Question about Refrigerators
Can I order a replacement door gasket for my Sub Zero 532 and fix it myself or do I need a technician? Where can I find DYI instructions to replace the door gasket?
SOURCE: Sub zero 532 ice maker
When my repair tech came out, he showed me that the fill tube sometimes retracts toward the rear of the freezer. He simply pulled it forward with a pair of needle nose pliers until it rested in the delivery reservoir. This placement allows the detector to know when the tray is full and shut off; thus not overfilling the freezing tray and/or splashing additional water onto the freezer wall and into the ice cube drawer.
Posted on Jun 30, 2008
  • 12 Answers
SOURCE: Sub-Zero 532 (About 18 years old)
First do the simple things like cleaning the condensor coils and turning the defrost timer a few times, also check the evaporator motor or just listen to the fan by opening the freezer door. Also check the light switch, make sure it turns the light off every time you close the door.
Posted on Aug 05, 2008
SOURCE: light switch does not work
1. Check to see if the bulb has blown.
2. Check the plunger switch is making contact. ( the light must be on when the
door is open meaning that the plunger is sticking outward. the light should go
off when you press the plunger in)
Posted on Feb 02, 2009
SOURCE: Removing Door Panels on Sub Zero 532
Hi, there is a metal strip that runs down the middle of each door the entire lenth. It is held on with two magnets. Once you pull that strip of metal off, you will see five screws that hold the door handle on. Remove thos five screws and the entire handle comes free. Slide out the panel and replace the handle, screws and metal strip ion reverse order. Take your time removing the magnetic metal strip as it is a very soft metal and could possibly bend or kink up on you.
Hope this helps. I'm having some trouble locating any company that makes stainless stell to match the appliances. All of the metal companies say the appliance manufaturers have a propriety type of lock on the appliance metal finishes. I also have the 532 model.
Good Luck
Posted on Apr 27, 2009
Sea Breeze
  • 4655 Answers
SOURCE: 532 sub zero evaporation tray is filling up with a
This is only normal in an environment of high humidity. My question is the condenser fan blowing over the condensate pan and is the air hot enough to evaporate the water that is in the pan? Has covers been removed on the rear of the refrigerator that may cause a different flow of air. Are all covers in there correct place and not missing panels that could change the flow of air over the pan? Let me know, Thanks, Sea Breeze
Posted on Aug 26, 2009
Gasker
On this model I will give you both gasket numbers as you didn't specify which one you needed. Freezer door part number 7010574, Refer Door 7010584. I verified that these numbers will match your serial number as you left it for me. I hope this helps you, good luck
Sep 16, 2014 | Sub-Zero Refrigerators
The freezer just started icing up and the air seal seems minimal> could it be the gasket or switch? Sub Zero Model # 532
This is your defrost sytem that has gone out and this is a simple repair. Just contact us with your brand and model number and we will get the correct part out to you asap.
We also provide part removal/installation instructions for proper replacements.
We look forward to working with you.
Nov 04, 2009 | Refrigerators
Power requirement sub zero 532
115 volts on a 15 amp circuit
May 19, 2009 | Sub-Zero 632 / S
Good Luck
Mar 25, 2009 | Refrigerators
Specific dimensions of a side by side model 532
FINISHED ROUGH OPENING DIMENSIONS: WIDTH = 47 1/2" HEIGHT = 83 3/4"
DIMENSION OF 532: H=84" W=48" D=24" MINIMUM HEIGHT=82 7/8" DOOR SWING=29 1/4"
Mar 24, 2009 | Sub-Zero 690 Side by Side Refrigerator
Jun 26, 2008 | Sub-Zero 632 / S
Sub-zero 532 problem
you have a Freon Leak @ the Evaporator.. Ice ball on back wall.. left side....
Apr 15, 2008 | Sub-Zero 632 / S
Sub-zero door seal
THE TRUE IS .. replace a door seal is a little pain to replace. YOU HAVE TO INSTALL RIGHT. ( some model using silicon. if you are patient. and able to remove aroun 30 screws. do it. if not. better call a tech........good luck.............................. LEAVE A COMMENT IF IT WAS GOOD FOR YOU
Dec 06, 2007 | Sub-Zero 642
Nov 21, 2007 | Sub-Zero 632 / S
Refrigerators Logo
140 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
