Question about Hoover 24 in. DT999 Free-Standing Dishwasher
Hoover dt999 hi i am andy and my dishwasher starts a cycle gets a few minutes in flashes up E4 stops cycle and beeps,, no manual so no idea please HELP!!!! cheers andy
  • Richard Mallinson Apr 17, 2008
    Same model same problem. Had the Issue before and it goes away after a few days.
    Checked hose etc all clear, it generally happens after a E3 message (filter blocked) first time. I suspect there is a water sensor thats tripped by the rising water after the filter block. Takes time to reset (possibly due to evaporation).
    If I knew where it was located I would give it a go but dont.
    Hoover services will seng an engineer out to reset it (at cost) but will not supply a solution beyond that.
    Problem Solver:
  • 10 Answers
E4 Error on other machines (eg. Baumatic) means that the bottom catch tray (condensate trap) below the machine has too much water in it. This condensate is supposed to evaporate away, but too much will mean it builds up over a period of time. There is a float that trips a microswitch in my Baumatic which detects this, it only needs 2 - 3mm of water before the microswitch is activated.
If this is the problem with your machine (try it annd see), there are several solutions posted in forums - best seems to be to remove plastic access hole caps from base and mop out the tray with sponge. TURN OFF AT MAINS BEFORE POKING AROUND INSIDE THE BASE. May have to repeat at regular intervals to.
What causes it ? - I think it is excess condensate from steam inside the wash cabinet, follow the manufacturers advice to open the door as soon as the wash cycle has ended to release as much steam as possible to stop it condensing inside the machine.
Peramnent solution ? - I don't think possible - My guess is it's just a bad design.
Dave
Posted on Oct 04, 2008
E4 means that water is not discharging properly, check the hose, filters etc
Posted on Apr 02, 2008
SOURCE:
Why does my Fisher and Paykel DD605SS stall part way through wash cycle?
I'm not sure of this, because the manual does not have an error with a E. I can fine error F4. It says it encountered a faulty temperature sensor or element. If the heating element burned through the night you circuit breaker tripped (Sure it was not the ground fault circuit breaker?), then the dish washer can't heat the water, so the program can't continue. The program stops (waits) till the chosen temp is reached. If the water stays cold the program can't go on.
So also check the heater in the machine. I hope you are aware everything in the machine runs on high (or at least dangerous) voltages, so be careful not to work in the machine when it is still connected.
Jun 15, 2014 | Fisher and Paykel Dishwashers
Hi, we have a Hoover HEDS668-80 dishwasher at work. The first problem we had was none of the programs would run this turned out to be a broken door lock. After replacement we managed to get one pre wash...
Hello... Did you check the water inlet pump is turning on to let water go inside the machine? I think if you starts a cycle and feels no water in machine it stops and give error... Hope that will be faulty or before that I'm pretty sure you forgot to open the water inlet valve because you recently repair ?? please check
Sep 21, 2017 | LG LDF6810 Built-in Dishwasher
What does E4 mean on a Hoover DT999
Hi well check the following 1.discharge hose is not bent. 2.Filters are not blocked. 3.Syphon is not blocked
Thanks! mannu_rakesh
Aug 13, 2009 | Hoover 24 in. DT999 Free-Standing...
Error 4
check out the following link... i think it will be useful for u...
http://www.fixya.com/support/t1213494-dishwasher_flashing_error_code
thank you good luck
Jun 02, 2009 | Hoover 24 in. HD98E Built-in Dishwasher
Our Hoover HD98E Dishwasher stopped working properly today. After a while the machine stops during the power spray cycle and just buzzes as though the pump is powered but not spraying. Is this the pressure...
its possible that your timer has a bad contack at this spot the machine stops but the drain valves open try advancing the timer one notch to see if it will work if yes relace the timer thanks from gilles
Mar 14, 2009 | Hoover 24 in. DT999 Free-Standing...
Hoover dt999
check the ellement the ellement is normally used at the end of rinse foe sanitising the dish maybe shorting out at the connection below remove bottom pane obsrv it ewhen in the area where it happens to see if no drips fall on the conection or short a t te connecters of the ellement thanks from gilles
Sep 07, 2008 | Hoover 24 in. DT999 Free-Standing...
DEC Dishwasher
I have a manual if you still would like a copy
Apr 04, 2008 | Dishwashers
Hoover dishwasher error codes
Hi we have a Hoover DT999 and according to the manual for that machine error E1 is water inlet tap turned off
Dec 18, 2007 | Dishwashers
Hoover Whisper HD97E
Try checking the water level, and level switch? Is the outlet hose high enough of the floor? If you tip the machine back you should see one or two clear plastic tubes, take one end of these and blow through them and the do it the other way round.
Nov 26, 2007 | Hoover 24 in. DT999 Free-Standing...
Hoover 24 in. DT999 Free-Standing Dishwasher Logo
881 people viewed this question
Top Hoover Dishwashers Experts
Philip Postlethwaite
Vitally Alcher
Are you a Hoover Dishwasher Expert? Answer questions, earn points and help others
