Carosel doesnt turn on rowe ami r-82 jukebox
Carosel doesnt turn
    Scholar:
  • 195 Answers
The Rowe Ami R-82 jukebox is controlled by a number of electronic boards.
I would check the power supply in your jukebox it has four leds, these all need to be lit brightly.
The magazine motor voltage is 28 volts AC but is controlled by the mechanism control board 401-06905.
You need to send in the following boards for testing/repair:-
Memory Unit 301-07855
Mechanism Control Unit 401-06905
Selector Logic 601-08060
If your are in the USA I would contact Bruce Wentworth.
Here are his details:-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865 Tel: 603-382-6272 8:00AM to 6:00PM
www.abjukeboxrepair.com
In the UK or Europe then myself.
Alan Hood (ami-man)
Games Unlimited & Datex Systems
Units 4 & 5 Lion Park
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
alan-hood@datex.co.uk
Posted on May 19, 2010
  • 447 Answers
First check to make sure you are getting power to the drive system. If turntable is belt driven, check power to drive motor, then check the belt. Otherwise it is direct drive, which means the turntable is connected directly to ths motor and the motot will have to be replaced.
Posted on May 16, 2010
Selections already made on jukebox, how do I clear them
Hello stillwell42,
What model is your Rowe Ami jukebox, there will be an information label on the back or inside the jukebox with the serial number and the model type. We can suggest a solution once we know your model type.
Regards
Alan
Alan Hood
ami-man
UK
Mar 13, 2015 | Audio Players & Recorders
I have a Rowe R-89 jukebox. Even though the motor is turning on the turntable, the turntable is not moving. Should there be a washer on the turntable base to elevat it so it will turn?
Hello Robert,
You say you have a R-89 jukebox and the turntable motor is running, I assume that the pulley on the top of the motor is clearly seen turning. Is the turntable belt loose or missing?
From your message I am not sure that your jukebox is a R-89, could it be a 1978/1979 R-82 or R-83 that uses an idler wheel.
On this model the turntable motor is 110 volts AC.
If the above is true check that the idler wheel and the linkage spring is pulling the idler wheel against the turntable and the motor shaft.
Regards
Alan Hood
ami-man
UK
Aug 19, 2010 | Wurlitzer Jukebox CD Player
I have a 1979 rowe ami jukebox model R65 when i switch it on it plays one record then just spins the record magazine and wont select another record what parts do i need .
Hello Gary,
If your jukebox is ineed a 1979 model it would be a R-83 Fiesta, Claremont or Disco. These jukeboxes curved top to bottom.
I think your jukebox may be the 1981 R-85 Starwood, Starburst or Starlight.
If your jukebox is from the 1979 era upwards then it will be electronically controlled.
You need to send in your boards to a Rowe Ami specialist in the USA you would contact :-
Bruce Wentworth A&B Jukebox Repair 56 Old County Rd. Plaistow NH 03865. A&B Jukebox Repair specializes in the repair of Rowe circuit boards in Rowe ...
In the UK contact me
Alan Hood
ami-man
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Mar 01, 2010 | Vintage Jukebox External Speakers Shelf...
Rowe Ami R-80 imperial jukebox
Hello Andy,
Yes I know the 1976 Rowe Ami R-80 jukebox very well as well as most of the other Rowe Ami jukeboxes.
The turntable motor and the lighting work off of the 110 volt output from the power supply.
The other power voltages are connected to the power supply via the molex plug.
Pin 1 30VDC white/red
Pin 2 30VAC yellow/black
Pin 3 Common black
Pin 4 Ground gren/yellow
Pin 5 No connection
Pin 6 Common black
All the voltages are protected by circuit breakers.
I assume that you may be in the UK if this is the case here are my contact details.
Alan Hood (ami-man)
New Street
Halfway
Sheffield
S20 3GH
0114 247 0242 phone
0114 251 0727 fax
Jan 20, 2010 | Vintage Jukebox External Speakers Shelf...
How do I slow the speed of the 45s on my rowe r-92 jukebox .The records are playing a little too fast
The turntable motor on the jukebox range of R-84 to R-93 is none adjustable.
If you are in the USA then the motor operates on 60hz but in Europe it would have to be on 50hz to do this a different pulley is used.
The Rowe Ami part numbers are as followes:-
30791907 Turntable Motor Assembly 60hz
30791908 Turntable Motor Assembly 50hz
21817801 Motor Pulley 60hz
21817802 Motor Pulley 50hz
These can be ordered from a Rowe Ami dealer or you could try www.victoryglass.com
Regards
Alan Hood
ami-man
UK
Oct 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
Rowe Jukebox CD-100E. When I turn it on the
AT THIS TIME YOU ARE NOT SURE IF THE PROBLEM IS IN THE LASER ASSEMBLY, OR THE AMPLIFIER?
BORROW OR RENT, AN AMPLIFIER HOOK IT UP TO THE OUT PUT ON THE LASER OUT PUT ON THE LASER CD OUT PUT. LOOK AT LASER UNIT IT HAS A MARKING ON IT THAT SAYS AUDIO OUT PUT. PUT CABLE TO A SECOND AMPLIFIER.
THAT WAY IF IT STILL FADES. THEN THE CD LASER IS THE PROBLEM . IF THE SOUND IS GOOD THEN THE AMPLIFIER IS AT FAULT
DOCTOR FIX IT
Oct 23, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wont eject disc
Ouch!
1. power OFF
2. UNplug cord at wall
3. Turn ON jukebox (w/o power cord plugged in)
4. Turn OFF jukebox
5. Plug cord into SURGE PROCTOR (not wall, not simple power strip)
6.Turn ON jukebox.
7. If it doesn't work, try once more; otherwise ... *sigh* repair/replace..
Sep 01, 2009 | Audio Players & Recorders
I have rowe ami jukebox Eagle Laser Star and its amp seems to be dead sin have no sound justa a buzz. Need to find one or how to repair it.
CALL AB JUKEBOX SERVICE--ASK FOR BRUCE--TELL HIM LES FROM RMC VENDING SUGGESTED YOU CALL HIM.-
603-382-6272
Apr 27, 2009 | Wurlitzer Jukebox CD Player
My cd rowe ami jukebox is stuck in scan/transfer mode
You say you do not have the digital display lite up, have you checked all of the breakers on the power supply?
If not do so. Rowe Ami jukeboxes are very prone to dry joints (cold joints in the USA) this is cracking around the soldered pin on the connections to the boards.
If you can solder correctly then check out the printed circuit board on the power supply. I would retest and see if the display now lights after correcting a fault on the power supply.
If that has not made any difference then proceed to the Mechanism Control Board and the Central Control Computer (CCC) and check again for dry joints.
If you can not solder with any confidence then send in your boards to a Rowe Ami specialist for testing/repair.
Regards
Alan Hood
ami-man
UK
Mar 10, 2009 | Wurlitzer Jukebox CD Player
Song Programming
With regards to your problem with the Rowe Ami 100 cd jukebox.
Do you have a manual, if not I suggest you buy a printer manual or one on CD and refer to the Programming and Installation section.
In order for the jukebox to know about the cd's that are installed in the jukebox it has to initialize all or the changed cd's that have been replaced within the jukebox.
Put the jukebox into the Service Mode (the service mode should appear on the display)
Type 3 to select the Initialize sub menu
Type 0 and full initialize will appear on the display
Press Popular to start the initialization
Place the jukebox service switch into the normal mode
Initiazation will take around 30 minutes to complete.
Regards
Alan Hood
ami-man
Jan 05, 2009 | Wurlitzer Jukebox CD Player
624 people viewed this question
 Grubhead
Grubhead
