Question about HP Pavilion dv2-1030us Notebook
Ok this is odd. I have a dv2-1030 and every time i put a harddrive in new or use i still get operating system not found. I have tryied installing a new os with no luck because it says there is no drive there and i tried self test to hard drive and its not there. Could the connector go bad on the motherboard.
  • lifechanging May 16, 2010
    I booted from a usb using both xp and vista. I did figure out that sometimes it will connect but after a while the connection will be lost. im thinking either the connector is bad or something internal is wrong and i know its not the bios/cmos.
  • 281 Answers
Yes the connector can go bad..
Did you try booting from CD? useing a windows cd?
The cmos may not be setup right, when you first turn it on look for [push f1 to enter setup] maybe f2,
Some time when you unplug a hard drive then turn the computer on it will disable it in cmos
Posted on May 16, 2010
Boot device not found
1) BIOS Setup states no harddrive found? Remove all power. AC adapter (Charger), and Battery. Remove Harddrive. Press Power On button in, hold in for 10 seconds, let go. Do this procedure 2 more times.
Reinstall Harddrive, and then Battery. Hook AC adapter again.
Harddrive recognized now?
You press the Power On button. This in turn presses against the Power On switch. The power is initialized. First chipset to receive power is the BIOS chipset. The Basic Input/Output System program is initialized. BIOS LOOKS TO SEE WHAT DEVICES ARE INSTALLED, does a Ram Memory count, and hands the computer over to the Operating System.
This is what I am basing the above on.
2) Not to knock sellers on Ebay, as I have found a few that are decent.
However the motherboard could be bad.
Harddrive controller could be bad.
Southbridge chip of motherboard chipset,
(CPU = Processor),
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
3) Don't E-slap me, but you were wearing an ESD wrist strap, with it's alligator clip attached to a good ground source; when replacing the motherboard, correct?
Please post back in a Comment.
Regards,
joecoolvette
Mar 15, 2013 | Computers & Internet
Operating system not found !
Your harddrive has failed or your operating system has crashed.
You will have to either run a repair disc (windows 7 installation disc or whatever Operating system you had installed on it before) or get your hands on a new installation disc and install a new operating system. Either that or take it to a computer geek in order to have them reinstall the operating system for you and hopefully, recover all of your files.
Aug 14, 2011 | Toshiba Computers & Internet
My computer is missing important system files
> type the path ...
Specify: C:\WINDOWS\ServicePackFiles\i386
as the "path".
Jun 23, 2010 | Computers & Internet
Corrupt harddrive
You state that you have pulled the pins out of your harddrive. If the harddrive is physically damaged then the data cannot be recovered economically. Do not try to take the disks out and put it in another drive: you will loose another one in the process.
I suggest you take the drive to a computer repair shop and see if the drive board can be changed.
Once the drive is working then install it as a slave on a working system, copy all your files to another location and format you old drive.
After formatting you have a choice to discard it (if it is old) or reinstall windows on it.
Aug 12, 2009 | Microsoft Windows XP Media Center Edition...
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Get error message "operating system not found"
Run diagnostics on the harddrive. if possible reseat the Hard drive, i.e take it out and put it back again. and then try installing the OS. remember you have to boot from the laptop to install OS. Hope you are doing it correctly
Apr 09, 2009 | Sony VAIO VGN-FJ270/B Notebook
When your laptop starts up enter the BIOS setup and insure that the drive is recognized. If not re-seat the drive and try again. Also, are you sure the drive is compatible with the laptop.
Jan 16, 2009 | Compaq Presario 1692 Notebook
Operating system & harddrive not found
Did you remember to enter the BIOS setup and change the boot drive so the system would look to the (optical) drive in which you have put your XP disk? In most cases, you must tell the system where to look for boot files and with a new hard drive, there are no files to find.
If you don't have any malware defense installed yet, and can again get it up and running enough to go on line, I would recommend all of the following:
- AVG Free Grisoft Home Page - Spybot S&D Spybot Home page - AdAware Lavasoft Home Page
Basic versions are either free or ask for donations.
Oct 26, 2008 | Gateway 4525GZ Notebook
Bad Harddrive
please check your cables and try with new one.check the bios setting
Apr 04, 2008 | HP Compaq Business Notebook NX9010
HP Pavilion dv2-1030us Notebook Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
