Question about Pioneer DEH-P4000UB CD Player
Front speaker output from wiring harness will only play one speaker. Got rid of factory wiring now it will only play the other speaker that wasnt working before. Also it no longer has an option for my ipod. it just all of the sudden quit showing up.
  • 4,924 Answers
In what regards the speaker it is a matter from the equalizer ..it probably have the settings on the left or right ..and when you changed the wiring just put them the other way around..in short the sound it is balanced on one side...check the first slide in the equalizer...it supposed to be the balance ..the other issue check if it is showing up when you plug the ipod..or try to see if it has a general reset ..and do it ..this will bring it to the factory settings and take care of both issues..
Posted on May 16, 2010
Need Car Stereo Wiring Diagram
Here you go. Be careful this can disable the truck in some models due to the radio system be tied into the factory anti theft system..
2009 Chevrolet Tahoe Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. The accessory turn-on is controlled by the lan serial network. Run a wire to the fuse box or ignition switch harness.
Car Radio Ground Wire: Black
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: The radio harness does not provide a dimmer wire. The dimmer wire is controlled by the lan serial network.
Car Stereo Antenna Trigger Wire: The radio harness does not provide a antenna trigger wire. The antenna trigger wire is controlled by the lan serial network.
Car Stereo Amp Trigger Wire: The radio harness does not provide a amp turn on wire. The amplifier turn on is controlled by the lan serial network.
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Jul 27, 2012 | 2009 Chevrolet Tahoe
I have a 2005 pontiac grand am and cant seem to hook it up. the wire installation kit that advance auto parts sold me Metra autoworks stereo wire harness. the wire harness number is AT-WHGM3. The clarion...
Ok, relax. The purpose of the harness is to wire you radio to it, then be able to plug into the factory harness without cutting wires. Let's start from scratch. The harness you have should have all the wires you need IF you told the retailer all the specifications of your vehicle. Basically the harness should have a positive, negative, switched power, and speakers (4 sets). Speaker wires are generally grey, green, white, and purple. Constant power is red, switched power is yellow, and ground is black. However, you unit may have other wires coming off of it, such as remote turn on (usually blue), RCA outputs, and will have an antenna jack that you may need an adaptor for. Sometimes factory harnesses have two plugs. Sometimes they are not required for the radio to be functional (it may be the output and return for an external amplifier that you are currently bypassing). So follow the instructions on the package. Don't feel like you have to be stuck in your car to hook your radio to the harness either. Hope this helps.
Sep 03, 2011 | Clarion Car Audio & Video
I am replacinng the factory stereo with a JVC unit. The harness for the original has two orange wires, one plain the other with a black stripe, and the JVC one doesn't. What are these for and are they...
the orange wire in the #8 cavity is your key on power wire, so yes you need it the yellow wire in the #1 cavity is the 12 volt alwise wire so you need it as well the orange wire in the #10 cavity is the right rear speaker wire + you also need it hear is the wire list.
wire #1. yellow 12 power with key on
wire #2. gray interior lights
wire #3. green right rear speaker -
wire #4. red right front speaker +
wire #5 black left front speaker -
wire #6 brown left rear speaker -
wire #7 gray power antenna
wire #8 orange 12 volt power hot all times
wire #9 pink interior lights
wire #10 orange right front speaker +
wire#11 blue right front speaker + ( door )
wire #12 empty
wire #13 empty
wire #14 yellow left front speaker + (door)
wire #15 white left rear speaker +
wire #16 black/orange ground
Apr 17, 2011 | 2004 Kia Optima
I have a BMW 318i 1993 and when i got it there was a big speaker and amp hooked up. I unhooked it but now i cant get any sound....the radio lites up but no sound. i know speakers work cuz they worked...
Hello pinkpimpin20,
Without knowing exactly what modifications were made to the factory sound system, it's difficult to point you to a particular fix. The number of channels on the "big amp" that you disconnected would help. Even the make and model.
But, from your description it's possible that the previous owner installed a multichannel amp to drive both the "extra bass speaker", usually referred to as a subwoofer, and the original vehicle speakers. In that case, the speaker wiring from the head unit (receiver) was cut and the receiver side of the wires was rerouted to the input of the aftermarket amp. The output of the amp was then connected to the other ends of the speaker wiring.
