Question about Saws
Owned this bandsaw since 2000. Unable to get the blade support bearing over far enough to keep the blade from running off the blade wheels when attempting to saw.
  • 10,319 Answers
What make and model bandsaw is it? that information is needed
Posted on May 16, 2010
I am unable to remove blade
Make sure you clean the knob adjustments on your bandsaw. Sawdust buildup would cause stiffness of the knobs. Look for a manual online and follow the instructions on installing band saw blade.
Jun 29, 2014 | Ridgid Ryobi Bs901 Band Saw Replacement...
Ryobi 902 bandsaw makes high pitch noise. have adjusted all guides and thrust bearing
The noise might not be coming from the blade, but perhaps from the bearings on the top or bottom wheel. Unplug it and open the covers. With the blade still on, turn the wheels by hand to see if you still get the noise. Then remove the blade and turn the wheels independently by hand. Then plug it back in and run the motor (with the blade still off!). Of course with the blade still off, the load on the wheel bearings will be very light, so maybe you can provide a bit of load by pressing a wheel or or caster against them as you turn them. Be careful. Good luck!
Oct 24, 2012 | Ryobi 9 in. Benchtop Band Saw
Bandsaw blades keep popping off,could it be heat related?
Blades slip off the wheels on these saws is because one or both wheels are not turning true to the blade. This can be caused by:
- Missing or worn tires on the wheels. The rubber tires have to be on the wheels and they have to be in good condition.
- Occasionally the screws holding the sprocket on the driven wheel come loose and the wheel will wobble causing the blade to come off.
- Both wheels ride on bearings and shafts that, if seized, worn or broken, will let the wheel wobble enough that the blade won't stay on.
- If the blade is stretched or twisted from use it won't stay on very well.
Aug 06, 2012 | Dewalt DWM120 Heavy Duty Variable Speed...
Tire comes off top wheel almost all the time. Tire comes off bottem wheel sometimes. Don't know how to set up this saw.
My jet bandsaw did same thing only fix was new tires .Tires are supposed to be tite on wheel .get wood dowels between tire and wheel and roll new tire onto wheel. If desperate could glue on with weather strip adhesive.put bandsaw blade on both tires spin wheels with power off till blade is running in center of wheel by adjusting top wheel in or out. When done adjust blade guides to blade and bearings to back of blade .This is top and bottom of cutting area
Jan 16, 2011 | Delta Woodworking Delta Rockwell 14 Inch...
Need a manual for a sears/craftsman model #103.24300 bandsaw
Any particular reason? If general settings problem, please follow this advice:
Brand of bandsaw is of no importance, problem is... I assume that problem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
I love bandsaws, they are one of best and most universal woodworking machines, used as well in food and metal industries.
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is housed driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
Switch machine off and remove power plug from the socket.
Start with tension, open covers, retract top (above the table) and bottom (below the table) guides so blade is not touching the rear bearing or side slides.
1. rotate top wheel and see where blade is wandering, regulate tension and tilt on the wheel till band position itself on the centre of the top wheel, is rotating freely without wandering, and cuttin edge is off the wheel or rubber and do not touch the wheel or raiser.
2. cut strip of paper and slide top guide towards the blade till bearing touch blade through the paper (paper thickness is about correct distance of bearing to the blade), allowing paper to be slided out without tension. lock bearing guide in.
3. insert paper on internal side of the blade and slide internal slide guide block till you can only pull the paper out, lock the slider.
4. repeat previous (3) operation on external guide block and after you slide paper out, lock it in position as well.
5. manually rotate the tension wheel, should operate freely, without wandering, without touching bearing or side slides.
6. repeat step 2 to 5 on the bottom guide
7. close the covers
8. adjust hight of the top guide suitable to cut , allowing about 2 finger breaths above the cut piece.
9. connect power, switch on the bandsaw and switch off, after it stop, check for tension, switch on and make test cut.
This general rule applies to all bandsaw, regardless of brand, make, vintage. Do remember that this is not a toy, it will cut through, wood, metal and your fingers...
Do remember, that these operations must be performed every time when you change the blade, do not forget to use bit of silicone or teflon spray if you cut very sappy or green wood, do not press and force, allow blade to slide and cut, use protection screen and googles, you have only two eyes and there are no spares...
If you have problem with your bandsaw, not related to adjustments, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 15, 2010 | Craftsman Saws
Sorry as i have extremely little amount of info on this machine (not mine ) i said i would fix it for her it is a 3 wheeled machiene made by rexon i asked for the model & was told all she could find...
Brand of bandsaw is of no importance, problem is... You did not stated what is exactly the problem, I assume therefore tha tproblem is with regulation of the blade motion. Please follow these instructions, I posted them previously for another member, they apply to any bandsaw in existence, regardless of brand, manufacture, age or look...
Now, what you should know about bandsaw that it have several points of regulations and all of them must be adjusted correctly. Basic "anatomy" of bandsaw is that it have body, in it there is driving wheel (bottom) and tension wheel (top), both of these are protected by rubber "tyre" usually crowned, that allow for better self adjustment and protect teeth on the band.
7. close the covers
If you still have some trouble with your bandsaw, please do not hesitate to ask further questions, let us know how you get along with this info.
Aug 13, 2010 | Saws
I have a 12" Sears - Craftsman - Band Saw and the blade keeps coming off. How do I install a new blade and keep it on?
Two potential issues here:
a.) You probably need to align your bandsaw wheels. Here's a link to a craftsman 12" bandsaw manual. Assuming you have model 113243310, 113243311, 113243300, or a similar model, read over page 12-14 "Installing the blade". Specifically, look at section 10 about adjusting the tracking.
Having the blade guides set properly is important too. A thrust bearing (the one up top, behind the blade) that's set too far forward can push the blade off the wheels too.
b.) If it's flat out too loose and you can't get it tight, the blade might be too long. It's worth double checking your manual to confirm you are supposed to be using an 80" blade and double checking the blade package to make sure you actually have an 80" blade.
Jun 14, 2010 | Craftsman 12 x 80" Band Saw Blade 6 tpi...
Bandsaw blade keeps coming off the wheels. What
ALL BAND SAWS HAVE AN ADJUSTMENT FOR THE BLADE TRAVEL WHEN I WOULD REPLACE MINE I WOULD ROTATE THE TOP WHEEL BY HAND TO CHECK THE ALIGNMENTAND WATCH WEHICH WAY THE BLADE STARTS TO TRAVEL THERE SHOULD BE AN ADJUSTMENT ON THE TOP WHEEL THAT TILTS THE WHEEL IN OR OUT JUST A TINY TURN WILL MAKE A BIG CHANGE
Aug 22, 2009 | Craftsman Saws
Grizzly bandsaw cannot fit blade
I lowered the spacer (on the threaded rod) and got enough drop in the upper wheel to fit the blade.
Jan 11, 2009 | Saws
Saws Logo
119 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
