Rv air conditioner problem
My RV air conditioner comes on but does not cool. I thought it just needed freon but my nephew said it had to have a leak or it would have freon in it. Is this true? I am thinking of just buying another with heat but then I read something about heat strips. Can you tell me about them?
Thank you
  • 27 Answers
This is true...freon does not fade or get "used up" if freon is needed there HAS to b a leak.
heat strips are very expensive to use....option for the heat pump heating which will only use as much electricity as the a/c side.
heat strips= 220 v X 10kw= 22 amps compared to a compressor at ie= 10 amps.....typical draw for 18,000 btu
Posted on May 16, 2010
Dometic roof aircon cooling but not as much as usual, filters cleaned but were very dirty
the coil probably needs cleaning but it sounds like you might have a freon leak.
Jan 28, 2014 | Dometic Rooftop RV Air Conditioner
Location of freon in carrier air conditioner camper
They are a closed system, meaning they shouldn't need re-charge unless a leak has occurred, and to Have an AC repair person come and evacuate, cut lines, add fitting and re-charge, could get pretty expensive. Most people find it smarter just to buy a new unit but get an estimate on repair and decide for yourself. Why do you think it needs freon, not cooling enough, or at all?
Feb 23, 2013 | Dometic Rooftop RV Air Conditioner
I have a Dometic Duo Therm rv Roof Air Conditioner Model# 59516.531.The fan is blowing and the compressor is kicking on but it is not blowing out cold air. Someone said it must be out of freon. Why would...
These are a closed system.(meaning that there is no fill valves for recharging) But a heating & cooling technician can solder them on and re-charge the system. Only problem there is to get an estimate up front, and compare it to buying a new roof unit which also comes with a new warranty, as well as keep in mind that the freon went somewhere, so there is an obvious leak that will need to be addressed as well. Most times it's wiser and cheaper in long run just to buy a new roof unit.
Are you sure that the compressor is kicking in? Did anyone remove cover on roof and check lines from compressor to see if any cooling is occurring?
These don't often leak, that's why I'm asking. Any idea how old the unit is?
Perhaps in fairly new, it's a warranty issue.
Jun 25, 2010 | Dometic Rooftop RV Air Conditioner
How long does the Briskair Duo Thermal ac run before it runs out of freon? I have medical issues and can't breathe over 70 degrees. I can't go out side. Does anyone know where to take the rv for freon? Can...
I would think your RV repairman could add refrigerant. Any heat and air company could do this for you. The unit does not have service valves in it and a port will need to be added. I have seen these units 30 years old and still holding the original charge. It is impossible to say how long it will last. If you need to add refrigerant more than once a year you have a serious leak that needs repaired.
Jun 29, 2010 | Dometic Rooftop RV Air Conditioner
On my 1999 camper trailer when I turn on the dc powered lights while the airconditioning is running the compressor will kick off. If you wait 3 minutes it will come back on and continue to work fine until...
Welcome to FixYa
Not enough cooling complaints are due to air flow issues, and not lack of “Freon.RV air conditioner- come from the factory- are hermetically sealed.The first basic area is the air filter. In summer, using the RV and air conditioner around the clock, the filter should be checked weekly and cleaned as needed. RV air conditioners use either a foam type filter or a fine mesh, both of which can be rinsed in water and reused.keep the filter(s) clean.Few years latter even the best filter will let enough dirt past to coat the evaporator coils, though, so they need to be cleaned. If the coils are not too dirty, and if the installation leaves enough room to access the coils.Once the cover is off, you can see the evaporator coil -Clean Coils too...
Thanks for Contacting FixYa....
Jun 10, 2010 | Dometic Rooftop RV Air Conditioner
Dometic duo therm does not cool or heat...
it should never have to be recharged unless there is a leak. so you should isolate the leak with dye injectable into the system w/ the freon and correct it, then fully recharge system.
Jun 09, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Quick Cool RV unit
Time to be serviced,could be a small leak and loosing freon, or low air flow due to dirty filter.,
Sep 06, 2008 | Dometic Rooftop RV Air Conditioner
Duo therm ac problem
Same problem. I have a 2005 on a Rockwood Roo. Worked fine in October 2009. Not working June 2010. Problem is not a freon leak, compressor went bad. I banged the compressor gently with rubber mallet then with a hammer but that did not work. The fan runs, the compressor runs but gets hot. Also no indication of freon moving through system as everything gets warm from the compressor outward.
Aug 25, 2008 | Dometic Rooftop RV Air Conditioner
RV Roof Airs, not so cool
After you check the pressure, get back with me. Age is always a factor with proformance. But really, unless it is leaking freon or has a defective part, the unit should work fine. Measure the temp drop across the coil. Meaning from the intake to the output. Get back with me.
Aug 17, 2007 | Dometic Rooftop RV Air Conditioner
Heating & Cooling Logo
78 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
