Question about Admiral 26 cu. ft. Side-By-Side Refrigerator
Problem with fridge ice maker
We have a Admiral 26 cu ft side by side fridge and the ice maker will not make ice
  • 109 Answers
Assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
Posted on Mar 31, 2008
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Admiral 26 cu. ft. Side-By-Side Refrigerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 21, 2011
I have an admiral American fridge freezer. The ice maker is continuously leaking water if the power is switched on as though a switched on. How can I stop the water ?
To verify if its the valve or the ice maker the easiest way would be to unplug the machine and then turn the water on. If the water stops, then the ice maker is bad and is continuously applying power to the valve causing the flood problem and should be changed. If the water keeps on coming out then the valve is bad and stuck open and should be changed.
Jun 04, 2012 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator FRIDGE VENTS ICING
heatman101
Sep 21, 2011 | Admiral 26 cu. ft. Side-By-Side...
Ice maker is not working. it turn and make the turning but no ice is producing.
Hello. Check to see if any water is entering the ice cube mold. Most likely it is not and the cause is either a clogged filter, a clogged supply line, a kink in the 1/4 inch line that feeds the fridge, or a frozen valve that would normally open and close to let water into the ice maker. J.
Aug 07, 2010 | Admiral 26 cu. ft. Side-By-Side...
Ice maker stoped
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
yy
Sep 25, 2009 | Admiral 26 cu. ft. Side-By-Side...
Ice/Water dispenser not working correctly
hi,,
it is a thermostat problem,,because of it heating is not done properly ..u should replace or fix it,,it is not a big amount....
thank u,,,
Jul 01, 2009 | Admiral 26 cu. ft. Side-By-Side...
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
Admiral Ice maker water filter, which one?
I have an admiral HMG19149 refrgerator with an ice maker. my problem is that the ice tast horable and cant be used. I looked for a filter to change but can't find it. Please help
Jan 14, 2008 | Admiral 26 cu. ft. Side-By-Side...
Admiral Refrigerator makes hollow ice
Hollow ice cubes are due to low water pressure to the fridge. Water thru the door should have good pressure behind it. This is a good indicator of water pressure. Should be able to fill a glass quickly. Causes for low pressure are self-piercing saddle valves on the water line (switch to drill type (1/4") valve) or reverse osmosis system or filtering system on water line to the fridge. R.O. systems should not be used. Increase water pressure and that will fix the hollow cubes. The loud noise may be the sound of the water valve on the fridge when it is acivated. This sound is normal and some are louder than others.
Oct 05, 2007 | Admiral 26 cu. ft. Side-By-Side...
Admiral 26 cu. ft. Side-By-Side Refrigerator Logo
336 people viewed this question
Top Admiral Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you an Admiral Refrigerator Expert? Answer questions, earn points and help others
