How do I go into safe mode on my windows 7 computer
I turn on my computer and I try to go into safe mode by pressing F8 and it does not work and it does not give me any other options,how do I fix this
    Habit-Forming:
  • 33 Answers
May be your windows Dll files was missing from the system ... but some of PC mdel F8 is nt buton to get safe mode list option, you try to pressing F5 or F6 or F7 or other ,.. some time in some Computer f* is decided to get boot menu or other function ...
This solution was prepared By Sami Jalal From Nehru Computer Center
Posted on May 16, 2010
HOW TO ENTER SAFE MODE
hold down F8 when it powers up. May need to remove battery and power cord. New windows 8 and probably windows 10 do not fully power down usually you have to hold shift key when shutting down windows from operating system. So it may not go into safe mode without it being shut down fully.
Nov 22, 2015 | Acer Computers & Internet
Start my pc on safemode
Windows 2000 and XP users Tip: If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
loading the last known good configuration.To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Choose Advanced Options for: Microsoft Windows Vista
Safe Mode
Enable Boot Logging
Enable low-resolution video (640x480)
Last Known Good Configuration (advanced)
Debugging Mode
Disable automatic restart on system failure
Disable Driver Signature Enforcement
Description: Start Windows with only the core drivers and services. Use
when you cannot boot after installing a new device or driver. Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally.
Aug 13, 2014 | Computers & Internet
How to get to safe modem?
To get into the Windows 2000 and XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use yourarrow keys to move to "Safe Mode" and press your Enter key.
Trouble Getting into Windows 2000 or Windows XP Safe mode- If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen
Jan 14, 2012 | Compaq Armada M700 Notebook
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
Microsoft Windows Vista and Windows 7 users
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Window 7 every 20 minutes hang
Many things could be causing this, the first thing I would do is boot into safe mode and see if the issue continues.
Safe Mode
Just before the Windows 7 splash screen (black with windows logo) appears, press the F8 key to enterAdvanced Boot Options.
You should now see the Advanced Boot Options screen. If not, you may have missed the short window of opportunity to press F8 in the previous step and Windows 7 is probably now continuing to boot normally assuming it's able to. If this is the case, just restart your computer and try pressing F8 again.
Here you are presented with three variations of Windows 7 Safe Mode you may enter:
  • Safe Mode - This is the default option and is usually the best choice. This mode will load only the absolute minimum processes necessary to start Windows 7.
Mar 15, 2011 | Toshiba Satellite L305D-S5935 15.4-Inch...
How to start in safe mode?
While the computer is initially booting up, press F8 (repeatedly if necessary), you should be presented with a selection screen to boot into safe mode (various levels such as with or without networking) or to boot normally. The F8 key only works while the computer is going through the BIOS startup procedure.
Jan 03, 2011 | HP Pavilion a1719n (RQ403AA#ABA) PC...
How do you put windows into safe mode?
Power on or Restart your computer, keep tapping F8 on the keyboard while it boots up. After few seconds, you'll be taken to the "Advanced Boot Options" with "Safe Mode" in the lists. Use the Up-Down arrow keys to highlight the "Safe Mode" and press enter on the keyboard to confirm the selected boot options. Black Screen with white texts will be displayed on the display, wait for few seconds until you see the windows logon Screen. You'll also see a confirmation message box asking you to confirm to boot into Safe Mode, click "yes" or "Ok" and proceed forward. There now you are in the Safe Mode.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 26, 2010 | Computers & Internet
I have a pc that has a virus. i cannot get into my control panel and it wont install programs. how do i repair this manually
First try to install MBAM (malware bytes anti-malware) in safe mode (press f8 while the computer is booting) Boot in Safe Mode with Networking.
If that doesn't work, the easiest way would be format the hard drive with the windows disc that came with the computer. That is the best way to ensure the problem is gone. All your information will be deleted, so you will want to copy things you need or want to an external hard drive or burn them to a CD.
http://lifehacker.com/157578/geek-to-live--how-to-format-your-hard-drive-and-install-windows-xp-from-scratch
Sep 23, 2010 | Computers & Internet
Blue screen of death. how can i ifix>? running windows 7 ultimate 64 bit
First try to start the computer in safe mode.
Restart the computer and repeatedly tap the F8 key (you need to press F8 before windows starts to load)
A menu should appear. Select Safe Mode and press Enter
Let me know if it able to start in safe mode
Mar 10, 2010 | MSI P55-CD53 (4719072129125) Motherboard
Mini notebook 7'' freezes on startup and says loading OS image
You will need to download one or the other
http://zeng.h1.28823.cn/VT8500Software.rar
http://zeng.h1.28823.cn/VT8505Software.rar
Please do as follows:
1.Extract files to your hard drive and only copy the script folder to a SD card, not the (VT8505 or VT8500 folder).
2. Turn off your netbook,
3. Insert the SD card to your netbook.
4. Turn on your netbook. Then the software will setup to your netbook Automatically.
5. After completed setup. It will show a windows screen calling for your to turn off the netbook.
6. Pull the SD card out off the netbook.
7. Then turn on the netbook and all should work fine
To God Be The Glory
Jan 10, 2010 | ASUS Eee PC 1000HE Netbook
Computers & Internet Logo
139 people viewed this question
David Payne
David Payne
