Excel I want to add up some numbers but I only want them to be included if I have put a letter like let say c for cash in the column next to the number is this possible or how can I do it?
  • 242 Answers
Use IF statement:
IF(A2 = "c",action if true, action if false)
wherein A2 is the column which could contain the letter c for cash
Posted on Mar 30, 2008
IS THERE A FORMULA IN EXCEL THAT WILL HIGHLIGHT CELLS THAT MATCH A NUMERICAL INVENTORY LIST?
One way would be to create a colunn C and use the formula: =COUNTIF(B$2:B$200,A2) in cell C2. Then copy the formula down to C200. (assuming you have 200 entries in B...). This will put a "1" next to every number in Column A that has a match in column B. Then you could put a conditional formula in column A that will highlight the cell if the value in column C is equal to 1. Alternatively you could also simply filter for 1's in column C and then manually highlight the cells that show up in A!
Sep 16, 2014 | Microsoft Excel for PC
I have a column containing a value of a single letter. I need the spreadsheet to sort add rows by letter.
Move the column to A. Mark entire sheet and sort ascending. There are more raffined ways to do this, but this is an easy quick fix...
Sep 07, 2014 | Microsoft Excel for PC
Describe the each part of microsoft excel 2207
Parts of the Excel 2007 Screen
Active Cell In an Excel 2007 worksheet, the cell with the black outline. Data is always entered into the active cell.
Column Letter Columns run vertically on a worksheet and each one is identified by a letter in the column header.
Formula Bar Located above the worksheet, this area displays the contents of the active cell. It can also be used for entering or editing data and formulas.
Name Box Located next to the formula bar, the Name Box displays the cell reference or the name of the active cell.
Row Number Rows run horizontally in an Excel 2007 worksheet and are identified by a number in therow header.
Sheet Tab Switching between worksheets in an Excel 2007 file is done by clicking on the sheet tab at the bottom of the screen.
Quick Access Toolbar This customizable toolbar allows you to add frequently used commands. Click on the down arrow at the end of the toolbar to display the toolbar's options.
Office Button Clicking on the Office Button displays a drop down menu containing a number of options, such as open, save, and print. The options in the Office Button menu are very similar to those found under the File menu in previous versions of Excel.
Ribbon The Ribbon is the strip of buttons and icons located above the work area in Excel 2007. The Ribbon replaces the menus and toolbars found in earlier versions of Excel.
Here are the main parts of Microsoft Excel 2007. Thank you for using Fixya !!!
Nov 15, 2010 | Microsoft Windows XP Professional
I want to find out what is meaning of cell in microsoft excel 2007 windows.
The rectangular box identified by a unique letter - number combination. You would type your number or text into this box.
A cell is the intersection of one row and one column. (EXAMPLE: A1, which refers to the cell made by the intersection of Column A and row 1.)
Nov 09, 2010 | Microsoft Office Excel 2007 Upgrade:...
How to get all balance sheet entries tally to excel
This is a very handy process when you're totaling or subtotaling columns. On the cell that you want the 'total' in type '=sum(column letter row number),(column letter row number). The first 'column letter row number' is where you want the first cell to be started in the total factor and the second 'column letter row number) is the last cell you want added in the total factor. The help (?) section is good at explaining formulas. Hope this helps, keep this process handy if you use Excel much because it'll be helpfull each time you subtotal or total columns.
Bob
Sep 23, 2009 | Computers & Internet
I need a running balance in a column for a petty cash spreadsheet
In the first row of numbers, assume row 3 for example (leaving 2 rows for titles, put in cell E3: =C3+D3. In the next row (assuming row 4, put in cell E4: =C4+D4+E3. Use fill down to populate this formula all the way down.
Jun 18, 2009 | Microsoft Excel for PC
CAN GET COLUMNS TO ADD UP AND GIVE TOTAL ONLY GET SUBTOTALS
Use the function =sum() to add numbers. To sum, for example, all of column A, enter in the formula bar =sum($A:$A). You can use the subtotal function within the range you are adding and the answer will not count towards the final total.
Mar 14, 2009 | Microsoft Excel for PC
Input data
If you want to transfer your data into SAS, SPSS, or some other program, follow these guidelines:
The cells in Row 1 should contain the column's eventual data set name. Each name should be a relatively short and unique acronym that clearly identifies the data. It should begin with a letter and contain only letters, numbers, or an underscore ( _ ) where spaces would naturally fall. Avoid using special characters such as $, &, @, in variable names. Since each row represents the values from one subject, the first column(s) should contain one or more variables that give each subject a unique identifier. They become especially important if you need to merge two or more data files.
In Excel, data formats are defined for a range of cells rather than for a complete column. For this reason it is important that each entire column, including cells with missing or uncollected data, have one, and only one, format. Actually, you do not need to format the entire column, only the portion you will eventually use. Highlight that portion and select the appropriate format from the Format/Cells option. Do not select formats that will enter commas, dollar signs, or other visual enhancements. Numeric, text, and date formats (e.g. mm/dd/yy is often a good choice) are probably the only formats you'll ever need.
The "Split" option (under the "Window" pull-down menu) keeps the row of variable names and the columns of identifiers in view, whatever range of cells in the worksheet you may need to review. First place the cursor at the most extreme upper left-hand corner where data entry begins (e.g., the intersection of Row 2 and the column in the upper left-hand corner where data appear) and then select "Split" from this menu. For any row or column of the worksheet you move to, you'll know exactly which variables you are observing (column names) and their associated ID values (rows).
For versions of Excel later than 4.0, one file can contain multiple worksheets. By default, the tabs at the bottom of these sheets are supplied names ("sheet1," "sheet2," etc.). You can change these names by clicking this space with your mouse and entering a new name. Use the same conventions for first-row variable names: use a short acronym of the page contents that begins with a letter, use only letters or numbers, and enter the underscore ( _ ) where a space naturally falls.
Jan 05, 2009 | Sage Instant Accounts 8.0 (013604ug)
How to add % (Percentage column ) in the excel
The formula is 200/700 equals the percentage;if you're in columns a, b, and c, the formula in c1 will look like:
=b1/a1.
Then you can format the cell to show the number (.2857) as a percentage (28.57%).
Jan 03, 2009 | Microsoft Computers & Internet
Multiple letters in each cell, want to add the letters and tally how many of each
Use the =COUNTIF function
For example if column a has the letters in it:
=COUNTIF(a1:a100,"a")
or
@COUNTIF(a1..a100,"a")
This will count all of the letter 'a' s in
column a from row 1 to row 100.
Mike
Oct 31, 2007 | Microsoft Excel for PC
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
