Question about Electric Intermatic T171 24 HOURS 40 AMPS 125 VAC 1 SINGLE ELECTRIC TIMER SWITCH
My Model S8711older 15 Amp timer has E10894
My Model S8711 older 15 Amp timer has E10894 stamped on the back. When I attach a lamp to it and am gone for a few days, the timer is hot to the touch when I return. Is this an indication that I'm about to have a failure with this device? It is normally attached to a lamp with a 60 watt bulb.
2 Suggested Answers
  • 760 Answers
SOURCE: I have an Intermatic Model
Go to www.intermatic.com Notice there is a recall for this model timer with codes 40z to 52z. Contact Intermatic for replacement. Here is link to the DT-17C probably same instructions.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt17c%20-%20english.ashx
Posted on Oct 04, 2010
Where is the model number on a vintage necchi sewing machine
Manufacturers put the numbers anywhere on the machine. Often, they can be found under the machine and may be a plate but often are numbers stamped into the metal. It may be on the metal base and could be hidden by the cabinet. However, if it is like some older Singers, there were no model numbers on the machines. The serial number actually signifies the model, ie N-6001-N-21000 is a Model 15.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&ved=0ahUKEwjohsLMlYXOAhWn6YMKHUcCC_kQFggwMAM&url=http%3A%2F%2Ffreenecchisewingmachinefiles.weebly.com%2Fuploads%2F1%2F8%2F7%2F3%2F18731174%2Fnecchi_model_list.pdf&usg=AFQjCNGMnPd8ffPJCeXrazqOj2oo-hsC7A&cad=rja
Vintage Sewing Machines
You could also take the machine to a sewing repair shop. Some of the older shop technicians are probably more familiar with these machines.
Jul 20, 2016 | Necchi Sewing Machines
How do I reset lamp time in Samsung DLP TV- Model HL-R6768W?
http://www.fixyourdlp.com/2007/02/15/resetting-your-samsung-dlp-lamp-hour-meter-counter-or-lamp-timer/
Try this link for details.
If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 23, 2014 | Televison & Video
How do i set my intermatic master control II model ed811
ED811 is older analog timer for turning table lamps on-off.
Copy following link for setting analog timers.
http://waterheatertimer.org/How-toset-timers.html
If dial does not rotate once each 24 hours, then timer motor has gone bad, replace with new analog timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TN
Add comment and say what you discover
Apr 26, 2013 | Intermatic Hardware & Accessories
I cannot put the two pieces of my received versadater stamp together and my stamp did not come with instructions....
I worked for a company that sold these stamps. Xstamper made some changes to this stamp & in doing so, the dater part would no longer attach to the received piece. Contact the company you purchased this from. Xstamper fixed our problem by going back to their older model so the two pieces would join together.
Mar 30, 2011 | Xstamper VersaDater Line Dater, Message...
How do I move the pins to change times for the time switch. It is an older model and currently at minus 40 C we want to keep vehicles heated longer overnight.They are silver, fan shaped but I cannot change...
I'm not sure exactly what timer you have.
You posted under Intermatic 'all weather timer' which is plug-in type timer with red and green pins.
1) If your timer is plug-in-type and trippers will not move, then just plug heater into the wall and don't use timer at all.
2) If you have Intermatic hard-wire timer that does not plug in, then trippers are attached to metal dial.
Remove trippers with pair of pliers. Don't use trippers and flip manual override lever to ON.
3) When it gets warmer and you have time to discuss, add a comment with timer model number and I'll look for the information.
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 17, 2011 | Intermatic All Weather Timer Grounded 15...
My model TN600CL lamp timer goes on fine and turns off at the times set but when it turns off at night in about 15 minutes or so it turns on again by itself. what gives?
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn600cl.ashx
If timer is older: The OFF tripper may be worn so it doesn't turn switch OFF completely ... and when tripper passes the switch, the switch pops out. Same thing happens with box-type electro-mechanical timers when tripper wears out.
Make sure trippers are pushed all the way in toward the center, and tripper is snapped on place.
If timer is new, and trippers are pushed all the way in, then timer sounds defective.
Nov 15, 2010 | Intermatic & Lighted Dial Timer
My fuse box cover has numbers to show what fuses go to what, I need a list of the numbers
1. 15 AMP Dome Lamps, Power mirrors (on 2 door models only), radio memory
2. 6 AMP front washer/ wiper
3. not used
4. 15 AMP stop lamps, 4 way flasher
5. 15 AMP back-up lamps, daytime running lights, rear defrost, turn lamps and turn indicator
6. 10 AMP speed control
7. 15 AMP instrument cluster warning lamps (explorer limited model #7 is 15 AMP heated outside mirrors)
8. 20 AMP horn
9. 10 AMP air conditioner switches, clutch coil
10. 15 AMP Park/ license plate lamps, trailer tow connection
11. 15 AMP radio
12. 20 AMP cigarette lighter, flash bright lights(from signal arm)
13. 10 AMP instrument panel illumination
14. 30 AMP power windows
15. 10 AMP ABS module
16. 20 AMP premium radio amplifier
17. 15 AMP rear washer/ wiper (explorer limited model #17 is 15 AMP warning gauges and lamps, 4 wheel drive)
18. 15 AMP heated exhaust gas oxygen
that's you list. hope it helps.
Aug 26, 2010 | 1992 Ford Explorer
Samsung projection tv
change lamp change fans
and replace color wheel.
make shure to remove jumper when replacing samsung color weel.
the jumper is black on the back panel of dmv modual.
jumper needs to be removed due to the new air cor motors thay are yousing, i had this same situation at one time.
Dec 16, 2008 | Samsung HLP6163W 61" Rear Projection...
Electric Intermatic T171 24 HOURS 40 AMPS 125 VAC 1 SINGLE ELECTRIC TIMER SWITCH Logo
170 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
Mike Carew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
