Question about Sony KDF-E55A20 55 in. LCD Television
Sony kdfe55a 20
Our sony kdfe55a20 had its lamp replaced about a year ago it worked fine now all of a sudden when you turn it on it takes awile to come on when it does the picture and sound off and on at about 10-15 second intervals the power light stays green the whole time if you turn the power off and on sometimes a red light blinks 5 times is it possible it could need replaced again the tv is only 2 1/2 years old
2 YEAR IS TIME TO RPLECE LAMP
Posted on Jun 25, 2008
I have a SONY KDFE55A20 TV. The picture and sound go blank and come back on in about 30 seconds. I get a red flashing light only if I turn the tv off and back on. It flashes 5 times and repeats. The bulb...
Sorry friend, but the only sure thing is that you're getting a lamp driver error. Odds are you're either having an issue with the ballast or your power supply can't supply the voltage needed. If you're good with electronics you can check the voltages on the power supply and try to rule that out. Otherwise you should take the set in for repair. Good luck.
May 05, 2011 | Sony Televison & Video
My KF60XBR800 will not always power up when we
Replaced the projection lamp again.Sony projection lamp more expensive,but last longer too.Genaric projection lamp brand last about 1 1/2 max.U hear clickinng sound too,when LED light flashes?Mean the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Jul 07, 2010 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony wega kdfe55a20 screen goes black, no sound
You can pull the lamp and have a look at it. I have a tutorial on these lamps if your interested. It has a bit of detailed explanation of how it works and how you can identify damage. To view it, look at my Tips & Tricks "Kitchen Table Investigation, Projection...". I hope this was helpful.
Mar 30, 2010 | Televison & Video
Tv will not turn on
For dark picture I need to ask one question, How long ago you replaced its lamp? one year, two years?
Picture brightness is depends on lamp in LCD rear projection (DLP) TVs and if lamp got weak in generating light, you will see dark picture.
I would recommend to replace lamp and buy Sony original lamp from Sony Accessories Store.
Required lamp part number is as follows..
F93087500 LAMP BLOCK ASSY XL-2400
and price is $200
Good luck.
Apr 29, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Replaced lamp in my sony55 inch tv still have lamp error 1
hello, if your still getting the lamp error then your lamp cover is'nt on right i'ld suggest taking cover off then re-installing it if the t.v. is'nt reading the lamp cover then it'll give you this error after re-placing the lamp, also take the lamp out and re-connect make sure the 2 prongs are on the lamp tight.
Mar 31, 2009 | Sony KDF-E55A20 55 in. LCD Television
HELP! KDFE55A20 watching TV and screen goes black and loses sound
Yes, its most probably lamp issue.
Please but original Sony lamp from Sony store and replace it in TV.
Mar 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
Ac not working right
You will need to add some coolant. Most auto parts stores and hardware stores have recharge kits. Purchase a kit with a gauge to prevent overfilling.
Jul 11, 2008 | 2000 Ford Taurus
Sony KDF-E55A20 55 in. LCD Television Logo
194 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
