Question about Shop Vac 925-13 Canister Wet/Dry Vacuum
Change shop Vac Model LM500 from dry to wet pick
Change shop Vac Model LM500 how do I change from dry to wet pick up
  • 447 Answers
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
Do I take off the dry bag and the fome cover when picking up moisture ???
dont know what model you have, but, as a rule, the dry bag is for dry vacuuming and the foam is for wet vacuuming.
Feb 12, 2011 | Shop Vac Shop-Vac& Mini Hang Up Wet/Dry...
How do you purge the liquid from a shopvac
If you have picked up liquid with your shop vac , you then need to release the handles on the side and dump the liquid out of the tub. Do not worry about the top part, the ball will float up and shut off the air so no damage will occur.
Also change the filter and bag if you have either inside when the liquid is picked up.
Heatman101
Mar 14, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
How do I change my Shop Vac QPV 10.5 from a wet to
you need to go get some bags and srew on the nozel and then put the bag inside the vac it will then act like a dry vac.
Nov 04, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuuming up water with Shop Vac model 84M200
when picking up dry materials use the foam sleeve that slips on and the blue cloth (assuming there all blue) over it, there should be a ring that slides over blue cloth to hold it in place over the foam sleeve, for wet pick up u can use the foam sleeve minus the blue cloth but let it dry out before picking up dry stuff, you can pick up both wet and dry with a cartrige filter that looks simular to a car air filter and it slips over the foam sleeve, but let it dry out after picking up water before picking up dry cause itll just clog it up
Oct 25, 2009 | Shop Vac 84M200 Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
What if i use my wet dry vac to pick up water without a filter
DO NOT USE A FILTER WHEN PICKING UP WATER!!!!!
Im certain if you check the instruction manual it says to remove the filter.
Oct 13, 2009 | Shop Vac 925-13 Canister Wet/Dry Vacuum
I do not have my users manual and have never vacuumed wet with this vacuum. How do I change it from a dry to wet vacuum. Can't find my manual and I need to use the shop vac for water in basement, do I...
Vacuuming Liquids
1. When picking up small amounts of liquid
the filter may be left in place.
2. When picking up large amounts of liquid
we recommend that the filter be
removed. If the filter is not removed, it
will become saturated and misting
may appear in the exhaust.
3. After using the vac to pick up liquids,
the filter must be dried to reduce the
risk of possible mildew and damage to
the filter.
4. When the liquid in the drum reaches a
predetermined level, the float mechanism
will rise automatically to cut off
airflow. When this happens, turn off
the vac, unplug the power cord, and
empty the drum. You will know that the
float has risen because vac airflow
ceases and the motor noise will
become higher in pitch, due to
increased motor speed.
IMPORTANT: To reduce the risk of damage
to the vac do not run motor with float
in raised position
May 06, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Shopvac 2010
Just be sure to remove the paper filter bag that fits over the foam filter before vacuuming liquids. It's easy to get it wet and they don't work very well when that happens.
Dec 10, 2007 | Shop Vac 201-13 Wet/Dry Vacuum
Shop Vac 925-13 Canister Wet/Dry Vacuum Logo
892 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
