Question about Oceanic Alpha 8/ Sport Regulator with Dry Valve Technology - Regulators - S
The front cover of the 2nd stage is broken on
The front cover on my alpha 8 second stage is broken on the primary and alternate. Need to find replacement covers. Any Ideas?
  • 36 Answers
How about going to a Oceanic dealer? Eh? They should be able sell you the parts and install them. Remember, life support equipment should be serviced annually, and said replacements would be part of that service.
Posted on Aug 19, 2010
I have a problem shifting in to second gear on my 2005 zxr6 636
Hi, Robert and the usual suspects are:
1. Clutch dragging slightly.
2. Primary chaincase overfilled with lubricant.
3. Corners wore off shifter clutch dogs.
4. Shifter return spring bent or broken.
5. Bent shifter rod.
6. Loose shift lever on shifter shaft.
7. Shifter forks sprung.
8. Shifter pawl needs adjusting.
9. Heel/toe shifter coming in contact with the floorboard.
10. Transmission oil too heavy.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
2nd gear problem help
http://zx6r.com/zx6r/13501-2nd-gear-prevention.html
Kawasaki Ninja ZX 6R Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja ZX 6R Owner Manual
May 01, 2016 | 2007 kawasaki Ninja ZX6R
What is the torque spec for 2002 flht primary drive cover bolt?
Install primary cover and gasket using the
sixteen screws with captive washers tightening in sequence from center to front alternately top then bottom the middle to rear alternatively top to bottom to the rear of the cover to 100-120
in-lbs (11.3-13.5 Nm) in sequence.
Clutch inspection (Derby) cover screws 90-120 in-lbs 10.3-13.6 Nm
May 04, 2014 | 2002 Harley Davidson FLHT Electra Glide...
Harley torque specs
Install primary cover and gasket using the sixteen screws with captive washers tightening in sequence from center to front alternately top then bottom the middle to rear alternatively top to bottom to the rear of the cover to 100-120in-lbs (11.3-13.5 Nm) in sequence.
May 02, 2014 | 2006 Harley Davidson FLHRCI Road King...
Needs torque specs for 2007 Harley-Davidson Dynasuperglide clutch and primary bolts
what clutch fastener information do you want? Post a comment if you need more information.
What clutch
Sep 17, 2011 | Harley Davidson FXD Dyna Super Glide...
How do I take the hyperbolic tangent of a value
You'll find the hyperbolic functions in the MATH/Hyperbolic menu, available by pressing 2ND [MATH]. Alternatively, you can simply type in tanh(, enter the value, ), and ENTER.
For example, to compute tanh(1), press 2ND MATH, down-arrow eleven times, ENTER, 3, ENTER, 1, )(, ENTER.
Or t, ALPHA, a, ALPHA, n, ALPHA, h, (, 1, ), ENTER.
If the calculator gives the answer as "tanh(1)", convert it to a numerical value by pressing diamond, ENTER.
Mar 04, 2011 | Texas Instruments TI-89 Calculator
Cylinder head torque settings for 1989 Volkswagen Golf?
hi to tighten you have to do it in 4 stages as follows
1st stage 40nm leave 5 mins 2nd stage 60nm leave 5 mins 3rd stage 90 degrees leave 10 mins 4th stage 90 degrees then you are done i will try put order on here i hope this works as follows
10 4 2 6 8 front of engine back of engine 7 5 1 3 9
starting with 1 so it goes like this
10 4 2 6 8
7 5 1 3 9
hope thats some help to you
Aug 09, 2010 | 1989 Volkswagen Golf
How do you put degrees mins & secs in a ti 84 plus
The DMS symbols are available under the ANGLE menu
Press [2nd][APPS] (ANGLE)
Under that menu you find the degree and minute symbol. To enter the seconds unit you use the key sequence [ALPHA][+] (")
To enter 1deg 15 minutes and 37 seconds
1 [2nd][APPS] [1:deg] 15[2nd][Apps][2:'] 37 [ALPHA] [+]
To enter a number in decimal degrees (eg 15.37)
  1. If angle unit is the degree just enter 15.37
  2. If angle unit is the radian , you must specify the angle unit as degrees: To enter 15.37 degrees you type 15.37 [2nd][Apps][1: degree] [ENTER].
To convert from DMS to DD and from DD to DMS, you use the sequence [2nd][Apps][4:|=>DMS].
Feb 08, 2010 | Texas Instruments TI-84 Plus Calculator
Instead of the heating element turning on the heat pump runs out side thermostate is not set on eheat
The heatpump is your 1st. stage heat, when you have a call for heat it will bring on the outdoor unit.
When the first stage heat can't heat the house and the indoor temperature drops 2° or 3° then 2nd. stage heat will kick in and maintain the house temperature at about 2° or 3° below the temperature setting.
If you outdoor unit fails or goes into defrost then emergency heat will kick in and keep the house at 2nd stage temperature approximately 2° or 3° below thermostat setting.
If you have an outdoor thermostat or balance point setting on outdoor board, it will shut the outdoor unit off at a certain set outdoor temperature and the 2nd stage heat will be primary heat for the house.
Jan 05, 2010 | Heating & Cooling
Need the torque settings for a toyota carolla
1st stage 25Nm or 18.5Ft-Lb. 2nd stage 50Nm or 37Ft-Lb. 3rd stage 65Nm or 48 Ft-Lb Torqueing sequence: <-- Front 8 6 1 3 9 10 4 2 5 7
Jun 13, 2009 | 1983 Toyota Corolla Deluxe
Scuba octopus?
An octo IS a regulator. There are two types or regulators on a typical scuba rig. Your first stage reg that is attached to your tank valve. From this first stage, there are hoses leading to your primary breathing second stage reg and your Octo second stage. The job of the first stage is to bring that possibly 3,000 psi air in the tank, down to a more reasonable pressure of about 150 psi. From there, the air goes to the second stages and can be reduced down further by these second stage, on demand (meaning it delivers air when you inhale and stops when you finnish inhaling), regs. The Octo is a second stage back up for a buddy that is out of air or if your own primary second stage ( the one you normally breathe from) is no longer functioning. Octos are generally ( not always) a cheaper reg, that may not have all the bells and whistles that a primary air source does. It's there for an emergency, so ease of breathing under load and tuning adjustments are minor. It gives you air when you're in a pinch, thats the important thing.
Dec 01, 2008 | Aeris A1 Octo
Oceanic Alpha 8/ Sport Regulator with Dry Valve Technology - Regulators - S Logo
236 people viewed this question
Top Oceanic Scuba Diving & Snorkeling Experts
Bill Boyd
ray gallant
Are you an Oceanic Scuba Diving and Snorkeling Expert? Answer questions, earn points and help others
