreen display or not. If you do the problem is highly likely to be on the IO board on the rear patch panel of the tv. Replace this board and it should take care of the problem.
If you don't have a good on screen display the two common problems are either on the power supply module or the digital control module. Samsung is known to have problems on both these modules and an electronics technician should be able to remove these modules to inspect for cracked solder joints, or out of tolerance electrolytic filters.
If these conditions do not exist on either board then the power supply board should be replaced first before replacing the digital control board. Search for a vendor that will offer you a full refund will a small restocking fee if the board does not take care of the problem.
Apr 28, 2009 | Televison & Video
Coating film on screen has a 'hole' after cleaning
Not panic!
I'm reading it and i did it again, to give you the advise. the plasma screen is glass that's sure, then:
The actual problem is really simple. because i remember my last jobs with plasma and this is actually a film protector the manufacture use when the part is not installed yet in the actual tv set.
  • Your husband is right. (but the plastic is like one or two inches inside the frame and is hold it by the frame and the screws attaching the display.
  • if the tv is under manufacture's warranty have them clean their mistake. call them and make them peel it off for you.
  • but if there is not any waranty on it. then the solution is as you can figure it out . Have some one who can actually take all parts apart and finally peel off this film and put anything back together as is now. to let the tv cristal clear at the front.
Apr 14, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Want to buy remote cantrol
OK go to www.sears.com parts dept///Have make and model ready....
This should fix ya right up!
Dec 12, 2008 | Panasonic Televison & Video
Panasonic plasma
Uh oh, a grid scan problem.. Call in the shop, but bring your wallet in case it's the display...accordianman
Feb 26, 2008 | Televison & Video
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
