Question about HP Mini 1101 Notebook PC
SCREEN DISPLAY INCORRECT SIZE FOR MINI 110 HP
  • MDDeff May 16, 2010
    Could you be more specific what are you trying to do with your HP Mini 110 Where do you see this error code? Can you see your desktop on the monitor? Thanks, Mike
    Sergeant:
  • 245 Answers
Adjust it with buttons on the side, of ur lcd,
Posted on May 16, 2010
Dropped my laptop now 1 half of my screen is white and the other half is fine
Hardware damage
1) Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port on the netbook.
The VGA port is on the Left Rear side.
This is an example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
Scroll down a little for the VGA Cable example.
NOTE* Color does Not matter. Usually it is Blue. Can be Black or White in color.
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
2) Turn the monitor on. If a CRT type of monitor allow it to warm up.
Turn the laptop on.
By factory default the display should show on the external monitor.
However there are at LEAST 3 display options available;
A) Internal monitor of laptop ONLY
B) Internal monitor of laptop AND external VGA monitor
C) External VGA monitor ONLY
Press, and hold down on the Fn key, (Bottom left corner of Keyboard), and at the SAME time tap once on the F4 key.
(The F4 key is the Display Toggle-Over key)
No display on external VGA monitor?
Hold the Fn key down again, and tap once more on the F4 key.
Display good on the external monitor? Fine. Your graphics chipset is good. Problem lays within the Display Assembly, (LCD screen, Display Cover, etc), or the Video Cable.
Also posted in case you do not repair the netbook, or repair is set for a later date. This way you can at least use the netbook at home.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Video Cable:
The video cable attaches to the motherboard, in the upper left area near the left Hinge.
It then leads under the left Hinge, and up into the Display Assembly.
(LCD screen/ Display Cover, Display Bezel, etc. is the Display Assembly)
From there it connects to the back of the LCD screen.
(The Mini 110-3135dx has LED backlighting, and does not use a screen Inverter )
Just due to normal opening, and closing of the laptop, the Display Panel Cable, (HP for Video Cable), can be pulled on.
This means the connection of the Display Panel Cable, at the motherboard side could have been pulled loose, or at the LCD screen side.
It can also damage the tiny wires inside the Display Panel Cable.
From your description, it sounds like the Display Assembly was open, when it landed.
Display Panel Cable connections should be PHYSICALLY, plugged in to ensure the connections are tight.
A visual examination will NOT do.
Connection on the motherboard side AND -> LCD screen side.
If there is visual signs of damage to the Display Panel cable's sheath, also suspect damage to the tiny wires inside the Display Panel Cable. (Stretched/Broken)
Check the connections first. You can leave the laptop partially disassembled, and check, before putting it back together.
If physically checking, by trying to plug the two connections of the cable in, does no good, you have to suspect if the Display Panel Cable may be damaged.
A continuity check with a multimeter set to OHMs, and checking each wire in the cable, is the next step of the diagnosis.
You can take the cable down to the nearest 'Mom and Pop' computer store, and have the tech check it for a few dollars.
Or due to the price of a replacement you may just wish to replace, and see if that was the problem.
The HP part number is HP 607755-001.
HOWEVER, this is supposed to be for a kit that contains 3 cables.
1) LCD Cable (Display Panel Cable)
2) Webcam Cable
3) Power Cable.
[ Power Cable:
The DC Power Jack is the jack on the laptop, that you plug the AC adapter ( Charger ), into.
The DC Power Jack is NOT soldered to the motherboard, with this model.
Instead it is soldered to a cable of wires, and the wires end in a plug.
The plug is unplugged from the motherboard, and the entire assembly is replaced as a unit. (It's a Power Jack Harness, really)
DC Power Jacks get broken. This one will be easy to replace ]
http://www.aliexpress.com/store/product/LCD-video-Cable-for-HP-Mini-110-110-1000-110-1100-Laptop-LCD-Cable-6017B0207601-6017B0232102/908032_556440323.html
Check the part number on your Display Panel Cable, and see if it matches up to the one you are going to buy, is the best method however.
Display Panel Cable checks out OK, or you have replaced it, and it doesn't solve the problem, the problem is the LCD screen.
Again, in my searching of the LCD screen replacements, I found they all use LED lighting for your model. (Mini 110-3135dx)
LED backlighting as a rule now, does Not use a screen Inverter.
