Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My craftsman door opener light doesn't work I replaced the light bulb and still doesn't work tried pulling out the centre socket contact to no avail.
    President:
  • 3,197 Answers
You have done all you can do if you are using a standard bulb. The light is controlled by a small relay on the logic board and that is probably bad.
Posted on May 17, 2010
I have a craftsman 1\2 HP garage door opener, made in '97. It only closes with the two remotes and the outside keypad but doesn't open. I can only open it with the inside console. Also the light is...
There is an antenna extender kit available from Sears or Chamberlain dealers that may help you. The part number is 41A3504.
You can try this for your light problem. Unplug the opener and remove the light bulb. Use a small screwdriver to pry out on the center contact in the socket. Replace the bulb and plug it in. Use only a regular incandescent bulb. Some others will not fit in the socket properly.
Sep 13, 2011 | Sears Craftsman LiftMaster Chamberlain...
I had a LiftMaster model 2000SDR. remote won't work when light is still on. Only wall control can operate garage door. Once lift is off, then remote control work. How to fix this problem?
Remove the bulb and try. The bulb or the socket may be radiating a signal. Unplug the opener and pull out on the center contact of the light socket. Try another bulb.
Feb 06, 2011 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster 1/2 hp professional, all functions work except for lights, i have unplugged and replugged in, bulbs are new, contacts good. Any suggestions?
Unplug the opener and remove the bulb. Using a small screwdriver pull out on the center contact in the socket. Replace the bulb and plug in the opener.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Put new battery in key pad will open door,then light will say on and key pad will not work.
Remove the bulb from the socket and try. You may have arcing in the bulb or socket that is interfering with your receiver. Unplug the opener from the wall and use a small screwdriver to pull out on the center contact of the socket. Replace the bulb and plug in the opener.
Garage door opener Model 139.53515SR overhead lights stopped working. Checked bulbs and all connections. All seems O K. What could be the problem? When I tap the unit ,at times the lights will flicker like...
Unplug the openers and remove the bulbs. Using a small screwdriver pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Nov 04, 2010 | Sears Craftsman LiftMaster Chamberlain...
Lights do not work on the garage door opener. what could be the problem?
Unplug the opener and remove the light bulb. Pull out on the center contact in the light socket. Replace the bulb and plug in the opener.
Jun 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
The light on my Chamberlain garage door opener does not work. I replaced the fixture that the bulb screws into but it still does not work.
Try unplugging the opener, removing the bulb and pulling out on the center contact in the socket with a small screwdriver.
Apr 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
Light will not function. Replaced light bulb but
Unplug the unit and then using a small screwdriver pull out on the center contact in the light socket.
Mar 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
The light in my Craftsman garage door opener does not work. I have replaced the bulb and it still will not go on.
Unplug the opener and using a small screwdriver pull out on the center contact of the light socket.
Sep 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,097 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
