Question about Toshiba Satelite A135-S2286 Notebook
How do you put a key back on a laptop keyboard. It is a plastic key with a sissor latch and a small diameter metal rod bent into a wide square bottomed U. My daughter pulled it off can't get it to latch back on.
  • 281 Answers
You have to get the sissor part back on first,
there are 4 small i-holes in a square on the keyboard,,
on the sissor part there is 4 small nubs on each corner, thay clip into the 4 i-holes,,
the key itself just clips down on the sissor part.<---Make sure its lined up b4 pushing
Posted on May 16, 2010
How to replace a key on laptop keyboard
a pair of tweezers a small flat head screw driver and persistence along with being careful and if you get irritated or annoyed stop and have a break and come back to it.
Take one of the keys off near it to see which way around the plastic parts go ( not too hard as you dont want the other plastic clips snapping or breaking off ) and see if any little bits of plastic are snapped - if they are you will need replacements so contact asus - if not and they are still in tact then put the 2 plastic hinges together the correct way around and then put them back in place ( you may have to slightly bend the metal clips on the bottom of the keyboard where the plastic bits fit ) which is where the small flat head screw driver comes in handy.
When you are putting the plastic parts together you may need the tweezers or possibly a paif of needle nose pliers ( being very careful as you dont want to snap the plastic clips / hinges )
Once you get the plastic hinges back in / on you can bend the metal parts back slowly and gently so as to hold the plastic bits and then push the key back on.
You should then be able to push the other key back on and that should be it.
If you need any replacement parts then you will have to contact asus.
Apr 10, 2009 | ASUS M51SN-B1 15.4" Core 2 Duo 1.83GHz 3GB...
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
Change of CMOS battery in IBM Thinkpad 1400 2621
This battery is hidden under the keyboard slightly up and to the right of center of the keyboard. To get it out is a pain.
Start with the computer sitting flat, lid closed, lid latchs facing you.. just like you were getting ready to open and use it.
Spin it around, rear ports facing you. Right above the external video port, on the right hand side, there are two screws, at a diagonal UP from the port itself, very close to the bottom edge of the LCD. Remove them. There is a small notch between the screws, using a small flat-blade screwdriver, pry up in the notch and pop the platic backing free from the rear of the laptop. DO NOT open it more than a small crack, you are just popping loose a small plastic tab. Open it too wide and you will lock it closed again or break the plastics when you open the LCD lid.
Spin the machine around again, and open the LCD carefully as far back as it will go normally. Find the Power Button. The Power button is to the far right of a plastic 'strip, with 4 other buttons on the far left. There is a small clear plastic strip overlying this button 'tray'. Find the small notch in the bottom edge of the clear plastic strip, use the flat-bladed screwdriver, and gently pry up, popping the plastic strip out of the tab holes in the tray. Under this plastic strip is a black adhesive 'strip' that has a house, magnifying glass, etc. markings on it, and 'i Series' or somesuch printed on it.
Using a razor blade, peel up the black adhesive strip on the left and right ends of the button 'tray'. You will find two small silver screws. Remove these. Then using your screwdriver, or as I did, a dental pick, *gently* pry up the entire tray from the BACK edge of the tray, and by lifting up the left side of the plastic tray. You will have to work it out from under the edge of the LCD bottom on the left side. DON'T yank on it, there is a small cable attached to the bottom of it. You will be able to rotate it toward you and roll it over, exposing the small latch holding the cable in place. Its a small, press-fit latch like what holds a keyboard cable in place. You'll need to work it open by lifting the left and right edges till the latch becomes loose. Pull the cable straight out of the slot, remove the entire plastic 'tray', and set it aside.
On the far upper right of the keyboard there is a small metal tab holding the right upper edge of the keyboard. Reach around to the back of the computer, right-hand side rear, find the little square thumb-notch, and pull it out. The latch on the upper right edge of the keyboard should retract. Now, while lightly pressing down on the keyboard, push the keyboard away from you. It should slide backwards and the front tabs on the front keyboard edge will pop out of the slots. Lift up the touchpad area, popping up the bottom edge of the keyboard, clear of the plastics, then pull the keyboard slightly toward you. It should pop loose all the way around. DO NOT yank on it, there are 3 small cables attached underneath. You wil need to lift the keyboard up enough to reach the cables and pop the lockdown tabs loose, then pull the cables straight out of the slots they are in. The cable slots are attached to the motherboard, the cables are attached to the keyboard.
Removing the keyboard will expose a flat silver panel underneath. There are 5 screws holding down the panel, 4 in a 'box' configuration on the left, and a single one on the right, and several slide-tabs around the edges. Remove all 5 screws, then slide the whole tray to the right, while lifting up. The entire tray will pop up, with the video card heatsink attached on the left-underside of the tray. Set this aside. Directly in the middle of the big hole you now have is the battery. Its smaller than a standard desktop motherboard battery, looks like a small silver button. Gently pry up on the bottom-left edge of the battery, very carefully or you will break the plastic clips holding it in place, and pop it out.
All done. Reverese order to put it all back together.
Feb 21, 2009 | IBM Thinkpad I1400 2621 Planar TV...
Key popped off keyboard
On the Keyboard, There should be a small little clamp housing. On the back of the key you should see a piece of metal that is sort of Staple shaped (A non bent staple) Just try and put the ends of the metal into the housing, Then apply a little amount of force onto the key to pop it back in.
