Question about Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
Where do I put the lubricating oil? - Oster Golden A5 2-Speed Universal Motor Clipper 78005-140
  • 27 Answers
Between the cutting blades.
Posted on May 16, 2010
My coin opp washer and dryer keys are hard to turn to get the quarters out what am I doing wrong
One should never lubricate a lock with oil. Obtain some switch cleaner and use that the flush the oil out, then lubricate the locks with graphite powder.
Jan 19, 2015 | Washing Machines
What is the correct oil mixture for mac 130
If you are using McCulloh Custom Lubricant, mix 40 parts regular gasoline to 1 part Lubriocant (put 3.2 fluid ounce of Lubricant in 1 US gallon of regular gasoline).
If you are using SAE 40 weight two cycle oil, mix 20 parts regular gasoline to 1 part tow cycle oil (put 6.4 fluid ounce of two cycle oil in 1 US gallon of regular gasoline).
Oct 20, 2014 | Garden
What if I put to much oil in
If you put too much oil in, the crank shaft will pump it full of air and your oil pump (if you have one) can not pump the air filled oil. Result: no lubrication. If your engine uses the splash system, you will be splashing foam, not oil. result: poor lubrication. Recommendation: do not over fill. if it is over full now, drain some off.
Want to see what I am talking about? Put some milk into your blender and turn the blender on. After some period of time ... 30 seconds or more, drink the milk.
You didn't say anything about the make, year, model or mileage of your motorcycle, BTW.
Aug 26, 2013 | Motorcycles
How to take apart a signer 7430 model
You can remove screws bottom plate, however, unless you are mechanically inclined, I would take in for service. Lay machine back on soft cloth or old towel. Don't lose screws! Oil moving parts one drop good quality sewing machine only and use Singrr lubricant on gears. If you don't have oil or lubricant, you can blow hair dryer 1-2 minutes and put plate back on. Never oil or lubricate plastic parts! One drop oil on shuttle hook, Run scrap to distrubute oil before sewing on project fabric ! Jimmy
Apr 03, 2012 | Singer Sewing Machines
Lost operating and maintenance instructions. Need to know how much oil to put into the self lubricating chain reservoir and where it feeds the chain to make sure there isn't a blockage anywhere.
You are free to charge to the top if you think right to use a chainsaw. It is essential that the oil is clean. If you accidentally charge too much (full hopper) it is good the rest of oil put back in the oil bottle or to extend on the chain. It is important that it is not oil-free and should be cleaned around the chain for good lubrication.
Sep 05, 2011 | Garden
Product NR83A2. Lubricate is coming from the trigger and exhaust cover. The nailer is new and I put lubricate in the gun prior to placing the air plug on. What is the best way to drain the excess...
Excess oil will eventually be consumed /blown out of gun, however if you store the gun over-nite with air inlet pointed down, gravity will assist. I find that oil /water will accumulate inside gun especially if compressor is passing oil and/or weather conditions cause system to produce lots of water. Majority of guns that come in for repair suffer from a lack of lubrication. Several drops at start of day should be ok for oil lubricated compressors and maybe more for oil-less. If oil drips out of gun overnight (if stored as stated above) then reduce drops. What actually shortens life of gun is debris that enters gun from handling and that enters hoses during transport. Before connecting air hose to gun (with hose under pressure) momentarily connect a spare quick connect fitting and blow debris out of hose.
Mar 16, 2011 | Hitachi 3 - 1/4" Framing Strip Nailer
Older hunter original, needs lubrication. Where do I put the lubrication in? What kind of lubrication/oil? Used to buy fan oil, but no longer available, Fan has clicking noise and lubrication oil...
Howdy,
This is the owner's manual to your fan
http://www.hunterfanhq.com/tools/sales/hunter/preseason/images/owners/41121.pdf
As for oil, you can use one of two oils. Depending on how old your fan is, I suggest changing the oil by removing the fan, turning the motor completely over and letting it drain into the "dish" on the part that spins, clean the oil out of there, then re-hang the fan and oil with 1 oz of either Hunter Fan Oil (which is available from hunter, or on ebay, just search for Hunter Original Fan) or Zoom Spout Oiler, both are the same oil.
Thanks
Sep 23, 2010 | Hunter Dryers
How do i lubricant my treadmill
it is an indicator that the belt needs lubricating. turn the power off, and lift up one side of the belt and spray a small amount of lubricant underneath the belt, onto the running board. repeat this step on the other side. turn the treadmill on and run it for a few minutes to spread the lubricant. the oil light should now go off.
this should be repeated every 5-6 months to keep the board lubricated and to reduce friction between the belt and board and will lengthen the life of your treadmill.
Dec 19, 2009 | Reebok New York Giants Eli Manning Jersey
Ive put petrol in the oil tank
Just drain the oil, refill, and I think I'd run it to warm it up fully AFTER draining and refiling, and drain and refill again. You shouldn't drive it w/ gasoline in the oil, as it will thin out the oil and it won't lubricate as it should, and the extra half litre would be overfilled a bit, which would cause the oil to foam, which also would affect lubrication. countrycurt0
Sep 27, 2008 | 1996 Mitsubishi Eclipse
Oster Golden A5 2-Speed Universal Motor Clipper 78005-140 Logo
154 people viewed this question
Top Oster Health & Beauty Experts
Anglia Clipper...
shaveroutlet.com
shaveroutlet.com
Michael Vincent Cruz
Are you an Oster Health and Beauty Expert? Answer questions, earn points and help others
