Question about Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm
Rheem gas tankless water heater with error code c4 13
Rheem gas tankless water heater error code c4 13- how do i fix
  • 67 Answers
Problem is inside burner compartment o2 sensor dirty or block..need to have a qualify technician clean it.
Posted on Jul 31, 2010
I am getting a C2 11 problem error on my Rheem tankless water heater, What that mean?
Just how much did you investigate this on the internet before asking here? I Googled " Rheem C2 tankless water heater" and found http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html. Look under Error Codes. Code 11 refer to gas supply/ignition. If you don't know much about tankles water heaters or gas ignition, call a Rheem Tech.
Dec 13, 2014 | Rheem Water Heaters
Need repair and diagnosis
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#no-error
Fix any tankless problem quickly yourself today for $380... and install tank-type heater:
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Don't buy tankless... don't buy Rheem products... seriously now.
Gene
h
Jan 23, 2014 | Rheem Tankless Water Heater RTG-74XN-1,...
My Paloma pg-711fr is turning itself off and error 12 comes up
Copy following link for error codes and Rheem-Paloma tankless troubleshoot.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html#error
Add a comment and say if this is new installation.
Call Rheem and hear them tell you to call the tankless installer, or hire local service technician to check your tankless computer that heats water, and catch up on required monthly and yearly maintenance. For example cleaning burner and flame rod, or replacing bad flame rod, or installing correct gas line, or checking gas pressure etc.
Fix any tankless problem yourself, any brand tankless, same day for $385, by replacing 1 part: the whole thing:
Do not install tankless.
Jul 21, 2013 | Water Heaters
Manual
Copy following link for Rheem tankless troubleshoot resources, including error codes, manuals, and general information for maintaining your tankless computer that heats water.
Multiple error codes can indicate failed PC board. Rheem will send PC board... so your computer-that-heats-water might have failed motherboard.
Continual maintenance can help avoid common error codes, but some problems are insoluble and chronic.
Jul 16, 2013 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
Rheem Pronto water heater Error code E1
Before calling service technician, open following link for troubleshoot resources include Rheem chat, error codes, and regular maintenance manual, and possible product manual:
http://waterheatertimer.org/pdf/Tankless-maintenance.pdf
Clean the water filter as shown in product manual.
Error E1 is not specifically shown for Rheem/Pronto tankless.
1 is usually related to water flow.
E errors are related to temperature, so E1 can be temperature sensor failure on hot water pipe.
E errors can be loose/bad wiring or part failure.
Error codes are considered start-point for troubleshoot.
Each tankless manual recommends cleaning the water filter monthly, deliming heat exchanger yearly, and cleaning combustion chamber and burner parts yearly.
Regular maintenance can prevent most common error codes, but the cost and nuisance will outweigh expected $1-8 monthly savings on gas bill.
The requirement for continual maintenance should signal folks that tankless are not effortless hot water as described in tankless promotion.
Solve most tankless problems same day, yourself, any brand, using minimal tools for about $350.
Oct 02, 2011 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Indoor tankless 74-pvn. power went off and has returned. get error code 24 when try to power on
Open following links for Rheem troubleshooting resources, including Rheem chat, error codes, and possible manual.
Error code 24 is malfunction of operational switch: press max or min button on PC board to reset, -or- replace PC board.
Max-min button is sometimes located above dip switches, and can be 1 button that is rotated with screwdriver or 2 separate buttons. Look at wiring diagram in manual that came with product.
Fix most tankless problems yourself, same day, for $330.
Aug 14, 2011 | Rheem Tankless Hot Water Heater...
I am getting a 13 error code . jim B.
Before calling service technician, open following links for troubleshooting resources including Rheem chat and typical manuals:
http://waterheatertimer.org/pdf/Error-code-13.pdf
All gas water heaters require periodic maintenance.
Tankless recommend yearly maintenance.
Typical maintenance would cover most the causes for error 13, plus causes for most other common error codes.
Jul 19, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Rheem Tankless Hot Water Heater Rtg-74pvp-2 7.4 Gpm Logo
1,479 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