Before applying pressure, Make sure that both ends are properly in place.
Hope this helps!
Jan 05, 2009 | Sony VAIO VGN-FS640W Notebook
Tip
How to repair laptop key
If your keys fell off from your keyboard, you can easily repair it by following the installation guide below.
You should have a key cap, one large and one small plastic pieces (retainer clips).
Take the larger plastic piece, it must have two larger sticks at either sides that are going to click onto the larger metal hooks on the keyboard.
Take the small plastic piece. It must have a small bar on one side that is going to click onto the smaller single metal hook on the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece. Make it one piece.
Put the plastic piece into the metal holes on the keyboard. Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces so that it clicks together.
That's all.
Source: http://www.laptopkey.com
on Dec 01, 2009 | Computers & Internet
Missing key
Hi Allie18,
If the cat has not eaten the small plastic clips that fixes the key to the keyboard, you are in luck.
Just place the key over the keyboard, align it so it is square with the other keys, push it down firmly until it clicks into place.
If this does not work then you have some missing parts or bent piece of plastic.
If you are game, you can remove an adjoining key by lifting it up, then you can check this key and see if it matches the other key for missing or bent parts.
Your Dell supplier may have replacement keys, if not you will need to replace the whole keyboard.
Nov 24, 2008 | Computers & Internet
2000 Dodge Caravan Rear Door Latch
I had the same problem and fixed it using the following steps. I am not an expert or even very mechanically inclined, just desperate to get this fixed without spending any money. This was done on a 1996 Dodge Caravan. Similar steps should apply to a number of years of the Caravans and Voyagers.
Two people will make removing the panel easier. To do this, you'll need a phillips screwdriver, penetrating lubricant, and pliers.
First, if you cannot open the door at all: There is a small plastic disc plugging a hole just above the latch on the inside. Pop out that disk, and use a screwdriver to lift the latch mechanism. It should not take a great deal of force to move the latch. When the latch moves, push the door and it should open.
1. Remove the plastic panel on the inside of the van. You need to remove the handle and several screws on the perimeter of the door.
2. Disconnect the interior door lights by gently pulling the wiring harness (two of these).
3. Looking at the door from the interior, there is a small electronic plunger mechanism on the right side with an "accordion" (this is the electric lock). There is a rod that goes from the to the middle of the door, just above the lock mechanism. Another rod goes from the key lock to the latch. This rod, threaded on one end, snaps into a small bracket on the latch. It may need to be snapped back in. There may also be a rubbery/tar-like sticker near the locking mechanisms that can be removed (it can interfere with some of the moving parts).
4. Manually operate the plunger on the electric lock several times using pliers. Mine was extremely stiff. It should move the rod at least a full inch.
5. Spray lubricant on the latch, the back of the key lock, and the back of the exterior handle. Also spray lubricant into the key lock itself (where the key goes). Do NOT spray lubricant on the electronic lock mechanism or plunger.
6. Just above the latch, there is a small hole (only about 1/8" around). Carefully and liberally spray lubricant into that hole in every direction (this is where the rods from the key lock, electric lock, and latch meet). There is a white plastic post that comes out through another nearby hole. Spray lubricant liberally into that hole, too.
7. Again, manually operate the plunger on the electric lock several times using pliers. It should be considerably smoother to operate.
8. Put your key into the key lock and pull it out several times.
9. Spray lubricant into the key lock again, then carefully operate the lock with the key. If it didn't work or was stiff before, it should operate much more smoothly. Operate the electric locks several times.
10. When operating the lock, you should see the plunger on the electric lock move to its extents (at least an inch). Watch it when using a key and using the electric lock.
11. Check the movements of the rod and plunger when operating the lock, and the movements of the latch when operating the handle (when unlocked). If anything is still really stiff, use some more lubricant and operate the lock and handle again.
12. When reassembling the door panel, remember to plug in the two wiring harnesses for the interior lights.
I hope this helps!
Jul 06, 2008 | 2000 Dodge Caravan
Putting keys back on acer 3100 laptop
yes..this is particularly a delicate operation. do you have a magnifying glass and small pliers..
Apr 03, 2008 | Acer Aspire 5100 Notebook
How do you repair a keyboard button that has popped off
the problem IS self fixable. I just did it now to my "]" button on a gateway laptop containing 2 plastic peices underneath it. There are concepts that make a laptop keyboard work. Primarilly, a slightly bendable pair of plastic peices that are made to latch together at the middle to form an X shape, the bottom of the X containing two comparatively large slits where it seats at the base of the keyboard (tuck them in first so they both snap), and at the top of the X is 4 notches where they meet at the button's back surface to snap into. the X shape is arranged first so that you can manually lift and drop the X so it smoothly lifts and drops. After securing the primary mechanical system, you snap one side of the button to the X shape only. Then you use a very thin long peice of metal like the end of a sissor or small screwdriver to lift the middle of the bottom side of the button so the entire button is lifted to about the height it is supposed to be, then keep it there so the button doesnt move any lower when you try to snap the other side of the button firmly down. This is the hardest part of the repair since you cant really see what your doing, but as long as the button is lifted to its normal height, it should snap in and look as good as new.
Jan 25, 2007 | IBM ThinkPad T42 Notebook
Toshiba Satelite A135-S2286 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
