Question about Acer AL1716 17" LCD Monitor
What is the screen resolution for acer al1716 monitor
Hold the power button down for at least 10 seconds till the light goes out, then turn it on and the problem is gone.
Posted on Jun 03, 2010
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Acer Master
  • 848 Answers
What is the screen resolution for acer al1716 monitor? This trouble maybe power supply or inverter boards is defective.
first you can test the voltage of the multr,and then check which part is defective.From Wisiny.com can find those parts
if you have any question,please let us know email:service@wisiny.com.thanks,we sincerely hope we can help you!
you can also check this boards whether suit you:
490401400100R ILPI 003 Acer 790401401600R Power Supply Backlight Inverter
Posted on Dec 01, 2014
    Problem Solver:
  • 15 Answers
If you google the model number, you should come across a review of it and that should give the resolution.
Search the acer web site for that model and you should get the specs.
Posted on May 16, 2010
tantong
  • 138 Answers
SOURCE: ACER AL1716 LCD MONITOR
I used to repair LCD monitor from Dell. It works for me. You might be using these following steps to examine what wrong with your monitor. After you turned PC on and monitor stopped working or went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image (Start menu), there will be a minor problem. This is because of CCFL lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 18, 2008
Fix-4U
  • 293 Answers
SOURCE: Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Posted on Dec 18, 2008
MC707
  • 16 Answers
SOURCE: Acer AL1716 monitor
First of all check your monitor's color configurations using the buttons in the monitor. Then, if colors are set to default, go to your GPU's control panel, usually found by right clicking your desktop and finding an option that says ie. Nvidia control panel. Go to video control settings and/or desktop color settings and either restore defaults or configure them yourself if you know what you are doing. Hope that helps.
Posted on Jun 11, 2009
romsky79
  • 822 Answers
SOURCE: Mine is Acer AL1716 and doesn't display anything,
this kind of problem is very common to acer due to hot pessure inside some of capacitor become budged. pls check the secondary power supply.
Posted on Jun 25, 2009
SOURCE: Screen resolution for Acer P221W
1680x1050.
It also depends on the video card how high the resolution can go.
That's the max resolution though.
Here's the complete specs for your monitor.
Have a good day!
Posted on Jul 19, 2009
Slow monitor
Check the video/display settings in your OS.
System Preferences in mac os
Screen resolution in windows.
Use recommended settings.
Mar 26, 2014 | Acer AL1716 17" LCD Monitor
My screen resolution wont go back to 1920 x 1080 what do i do?
on the desktop screen do a right click
you will be getting a drop down box
there select screen resolution
you will get a screen opened
there you can find an option as resolution
you can chage the resolution of your screen there
Dec 12, 2010 | Acer AL1716 F Monitor
Will an Acer AL1716 monitor work with a Dell 4600? Do I need a monitor card?
http://reviews.cnet.com/desktops/dell-dimension-4600-for/1707-3118_7-30529709.html
It has video card already, just make sure the video card driver is correct. Mkae sure to set the PC video resolution to the native resolution of this Acer, which is 1280 x 1024 @60Hz.
http://s807.photobucket.com/home/budm/allalbums
May 10, 2010 | Acer AL1716 17" LCD Monitor
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
You should have no problem connecting the monitor to the VGA port of the Dell that is already comes with the computer, just make sure to set the video output resolution to be at native resolution of the monitor, which is 1280 x 1024 @60Hz.
Mar 18, 2010 | Acer AL1716 17" LCD Monitor
Al1716 monitor plugged unable to change resolution.
You need to set the PC resolution to the native resolution of this ACER monitor, which is 1280x1024 @ 60Hz.
Mar 10, 2010 | Acer AL1716 F Monitor
17 in monitor
Set the resolution to match the new screen.
In XP, Go to control panel, display, settings tab and change the screen resoution slider. If you have a regular shape screen (not widescreen) choose 1280 by 1024 pixels. If yours is a widescreen, choose 1280 by 768 pixels.
Feb 20, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1716 17" LCD Monitor Logo
439 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
