Question about Lightning Audio Amplifier, B3.200.2 Car Audio Amplifier
I hooked my amp up and it did not get any power the fuse is good and every thing is hooked up right but the protect light and the power light are not on
    Sergeant:
  • 163 Answers
Check ur ground poss bad ground area take test light to pos side of amp to see if u have power
Posted on May 16, 2010
No protect light or power light comes on w/my american legacy 800watt 2channel amp
is the blue trigger wire connected from cd player to amp? fuse? check earths connections also.. if its wired correctly the light should illuminate otherwise there may be a problem?
May 14, 2012 | Car Audio & Video
Wont turn on every thing is hooked up right pluged
A PLYE AMP IS NO GOOD AND ITS PROBABLY BLOWN SORRY FOR THE BAD NEWS
Feb 09, 2010 | Pyle PLA985R Car Audio Amplifier
No bass
could be the speaker its hooked up to . try to disconnect the sub and see if the protect light goes out
Feb 06, 2010 | Competition INTERFIRE BIG BOY 2CH...
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
My amp protection will not turn off i tryed almost everything?
i wish i can chat to you live so i can ask you qestions about your amp but to figure out what section of the amp might be fried it could be the power supply section could be the out put section or the in put section but i would try process of elimulation try unplugging your rca jacks and your subs unhook to your amp just the power hook up and try powering it but if the protection light steel comes on then try to remeber the last time your amp was working good and playing your subs was your amp getting hot if so you probaly fried your out put chips and not telling what else next question was you just hooking your amp up in your car and acually touch one of the power wire to the ground on your amp this happen to my friend and fried the power circuit relay chip on the power supply thats all the advice i can give but usually when the protection light comes on and you got every thing hook up right something fried
Oct 29, 2009 | Power Acoustik LT-980/2 Car Audio...
Amp protector light going on and dimming
first thing you want to check is the fuses in the amp, and power wire if applicable. This might cause the protection light to come on. I do assume you are referring to the protection light on the amp itself and not your car.
Post back if you have checked your fuses and have still not solved the problem.
Thank you for choosing Fixya!
Oct 03, 2009 | Car Audio & Video
When i hook my amp up only the red v comes on, and every thing is hooked up right.neither the protection or power light will come on
Hello perryman_ton,
Check to see that the remote turn-on lead has power on it when you turn the receiver/head unit on. If it does, the amp is probably defective. If the remote turn-on lead does not have power on it, try connecting it to a known good 12V+ source. A switched lead from the fuse box is best.
Hope this helps.
Aug 13, 2009 | Car Audio & Video
Amp goes dirctly into protect
ok well it could be two thing wrong your amp dont have a good ground or your amp is a smar amp and your subs must have to be hooked up so the power from the amp cn go to the subs so the amp can see that you do have subs hooked up to take it out of protect o and look at your fuses to to smal or to big will send it to protect to
May 19, 2009 | Kenwood KAC-9102D Car Audio Amplifier
Memphis PR300.2 Amp protect light on
If it is not turning on your problem is it is not getting power. Check your fuses. The reason an amp goes into protect mode is usually because the subs are not wired up right. Make sure your fuses are good, you have a good ground, and make sure your amp turn on wire didn't come loose when you were putting the deck back in. As for the amp going into protect you probably wired the subs down to too few ohms and the amp you have can't handle it. Try hooking the subs up straight w/o bridgeing them and turn it up to see if it works. If you don't have problems with it then you wired your subs wrong.
Mar 22, 2009 | Car Audio & Video
I have a power acoustik LX2-1000 amp. for the life of me i can not get it to work when i hool it up the red protect light comes on and wont go off. i thought maybe it wasnt grounded good enough so i ran a...
Check the fuses and make sure there are no wires touching. Thats all i know for an amp. If you're positive its hooked up right with good wiring the only other thing i could think of is the amp is fried. sucks..
Mar 10, 2009 | Car Audio & Video
Lightning Audio Amplifier, B3.200.2 Car Audio Amplifier Logo
74 people viewed this question
Top Lightning Audio Car Audio & Video Experts
80stech
Tygh Duval
Tygh Duval
Mark Skinner
Are you a Lightning Audio Car Audio and Video Expert? Answer questions, earn points and help others
