Question about HP LaserJet 2200D Printer
The delivery rollers dust the paper with toner
My HP 2200 D Laserjet Printer have a printing problem, when the paper comes out its comes with a line of dust or toner in the delivery roller.
How can I fix this?
    Genius:
  • HP Master
  • 1,354 Answers
Hi
thank you for using Fixya
go to folowing link it will help you to repair your printer
http://alatest.co.uk/reviews/printer-reviews/hp-laserjet-2200d/po3-15372558,31/
Posted on May 16, 2010
Black line on right hand side of the pahe
This usually indicates the the Teflon coating on the fuser roller is damaged and will need to be replaced. The fuser is the part at the back of the printer that heats the toner and fuses it to the paper. The heat roller is coated with Teflon so the toner does not stick. If something scratches this coating the toner will stick and come off on the paper in a line where ever it is damaged. Here is a link to an article showing how to check the toner, the guide is for the 2100 printer but the issue is the same.
http://www.ccl-la.com/blog/index.php/how-to-fix-hp-laserjet-2100-vertical-lines-on-print/
Jan 22, 2013 | HP LaserJet 2420 Printer
HP laserjet printer2200dn it prints a blank paper and the paper comes out slowly what is the problem of this printer.
Try getting a feeder cleaner. It will clean the rolls or get a pressurized air can and use it to blow dust off.
Oct 16, 2012 | HP Laserjet 2200dn 2200 Dn Printer Duplex...
I have a preoblem with the HP laserjet printer 2200dn it printing blank and the paper comes out slowly from the fuser unit what could be the problem
The 2200 is a slow printer. I would guess there's no problem with the speed. You should try replacing the toner first. I've had this problem on off brand toner's (even brand new).
How to open H.P laserjet 1020 for cleaning the powder dust in printer
The only part of the printer that you ned to get at is under the toner cartridge. Open door, remove toner cartridge and vacuum dust. If you are referring to black toner dust on the fuser roller ( where paper comes out of printer ) that is alot harder job.
Feb 19, 2011 | HP LaserJet 1020 Printer
Black line going down side of paper from HP laserjet 1018
Roller Drum Problem in the cartridge.
If you are printing bulky document it may damage the roller drum causing dark line starting for both left and right paper. It will get bigger once it span of time.
Or if you are refilling the toner of the catridge, the waste compartment is full and requires to remove the waste tones inside the cartridge.
Or the worst thing is the the FUSER FILM ROLLER (orange plastic roller inside the printer is torn or burn because of heat or bulky printing.
Dec 08, 2010 | HP Hewlett Packard LaserJet 1018 Printer
Getting streaks on prints
Kindly check the Cartridge roller if there is any physical line if its then you need to replace the Cartridge.
Jan 28, 2010 | HP LaserJet 1100 Printer
When printing, I see a vertical streak on the printed page, from top to bottom, about 2 1/4 inches from the left side of the paper, and about 1/16 of an inch wide. I can't seem to see what causes this. The...
This is more than likely down to the upper roller in the fuser assembly. It's the heat roller at the back of the printer. The upper roller wears so paper dust and toner stick to the roller which then can get deposited back on to the page.
Oct 15, 2009 | HP LaserJet 1020 Printer
Black line on left side of paper
inside the printer on the paper pulling roller there will be some powder got collected on it due to this a black line appears on the paper.the power faLLS FROM THE TONER WHEN THE WASTE POWDER COLLECTING SECTION IN THE TONER GETS FULL SO IT FALLS on the roller while printing and this happens.take a air blower .bolw in to all the parts of the printer.keep the printer off .remove the toner cartridge.and keep the toner assessing door opened.and then blow the air in the printer.and then check out.
Feb 09, 2009 | HP LaserJet 3055 All-In-One Printer
Hp 2200 laser printer tray 1 paper delivery from top
Are these printers designed to handle Legal sheets?
Did you tell the Printers Software that you will be sending Legal size sheets to this printer?
Apr 10, 2008 | HP LaserJet 2200dn Printer
Printer is printing black line
Dirty Primary Charge roller. Change the Toner Cartridge.
Bad Toner Cartridge. Replace the Toner Cartridge.
Mar 07, 2008 | HP LaserJet 4 plus Printer
HP LaserJet 2200D Printer Logo
197 people viewed this question
Seeker5211
Seeker5211