Could I be wrong, and your laptop does indeed have a screen Inverter?
Only you will know once you open the Display Assembly, and check the Display Panel Cable connection at the back of the LCD screen.
If a screen Inverter is used it will be in the Display Assembly.
A screen Inverter could easily have been damaged in a fall, and a bad screen Inverter COULD show the results you stated.
I say -> COULD.
I believe the Display Panel Cable connection may be loose at the motherboard side, and/or LCD screen side, or it may be damaged.
If not I believe the LCD screen is the problem.
To check the Display Panel Cable on the motherboard side, for this model, you have to remove the Top Cover. (HP for Palm Rest Cover)
This means the Static sensitive hardware components for the laptop, will be exposed.
This means you NEED to wear an ESD wrist strap, once the Top Cover is removed.
BEST method however is to just put it on BEFORE starting to disassemble. This way you do not forget, and have a Static shocked laptop, that is only going to be good enough for a DOORSTOP.
One example,
http://www.radioshack.com/product/index.jsp?productId=2103245
The alligator clip needs to be connected to a good ground source.
I connect to an unpainted surface, of the metal frame of an open, empty desktop computer case.
You can also set a large metal serving tray (Unpainted), on the table you're working on, and connect to it.
Or a large metal knickknack. (Unpainted)
Pictorial guide that may help. Allows you to see someone working on an HP Mini,
http://www.insidemylaptop.com/replace-keyboard-in-hp-mini-1033cl-notebook/
Service Manual from HP Support (Free),
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=4307901&
In the list click on -
HP Mini 110 and Compaq Mini CQ10 - Maintenance and Service Guide
[ Note*
On page 65 it shows the Wireless LAN cables.
Number 6 states,
"Disconnect the display panel cable from the motherboard"
It is actually referring to the Figure on the next page. Page 66.
And Number 1 ]
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 23, 2012 | HEWLETT-PACKARD HP Mini-Notebook...
Washed out colors and slow problem hp mini 110
MS Fixit site may help. Use IE and filter answers with display. It will download an executable as part the whole Fixit program. Let us know how it worked out.
http://support.microsoft.com/fixit/
Oct 05, 2012 | HP Mini 110-1037NR Netbook
Program too large to fit screen hp mini 110 notebook
Change your screen resolution on the Display in the Control Panel.
Click Start/Control Panel and look for Display or Appearance and Personalization (depending on your operating system). When the Display opens increase the Screen Resolution. The resolution will be under the Settings Tab on the Display. The higher the resolution, the smaller the icons and things will be on the screen, therefore you'll see more.
Apr 19, 2012 | Computers & Internet
My HP mini 1000 is locked and I can't even get
Remove the cmos battery for 5 - 10 minutes. That will reset all data in the bios.
Jul 25, 2011 | HP Computers & Internet
How do I restore an HP Mini 110 Computer
To restore the original operating system and programs using the System Restore utility that is installedon the device, follow these steps:1. Turn on or restart the device, and then press the esc key repeatedly while the "F10 = BIOS SetupOptions" message is displayed in the lower-left corner of the screen.The "System Restore" page opens.2. Use the arrow keys to select System Restore, and then press enter.3. Follow the on-screen instructions to restore the system.
Doing this will wipe the hard drive.
Use the following link to download the service guide manual if needed.
http://h10032.www1.hp.com/ctg/Manual/c01895806.pdf
Dec 06, 2010 | HP Mini 110-1037NR Netbook
The screen on my hp mini 110 went white
A white LCD screen can be caused by (likeliness):
1. Loose connection between the video cable and the LCD screen.
2. Defective LCD screen.
3. Defective motherboard.
A local computer repair store should be able to fix this for you.
Jun 25, 2010 | HP Mini 110-1037NR Netbook
My HP mini 110 is doing a Startup Repair
Your operating system is corrupted - reinstall your operating system or take it to a HP service agent and get it reimaged
Jun 12, 2010 | HP Mini 1035NR Notebook
I can't change my wallpaper on my hp mini 110
You should select picture open with paintbrush resize save then from menu go to use as background option choose screen size and its done http://www.netalien.biz
Nov 02, 2009 | HP Pavilion dv5-1125nr Notebook
HP Mini 1101 Notebook PC Logo
66 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
