Question about Asko Dryers
Asko W/D. Power to 220 wall outlet and washer
Asko W/D. Power to 220 wall outlet and washer plug on back of dryer, but dryer has no lights or power. Washer works fine.
  • June C.M. Jacobsen Mar 24, 2013
    Hello, just had similar problem with brand new ASKO model T712C dryer; washer works but dryer has no power. On back top left in junction box near 220V terminals is printed "control fuse" but can't find opening to access the fuse. We can call for warranty service but thought there might be a quicker solution. Thanks!
  • Asko Master
  • 2,605 Answers
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Posted on May 16, 2010
My Asko T7781c dryer programme panel is dead. The mains switch turns on but nothing else functions. There is no reset button ; the dryer did not reset itself. A new circuit board at $300+ ?
On the back of the dryer, there should be two fuses in black or grey holders. Should be round knurrled caps or slotted holders. Check these. The fuse holders could also be overheated and burnt.
Is your dryer plugged into the washer for power? Or directly into a outlet in the wall.
Jun 22, 2016 | Asko Dryers
DDE7608MALAD
Do you have t 220 at the wall. Check your wiring from the plug to the back of the dryer and then inside. I thnk your problem is there. Your relay may be out . It is under the top of the dryer.
Feb 28, 2013 | GE Dryers
ASKO 7000 series washer drum stopped rotating. Smelled of burning. Could not turn the drum by hand. Guessing a burned out bearing as electronics and pump still work and are trying to turn steel drum. ...
check inside your washer for nails or other objects . I already seen a nail fall down in one of the basket holes and the nail stuck into the outer tub not allowing the basket to spin. If you dont see anything in the basket holes, then it is your bearings. The burning smell is coming from your belt. The motor is spinning but your basket is not. It is cheaper to buy a new washer. In ordered to fix your washer you have to rebuild it. The bearing are built into the outer tub of the washer.
Jul 13, 2011 | Asko 8005 Front Load Washing Machine
My Asko Dryer has power coming into the main board but the unit is dead. Can there be any other problem other then the main board being bad?
The first thing I check is the electric plug at the wall outlet to make sure I have 220 volts you will need a electric test meter If you are not comfortable with this you need to get a licensed electrician, with a ohm meter you can check the limit switches and the door switch with the power off at the breaker. one of the 110 circuits run the motor the other the element.
Apr 16, 2010 | Dryers
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
207 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