To restore to the original, you need to pull the stock receiver and resplice the wiring. If the previous owner cut the plug completely, it may be necessary to purchase a replacement from your BMW dealers service or parts department. It's possible, but not likely that the previous owner used both an aftermarket "harness" and an aftermarket "reverse harness" to avoid having to cut the wiring. In that case, all you'd have to do would be remove them and plug the radio harness back into the vehicle harness (or the back of the radio). But most DIY audio enthusists don't mind butchering the vehicle wiring. And you'll probably find that electrical tape was used to secure the wiring. After a year or so under the dash, it'll be a sticky mess to unravel.
The speaker wiring colors for the '93 318i are as follows:
Left Front Speaker Wire (+): Yellow/Red
Left Front Speaker Wire (-): Brown/Orange
Right Front Speaker Wire (+): Black/Red
Right Front Speaker Wire (-): Brown/Orange
Left Rear Speaker Wire (+): Yellow/Black
Left Rear Speaker Wire (-): Black/Orange
Right Rear Speaker Wire (+): Blue/Black
Right Rear Speaker Wire (-): Brown/Orange
Hope this helps.
Sep 24, 2009 | Jensen Car Audio & Video
2003 silverado z71
You could get a stereo installation kit for your year, make & model, that comes with a pigtail plug that would plug right into the existing harness plug and prevent you from having to hack up your original wiring harness.
If not....
Car Radio memory Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Good luck
Aduz
Mar 21, 2009 | Alpine iDA-X200 Car CD/ MP3 Player
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Mar 08, 2009 | 1996 GMC Jimmy
Audio wiring problem
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown (or your own wire to a metal grounding point)
Illumination Green
Antenna Trigger Black/Red
Front Speakers 4" Dash
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Green
Right Front (-) Blue
Rear Speakers 5 1/4" Rear Deck
Left Rear (+) Black
Left Rear (-) Yellow
Right Rear (+) Red
Right Rear (-) White
I a '83 camry, there are 2 seperate plugs that go into a factory radio.
One for Power/and front speakers, and the other for rear speakers.
Sounds as if you are missing part of the harness for the rear speakers (or it is shoved in the back of the dash unused by the previous install). If there is not an un-cut plug in the dash - your only course of action would be to run your own set of speaker wire to the rear.
See this picture... these are the plugs that should go into your factory radio....
Metra kit 71-1938 will go from your factory wiring directly into your factory radio.
Thanks for using FixYa - a FixYa rating is appreciated for my effort in answering this Freebie question.
Feb 25, 2009 | 1983 Toyota Camry
Chevy Tahoe radio wiring problems
I had the same problem and here's what fixed it. By default, I did not connect the blue/white striped remote wire to the harness. Apparently there is an amp somewhere in the vehicle I did not know about. After looking at the factory wiring and the aftermarket harness, I noticed that the remote wire was used and I connected it with the remote wire on the harness and everything came up and worked perfect.
Jul 11, 2008 | JVC KD-G110 CD Player
I just bought a factory radio to put in my Eclipse. After hooking up all the plugs, radio comes on but no sound comes out of the speakers.
Are you sure that there are speakers currently installed in the vehicle? There may not be, I have seen vehicles that didn't come with factory radios not come with speakers either. If you do have speakers you may want to take the deck back to where you purchased it and show them the problem. If you purchased it online, then you may be stuck with what might actually be a dead unit.
Jun 13, 2008 | Car Audio & Video
Audio Output problems
Currently you have the blue wire from your Kenwood head unit connected to the blue wire in the Chrysler wire harness adapter. You need to disconnect this wire, and reconnect it to the blue/white wire coming from your Kenwood head unit instead. You probably already have the remote wire from your subwoofer amp connected there; both wires need to be attached to the blue/white Kenwood remote output. Your LHS is equipped with a factory amp. The blue wire in the Chrysler harness activates the amplifier, but it's connected to your Kenwood's power antenna activation output; therefore it's only being turned on when the tuner is selected.
May 30, 2007 | Kenwood KDC-MP828 CD Player
Pioneer DEH-P4000UB CD Player Logo
32 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
