My tv set have a visual vertical line only but sound ok
  • 1,210 Answers
Your vertical IC may need resoldering or replaced. And replace any capacitor in the immediate area near your vertical IC . Good Luck and be very careful if you decide to fix it yourself!
Posted on May 16, 2010
  • matt martin
    matt martin May 16, 2010
    One more tip. The vertical line may be another bad ground in another area of the TV. So please check the powersupply for any grounds that may need resoldering.
Sony bravia KDL-50W800B got only vertical lines when turn on.
You need to take it to a TV repair service, preferably one that specialises in Sony TV's. There is nothing you can do to fix this yourself.
Jun 16, 2016 | Sony Televison & Video
Vertical line on tv screen
This problem have been answered.
Aug 22, 2012 | RCA TruFlat 27F520T 27" TV
I was on the inside of the tv trying to adjust the color and now a line comes down the screen. How do I remove it?
well if you are inside you would be famous or dead
jokes apart you may have switched the switch to adjust mode or vertical as you usually do this to check if the tv is ok and to install video
you do this in video to make sure it is ok and tuned to tv set
restep what tou have done and undo this you will locate the switch
if it continues than you will have to readjust tv set and reprogram it
not sure if line is black and without visual or with oicture on as you did not state this
Sep 27, 2009 | Philips 50P8341 50" Rear Projection...
Vertical line down the center, sound OK.
This is the deal. Your picture tube is going out. How thick is the line. As it gets wider that will tell you how much more time you have. Was the TV dropped? There is a way to adjust this but you have to get into the back of the TV and if the static discharge is not done properly it will kill you. Don't mess with it. It is now cheaper to buy another TV on craigslist or your local paper than trying to repair it. Hope this helps.
JimmyC
Sep 25, 2009 | Televison & Video
H line problem
I think you are describing 'no vertical deflection.' If all you have on the screen is a single horizontal line, the vertical deflection circuit (or IC) has died. Unless you have service documentation on hand, I can't give a part number to replace but this is typically not an expensive failure and if the set was OK before, it is worth having repaired.
Jul 05, 2009 | Sansui 27" TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
Vertical line in center
If the line is "vertical" then the vertical circuit sounds OK. The problem would be in the horizontal deflection.
Check yoke connection and solder around horz defl circuit.
If the line is horizontal then I would suspect the vertical IC.
Apr 02, 2009 | Sanyo DS31520 31" TV
Sanyo DS27880 TV, vertical sweep is gone, sound ok
Check for cold joints on the vertical chip. DS27880 sets use a la7841 typically.
If soldering doesn't fix it, simply replace the vertical as well as the 1ohm 1/2W resistor and
the fast recovery general purpose (nte556 equiv) near the flyback.
Mar 24, 2009 | Sanyo Televison & Video
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Vertical fold over
if the set has a previous vertical line problem and a white horizental line only comes in the cross of the screen and you turned the tv on for a time while the problem is solved that mean you have make a burnt line to the screen , but if you are the tv owner and nothing of that happens so you have a problem in faulty dried capaciter in the vertical live part search for 33uf 160 v or 22u 160 v and alter regards please don't forget to rate thx
May 01, 2007 | Sony KV-32S45 32" TV
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
Electro Med Services...
