Question about Toshiba 57H81 57" Rear Projection Television
Have a toshiba 42H83 how do I get into service mode? think it is menu menu(hold) and push what at the same time
ENTERING TO SERVICE MODE
1) Press MUTE button twice
on Remote Control.
2) Press MUTE button
again to keep pressing.
3) While pressing the MUTE button,
press MENU button on TV set.
Posted on May 24, 2010
Hi I Have a Toshiba 62JM9UA Rear projector TV, canyou please advise how to get into the service menu,
TOSHIBA
With the set ON, press MUTE once remote, then press MUTE again and hold in down while pressing MENU on the TV
The letter S will appear on the screen to show that the set is in the Service mode
To select the adjustment that you want to change press CH+ or CH -
Press VOL+ or VOL- to adjust
METHOD 2
With the set ON, Push the MUTE button on the remote 3 times and on the third time hold it down then press MENU on the set.
Jun 09, 2011 | Televison & Video
My toshiba 42h83 tv is dead. It won't turn on. I
hello if you've never looked inside a tv before then you'll be wasting your time with out the right equipment it will be hard. get quote from an engineer good luck
regards
shaun
Jul 31, 2010 | Toshiba 42H83 42" Rear Projection...
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
I have a problem with a very shaky picture on my TOSHIBA rear projection TV model 42h83 I have tried the touch focus, all I really get is two horizontal lines of each color (RGB) they roll top to bottom...
Hi, I used to work in Best Buy and one of the key things about rear projection TVs and the reason they push those service plans on you is that the tubes/colors need to be calibrated each year. You can do this yourself by checking out the following website:
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=3229
Hope this helps :)
Sep 17, 2009 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 model projection HD tv has a bad wavy picture.
yes it can be fixed call a repairman and have them come out and repair it.it shouldnt cost more than a couple of hundred dollars to fix
Feb 01, 2009 | Toshiba 42H83 42" Rear Projection...
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83 42 in unstable video
Probable PIP sister board.Moderate skill & some tools needed.Advise==get a senior tech near you.
Sep 10, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 42H83
Most projects in life are "easy",if you know how.Chassis will have to be pulled,convergence IC's replaced w/top quality parts to prevent recall.Some excellant soldering will be needed for prevent maintenance,for instance,the steel jumper wires feedig b+ to convergence IC's. RE-align in servicer mode==final step.
Aug 03, 2007 | Toshiba 42H83 42" Rear Projection...
Accessing sevice menu
i tell people all the time if you get into the service menu and hit the wrong buttons i wont know what you did to it again if you post here to ask how to get into the service mode you dont have the desire to find the codes on the internet which are readily available as are service manuals turn on the tv push mute on the remote till mute goes out hold down mute button and push menu on front of tv hit menu again when the s comes up hit 7 on remote and watch out you just figured how to reconverge your tv maybe not
Dec 06, 2006 | Toshiba 55H70 55" Rear Projection...
Toshiba 57H81 57" Rear Projection Television Logo
199 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
