Question about Philips 42PF9630A 42 in. Plasma Television
Static while on, logic board led flashing, normal startup no pic
Picture went out a few days ago and now it still turns on fine with no error lights. there is just some sparse colored snow on the screen like random pixels firing. LED2011 is blinking on the logic board. All other LED's are steadily lit. Suggestions?
  • Seth Alison
    Seth Alison Jun 05, 2010
    I got the TV for free. It was the previous owner who said that the picture recently went out on it. I have not hooked it up to a video source. Nothing really happens on the screen, but when you push the menu button, there are flickering specs of rgb randomly across the screen. More than before you hit the menu button. what board would cause the problem? I am mostly wondering if the flashing green LED on the main logic board is normal or points to the problem.
    thanks!
  • Seth Alison
    Thank you very much for the very informative answer! Take care!
  • Philips Master
  • 12,061 Answers
Http://www.retrevo.com/support/Philips-42PF9630A/37-TVs-manual/id/278bh337/t/2/
Above is your user manual, below that is a pay for link for your service manual. https://www.completeservicemanuals.com/philips/magnavox/plasma-television/cat_89.html Below is a link for a FREE services manual http://www.scribd.com/doc/21281939/PHILIPS-BJ2-4UPA-BJ2-5UPA Below, is a thread, discussing this tv and some issues, perhaps this will be of assistance. I have included these manuals so you can get to grips with it all, anbd if you intend to try to repair yourself, not really recommended, then at least you have the most important tool, the service and repair manual. You see, with just this symptom, it is nearly impossible to tell what the exact "Cause" of this symptom is. The LED's do not tell us what, exactly what is wrong, sometimes it may indicate the "Area", just say in your case, it indicates the X board. BUT thats NOT where the "Fault is" thats just the part that is affected. We MUST find the damage, and repair, and, also the cause of the damage, usually never one in the same. These days unlike the "Old" analogue days it just isn't realistically possible to fix anything but the most basic of problems with todays sophisticated units. This is quite apart from the Safety aspect, any unit that can cause a firs or have an explosion, or both, is NOT to be treated lightly, and and the repairer, of the unit is legally responsible, another thing to think about. Also, one must have tools, a Multimeter, a soldering iron, a deslodering iron, an oscilloscope, a signal tracer, tools, and most important of all, a Service Manual, without which, there is no way to even begin to understand and fix it, and more importantly Program it, AFTER it has been fixed. As these days a TV, is a PC, a Tuner, and an HDTV Monitor, and more, all in one. in the "old" days TV"s were more, rudimentary, and built to last for 20 years, and a "Parts" supply was set aside. They usually used to fail for only a few reasons, and they while still difficult, were less difficult to repair. Electrical knowledge was transferable, and they could be and would respond to, This-is-the-symptom-This-us-the-Fix, But that no longer applies, as now, it can be a Fault on I squared Bus, or "Sensor" failure, or it simple may have "Crashed" just like a PC, It could be a Diode go bad, and that will stop the whole thing. You see, in the day, the sets were Very "Fault Tolerant" because they were Analouge, and a faulty, component, or more sometimes, the set would always diplay something usually, and when they didn't it was one of only a few things, sure there are always the horrid ones, and there are pleanty of those, but all in all it was quite easy. But with Digital Electronics, it either goes, or it doesnt, there are usualy few half measures. I mean thats the definition of logic either going or not. So it can take very little to completely paralyse a set, and generally give the only sysmptom, it can, by not working, usually No picture, or the like. So you, see the list is endless almost for any given SYMPTOM, as that is what is being seen, not the cause, as I keep going on about. Also any fault, usually involves the Power Supply, it is either the cause, the cause of the damage, or it is damaged. or ALL of them. Then after you have done the electronic repairs, you then must program the set to work, and align, and set up in general, any one of those settings missed or done wrong, back to square one.
So, it is nearly always my professional opinion that one should always get a "Quote" form the manufacturers recommended service center, Philips ion your case, please contact a local or head office, and ask for a referral to an Authorised Service Center. Now, I cannot stress how important that last point is. It is even worth the cost of shipping. you see an authorised service agent, they will have trained staff, trained on their (Your) brand, also they have first hand access to parts, original parts, too. . This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Below is a forum that you may find helpful.
http://www.avforums.com/forums/plasma-tvs/400763-philips-plasma-repair-advice-thread-13.html
Posted on Jun 05, 2010
  • 10,865 Answers
Hello. You most likely have a loose or bad solder joint. Take your set into a repair shop for the least expensive fix. J.
  • Seth Alison
    Thanks for the response. I want to avoid the repair shop and fix it myself. What board would be at fault that I could look at more closely? I am great at repairing and soldering, but this is my first Plasma project. What is the significance of the flashing green LED on the logic board? How do you test to see if one of the other boards simply need replacing (buffers, signal, X/Y/Z sustain, etc...)
    thanks!
Samsung UN40FH6030 won't start, no picture, logo screensaver is only picture received
logo is the startup screen like dos old pc's. would say there is a problem with the control system for the startup usually a memory fault. turn off at wall and leave off for a few hours to dis charge then try again it can be a fault in the logic board. dust and static can play a big part in the problem the parts are so small the dust and a little damp cause the problem. somtimes a good clean out of the board can fix this.
Jan 30, 2014 | Televison & Video
Samsung PS-42Q96HD
Please check whether the inverter is working and giving voltage to the display board. If not, this might require attention of a qualified service technician.
Jul 12, 2012 | Televison & Video
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
My toshiba 42" REGZA 42RV535U
U have sound but no picture?Picture does flashes a few sec?Yes,than those 2 long LCD inverter boards are dead.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 long LCD inverter boards for the replacement.
Jan 13, 2011 | Televison & Video
My Samsung SPN-4235 had the picture go out several months ago. When the power button is pushed, it just flashed on and off. It wouldn't power on for 6-7 weeks, came back on for a few days, then started to...
The flashing led is on the logic board and it indicates communication from the main bd to the logic bd via the lvds cable --your problem would best be analyzed by verifying the va - vs - ve - vset -and vsc voltages - then if all are good it could possibly be the y-main or the x main bds
Feb 06, 2010 | Samsung SPN4235 42 in. Plasma HDTV
LG DU-42PX12X Plasma, picture startes flashing then goes black after a few minutes
You need to get this tv service asap.i beleive that the problem is in the inverter board or yb board.
good luck
caypianan@yahoo.com
Oct 25, 2008 | LG 42PX5D 42 in. Plasma HDTV
TV does not turn on/red led flashes 7 times in front
this is common issue with this model and through your troubleshooting is tied to y main board. blinking led on logic main in normal operation. when replacing y main always good idea to replace y upper and lowe buffer boards as they complete a circuit and sometimes replacing one without other could cause additional failure on remaining boards
Aug 10, 2008 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips Problem
Philips 42PFP5332D/37 power problem.
The set blue light comes on, then then standby light comes on and flashes. no picture, no sound and no help from philips. Anyone knows the cause and possible solution? Help
Jul 23, 2008 | Philips 42PFP5332D 42 in. Plasma...
Flash problem
Same here. Any flash picture comes out nearly bleached out. Started from one picture being fine to the next being white. I'm very frustrated because I love this camera. I have a Digi Rebel and prefer my Fuji 5000! Anyone have any ideas?
Dec 17, 2007 | Fuji FinePix S5000 Digital Camera
Philips 42PF9630A 42 in. Plasma Television Logo
344 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
