Question about Whirlpool SF379LEKS Gas Kitchen Range
Our Whirlpool just started showing the following
Our Whirlpool gas range, model SF379LEK, just started showing the following in the time and temperature display: "E2 -F1-". Anyone know what the problem might be?
  • 26 Answers
E2 F1 - UL A/D error(s)
1. Disconnect power longer than 30 seconds.
2. Re-apply power and observe for longer than 1 minute.
3. If failure remains, disconnect power, replace control.
Here's parts diagram for your model:
SF379LEKS2
Diagram#2 Part location#12 is your electronic control that you can order if you need to.
Posted on May 16, 2010
Testimonial: "Sounds great!! I'll give it a try...THANKS!!"
Have a whirlpool accubake that needs to be converted to propane Model SF36zlxsy
Whirlpool 9755428 Conversion Kit (lp Gas ...
www.appliancepartspros.com > ... > Range > Whirlpool Range Parts
$18.90
Spud kit for lp gas conversion., 9755428 / AP3176464 made by Whirlpool. ... I needthe LP Conversion Kit (Orifices) for the model WFG320MOBS. What is the ...
[PDF]GAS RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/.../Use%20and%20Car...
Whirlpool Home AppliancesIf you should experience a problem not covered in TROUBLESHOOTING, ... You willneed your model and serial number located on the oven frame behind the ...... TheACCUBAKE® system electronically regulates the oven heat ..... Range convertedimproperly. If propane gas is being used, contact a service technician or.
Dec 20, 2015 | Whirlpool Kitchen Ranges
My WhirlpoolModel SF379LEK display shows an FS, E1 code and beeps. Any Ideas? Thanks for any help
Hi
Error code F5-E1 indicates that there is an issue with the door latch switch assembly; if the switch tests open then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 29, 2011 | Whirlpool RF378 Electric Kitchen Range
Whirlpool Range keypad partially not working
Could not find any other way to contact you - have you found a solution? I am having the same problem with the exact gas range model.
Thank you,
Dan
Jul 31, 2010 | Whirlpool GW397LXUS Stainless Steel Gas...
Start Button Failed on Whirlpool Electric Range Model GY396LXPQ02
It sounds like you have an oven problem rather than a start button problem. Is there an error code? If so list your model and error code on a search engine and you will find error codes. Or you can just list make model number and error codes and you can find a chart of Whirlpool error codes. I have done this with no problem. That should tell you the exact problem and things to try.
It may be neither issue you mentioned. It could be a bad element or a short.
May 29, 2009 | Whirlpool GY396 Electric Kitchen Range
F2 Error on Whirlpool Dual Fuel Range
I was baking and the stove suddenly changed to Maxi Broil and then to ERR F2EO Stuck Key. I cannot seem to change it by start or off or even turning the unit off and then back on. Any suggestions? Thanks.
May 11, 2009 | Whirlpool RF315 Dual Fuel (Electric and...
Whirlpool gas range control panel doesn't work
Hello glad to help. If this is the part that has been replaced before you may want to have a technician take a look at why the board is failing.
I have included a link to our PartsDirect page where you can purchase the part you need to complete your repair. Just click the blue link below to be taken to the page.
searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Range-Parts/Model-GW397LXUQ06/1198/0124250/W1203145/00001?blt=06&prst=0&shdMod=GW397LXUQ06
Aug 02, 2017 | Whirlpool GS460 Gas Kitchen Range
My Whirlpool Gas oven has started to burn everything
First, tell me what error it showed so we can get to the bottom of the problem
Dec 02, 2008 | Whirlpool GS460 Gas Kitchen Range
Whirlpool Gas Range E2 F3
I HAVE A WHIRLPOOL GAS RANGE MODEL NUMBER SF379LEMS.OVEN WILL LIGHT UP BUT AFTER TEN MINUTES IT WILL KICK OFF ANF ON ON ,THEN AFTER AWHILE I WILL JUST SHUT OFF.ANY SUGGSTIONS. ADAM
Nov 23, 2008 | Whirlpool GS470LEM Gas Kitchen Range
Model WHIRLPOOL WEP54800 Stove starts to beep at differnt times of the day.After four beeps F2 showes up and continues to beep when it feels it should. The control board has been checked twice and A new...
Hello fairglen,
welcome,
You said, model WHIRLPOOL WEP54800 Stove starts to beep at different times of the day.After four beeps F2 shows up and continues to beep when it feels it should. The control board has been checked twice and A new oven sensor installed. EVERY thing works perfect.This all started after water was brought to A boil on the back burner
But something is wrong!!??
Check your model number.
It is not showing up anywhere in the repair manuals or error codes.
Not even Canada.
What country did you buy it in?
How old is this range?
These are the only F2 codes I found in whirlpool so far!
F2 - Oven temperature sensor shorted = Replace oven temperature sensor
F2-Oven temperature above specifications = 8-pin connector oven temperature sensor to the Electronic Range Control (ERC)
Waiting your response or correction!!!!!!!!!!!
Huuum
Oct 17, 2008 | Whirlpool Kitchen Ranges
Whirlpool SF379LEKS Gas Kitchen Range Logo
293 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
