Question about GE Monogram ZISS480DRSS Stainless Steel
I have a GE monogram ZISS480DRSS side by side the condenser fan runs but the compressor does not.I checked for power from the inverter there was no power. There was power going to the inverter.At one point the comp.cycled up the stopper. the ohms of the comp. terminals are @ 7.0 what is going on I already replaced the inverter 2 years ago
  • 1314 Answers
SOURCE: GE Refrigerator Compressor Inop.
what the good doctor is saying is check for voltage where the wires come into the ptc reley thats a great idea
Posted on Jan 22, 2008
docjohn174
  • 943 Answers
SOURCE: GE Monogram side by side freezer and refrigerator
HI thanks for your question. the problem could have been, a defrost timer, stuck on defrost. or a failing thermostat. keep a close eye on it, if it stops again. get in touch and we fix the problem. thanks
Posted on Oct 15, 2008
SOURCE: GE GSS25WGMCC, Ice Forming On Freezer Interior Surfaces
i had the same problem and i replaced the defrost heater and it worked fine for about one month but now having the same issue. Most of the time from what I have heard it is the defrost heater (about $60 part). I might have another issue going on with mine like a defrost thermostat. Your defrost heater is right under the panel on the inside of the freezer section. remove white panel on back side of freezer section and remove two screws and two wires and replace it and you should be fine.
Posted on Apr 25, 2009
SOURCE: ge side by side not cooling
it could be two things your compressor is shot .check what date you bought it if less than one year you call the store you got it from or G.E but the store you got from sholud replace with a new one dont let them send a service tech out
Posted on May 29, 2009
SOURCE: Ge Monogram ZISS420DMAS compressor and fan not running
ICE CREAM WON'T FREEZE
The ice cream does not freeze, it stays soft. I have a GE Monogram 42" Built-in-Side-by-Side Refrigerator.
Posted on Jun 18, 2009
Ge monogram won't turn on?
Thank You for providing the model number so I was able to see what parts your refrigerator uses. Some models like yours have something called an inverter board, yours does not. Fans not working properly can also bring a heavy load on compressor causing the compressor to heat up and damaging the motherboard where you hear the clicking.The problem you are having is possibly related to the=> WR07X10074 Start Relay, e=>WR08X10052 Overload WR62X0080 Run Capacitor, and the=> WR55X11130 Main Control Board Here is another board sold at Appliance Parts Pro's=> WR55X11130 Main Control Board Assembly If you would like to do this yourself I will be glad to help answer the questions you have even assist you with installation questions. The problems you are having i typical for GE Refrigerators. If you have questions I am here. Thanks John Tripp Appliance 911
Contact me HERE
May 24, 2014 | GE Monogram ZISS480DRSS Stainless Steel
Temerature on freezer or fridge does not reset
You may have a defective inverter=> WR55X10504 Inverter
The Monogram is complex and expensive so if you would like my assistance I will be glad to help. First unplug refrigerator and examine the inverter for burns or swollen capacitors. Here is one after the plastic was cut away to expose the inverters circuit board, notice the tops of the capacitors are swollen? PHOTO HERE Service Manual HERE
I will be here should you need my assistance or comments, Thanks Sea Breeze
Other parts store=> WR55X10504 Inverter
Mar 04, 2013 | GE Monogram ZISS480DRSS Stainless Steel
Compressor is not running. I opened the cover and feel the compressor it is not running
Made a video of compressor replace on ge monogram. Maybe You don't need to change compressor, but just check how machinery compartment made. Location of components. I hope that was helpful.
Jul 26, 2011 | GE Monogram ZISS480DRSS Stainless Steel
Hi, I am hoping to find out what may have caused my frig. to go out. I have a GE Monogram ZISS480DRSS Stainless model. I woke up today to find a puddle under my freezer. The lights still work, but the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 29, 2010 | GE Monogram ZISS480DRSS Stainless Steel
Ice cube maker makes ice cubes ever once and a while, the condenser fan turns slowly. is this why it doesn't make ice cubes and the frezzer side is not cold enough? condenser fan going out? monogram...
Good day,
The ice maker speed of production is determined by the freezer temperature. If the freezer temperature is warmer than normal then the cycle thermostat in the ice maker will take longer to reset for the next harvest, causing low ice production.
More important, the condenser fan motor running too slowly can cause the compressor to run overheated and cause serious and expensive damage.
If in your opinion, it is running too slow, the issue should be addressed as soon as possible.
Aug 05, 2010 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS480DRSS - freezer and refrigerator both quit cooling. I had a mostly plugged condenser coil - cleaned it & still no cooling. What would be the likely component failure path to check?
replace the ptc overload relay on the compressor as this supplies power to the compressor,it may sound like the compressor is operating,but possibly only on the start windings and will be very warm to the touch,if so replace it soon so as not to burn out the compressor motor windings
May 19, 2010 | GE Monogram ZISS480DRSS Stainless Steel
The refrigerator is not cooling enough
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
346hf
Apr 06, 2010 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram side by side compressor runs loud - sounds like rapid knocking. what can i do?
check if it is the fan make that noise and not the compressor but if it is the compressor then you might need a new starter unit to the compressor
Jan 01, 2010 | GE Monogram Side by Side Refrigerator
Freezer is 0 degrees frige side only 40 degrees
that would be a valid check
but with this model i would look more twords you thermister in the refer, if its maintiaing a constant temp, but just outta temp, its more than likely you thermistor is going bad
Oct 14, 2009 | GE Monogram ZISS480DRSS Stainless Steel
Compressor of built-in monogram burning up. Should it be?
Don't know who to believe these days. When the compressor won't start and over heats the start relay,start capacitor and external overload may be the most likely reason. The door frames have heat strips that is normal. Sea Breeze
Jul 23, 2009 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZISS480DRSS Stainless Steel Logo
110 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
