Question about Kenmore 22932 Top Load Washer
How do i remove the agitator dogs on 22952 kenmore elite washer
  • 15,935 Answers
The following advice is for replacing the "Agitator Dogs" on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are "Agitator Dogs"? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16" hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8" to ½" ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It's that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 30, 2010
Washer won't agitate
First, see the Sears parts site for washer model # 110.22952100 which I believe is your model.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22952100+
Look at the section containing the agitator and you should see how the parts fit.
Also see the following for an illustrated description of replacing the "dogs"
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=136&osCsid=71493d5cab3d7784ad8aa7cde8e5e5d4
Nov 17, 2009 | Kenmore Washing Machines
I have a kenmore elite model # 20949 and the bottom of the agitator turns but not the top
If the bottom agitates and not the top, the problem is likely the 4 "agitator dogs" designed to allow the top agitator to turn only one way.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Look at the section on the Sears site for Agitator, basket and tub.
See the part "Dog, agitator "
Remove the fabric softener unit, lift the top agitator cap (use a screwdriver) and you should see a plastic part in the center of the top agitator with
a 1/2" square drive.
Remove the drive and lift off the top agitator. Turning it over you should see the 4 "dogs", replace these and the top agitator should turn in one
direction only.
Replace the 1/2" drive, the cap and fabric softener unit and the top agitator should work.
Oct 31, 2009 | Kenmore Washing Machines
How do I replace the dogs in a Kenmore Elite washer?
With a flat blade screwdriver or putty knife, remove the top cover from the agitator. Use pliers to pull out the inside plastic cover.Take a 7/16 socket on a extension and remove the nut .Pull the agitator out. It should separate. If it does not separate,stand on the lower half and forcefully pull up on the upper half.Remove the agitator dogs and spline gear from the upper agitator. Replace the dogs. Re-assemble the agitator. Wash clothes.
Jul 14, 2009 | Kenmore 15.5 in. Pedestal
Washer making rubing noise while turning
On the back of your machine you can remove the back panel think it is about 8 screws. Once you get the back panel off look closely at the motor. Motor mounts, gears, clutch, brake, and if need be take the bottom apart and look at the main bearing on the bottom of the drum to make sure that hasnt gone bad
Feb 14, 2009 | Kenmore 24032\24036 Top Load Washer
Washer wont spin
Feb 14, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore elite won't agitate properly
Does the bottom of your agitator work correctly? We had the same problem if you pop the cap off the top of your agitator there is a cam in there with 3 dogs that engage the agitator causing it to spin. If the bottom part is agitating correctly then chances are the dogs in the cam assembly are shot. If the bottom is agitating correctly then it is very possible you have something stuck under the bottom section of the agitator. If this is the case remove the top cover (same as before it's just a lid that pops off) inside you will see a 1/2" square use a 1/2" drive ratchet with a 3" or 6" extension unscrew this piece remove the top section of the agitator then the bottom. Once the bottom is out check to make sure all is clear inside the washer. Reassemble in the reverse order making sure the lower section sits all the way down on the splines for the drive mechanism. If neither one of those solve the problem I would suspect you have an issue in the drive train of the washer.
Dec 29, 2008 | Kenmore 24032\24036 Top Load Washer
Kemore elite top loader won't fully agitate
If you have a whirlpool built machine th problem is probably the agitator dogs. They are located inside the agitator. My guess since you say it doesn't fully agitate. If changing the dogs does bot fix the problem then the coupler is probably bad and that connects the motor to the agitator.
Kenmore elite washer not agitating properly
pull off fabric softner dispenser ..some twist off others pull blue ring up and then dispenser up..under neath remove the cover by prying cap or pulling up on tabs..remove 7/16 bolt or on some use 1/2 in drive extension to twist out retaning bolt pull top off and replaced the agitator dogs underneath ..part#80040
Sep 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 22932 Top Load Washer Logo
337 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
