Question about Amcor PCM 10000EH Portable Air Conditioner
Unit vibrates violently
Im afraid to attempt to see if unit cools because of vibration poccibly compressor is moving around ,controls and electronics seem ok how do i open to remidy this possibe problem thanks guys DB
  • 53 Answers
Okay locate the screws on the bottom an the sides of the unit to open the system soon as the system is open ,try to locate the fan motor that supplies air to room an cools compressor off thats your problem with vibrations
Posted on May 16, 2010
My frigiaire is not cooling and has started beeping and not getting cold I need help couse my food is thawing out
Open each door if light turns on then check that u can hear the fan and feal the air move. If good then check fan that is under or behind refrigerator. It too must be turning. If good carefully touch the top of the compressor. It should be warmish and lighlty vibrating. If its hot And or not vibrating it may be stuck... (fans also get stuck sometimes). .. unplug fridge wait 1 minute then plug back in while keeping your hand on compressor. If it moves quickly then vibrates quietly it should be working and if all else is good u may have a freon leak. If no movement i would suspect its stuck and you need a hard start kit for small refridgerator. About $20 from ac supply or online. Easy to install im sure youtube has a video of that as well. Ive fixed many a fridge this way..Freon can be replaced but requires a buddy with tools:)
Jan 29, 2015 | Refrigerators
Why would I get Violent vibration on pull away when vehicle is warm, it has done 2600 hours
try replacing the drive belt. It should be replaced every 200 hours. Im guessing it is the original and is completely worn out.
May 15, 2014 | John Deere 2011 Gator XUV 4x4 855D
Optoma th1020 - heard loud "pop" and now projector vibrates violently. Shaking so much that it cant stay in focus
Sounds to me like a blade has come adrift from one of the cooling fans in the unit, throwing the fan out of balance (The pop you heard will have been from the pice of plastic being ejected from the fan). Unless you are experienced in electronic servicing, I would not advise opening the unit to identify which fan - you'll almost certainly have to take it to an authorised repairer anyway since these fans are usually highly customised units
Apr 01, 2014 | Optoma TH1020 Projector
Does tipping an A/C effect the gases in the compressor?
ya that can that can mess it up because you ave the freon in it and its just apost to use the gas that comes up from it whe it tips it get the liquid freon in it
Jun 29, 2012 | Kenmore Heating & Cooling
Whynter Portable Air Conditioner Model: ARC-14S. Problem: It sounded as if something fell inside the unit while it was operating (cooling) then it started to vibrate horribly. The vibration is only...
Hi,Whynter Portable Air Conditioner has many moving parts, and they all make noise and cause vibrations. Some of these parts are more likely to causing shaking and loud noises, and sometimes this signals a larger problem, something to watch and scrutinize. If serious enough, it calls for a repair.
Loose Parts
Loose parts cause the majority of shaking and vibration noises in your air conditioner. A few of the most common loose parts include the air compressor, the piston rods and even the fan or blower unit itself. These noises are clunking, clanking sounds that occur along with a vibrating action. The only method of repair is a complete compressor replacement, which is a repair only a certified air conditioner technician is qualified to make. The compressor is a fully sealed component, so individual parts in the compressor cannot be repaired.
Fan Blades
Fan blades cause noise, shaking and vibrations even when properly secured. If fan blades contact the exterior structure of the air conditioner due to a bent fan blade or broken and misaligned grate, a constant, repetitive noise and vibration results, which sounds like a ticking or banging from the interior of the air conditioner. Vibration in this case is limited but still present.
Mounting Brackets
When an air conditioner shakes, there is a problem with the mounting brackets. These brackets hold the air conditioner compressor steady as it operates. Normal vibrations and shaking would otherwise occur without these brackets. A loose mounting bracket causes the air conditioner to rock back and forth and creates a clanking sound. As the compressor starts up, this rocking and clanking sound begins, resulting in a very loud and fast vibration and noise. It also occurs when the unit shuts down.
Other Sounds and Vibrations
Sometimes air conditioners squeal, hiss, hum or screech. Each noise is often accompanied by a vibration. Humming sounds along with a vibration may indicate a bad capacitor, the electrical part responsible for starting the machine. Hissing sounds tend to indicate a pressure problem while screeching and squealing sounds are fairly common in window air conditioners and in central air conditioners. This sound is also a result of the compressor motor. It usually starts when the unit turns on and continues through its normal operating cycle. Vibrations always occur in the air conditioner due to moving parts and the compressor motor's operation.
Hope it helped..
Aug 18, 2011 | Whynter Portable Air Conditioner
Bosch classixx 1400 express spin vibration problems - when my machine spins is vibrate violently and moves across the floor - how do i fix it?
Is the clothing distributer evenly around the drum or is the washed bunching it up and spinning it around as a ball.
Jan 16, 2011 | Washing Machines
Whirlpool side by side does not cool at all
Simple Fix. That's cost around $40. You need to replace your relay/overload. Its mounted on the compressor. It should have a black box over it. Take it off then pull the part off the compressor and replace it with a new one.
Jul 30, 2009 | Whirlpool ED0GTQXMQ Side by Side...
Violently vibrates while spinning
Hi, First thing you want to be sure of is that the machine is solid to the flor. Check and see that one of the legs hasn't moved. Get me model# if you need further assistance please.
Vic
May 21, 2009 | Washing Machines
Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
May 16, 2008 | Haier ESA3245 Thru-Wall/Window Air...
Shakes violently
The bearings of you machine are damaged or bad..You have to get em' replace..until then lowering the water pressure will solve this problem to some extent..
Oct 24, 2007 | Hotpoint First Edition FEW12 Front Load...
Amcor PCM 10000EH Portable Air Conditioner Logo
142 people viewed this question
Top Amcor Heating & Cooling Experts
AJMAL KHAN
Donni Steen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
