Question about Samsung HL-R4667W Rear Projection Television
Why is my screen showing a green color with multiple lines vertical and horizontal when I turn my set on ?
  • 1,476 Answers
Sounds like you have a bad optical engine. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the repair process and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 16, 2010
I have a Bravia KDL 40BX421 that suddenly has green vertical lines on the bottom 1/4 of the screen. These lines are in a background bar that is mostly a reddish shade.
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/.../1127410-thin-vertical-lines-cover-screen-samsun...
Mar 7, 2009 - 30 posts - ‎25 authors
Hi guys, Ive had this TV for about a year now - all of a sudden thin vertical lines havecovered my screen (show in link below) No matter what ...Missing: 40bx421
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... hi i have a sony bravia mdel # KDL46EX523. i have horizontal multi colored lines ... My TV has the following symptoms: - Horizontal lines from top to bottom of .... thick(like 1-1/12 inch) and a couple of green vertical lines next to the black one.Missing: kdl ‎40bx421
Flat Screen TV Has Lines Going Through Screen - Possible ...
Dec 16, 2015 | Televison & Video
Tip
How to set convergence on Projection TV ' s
I have given an general explanation on most projection TV ' s
  1. Enter the menu on your TV. Use the remote control and bring up the menu.
  2. Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  3. Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  4. Press "Enter." A crosshair pattern will appear on your screen.
  5. Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  6. Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  7. Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  8. Repeat these steps for all colors.
on Mar 18, 2010 | Televison & Video
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
LCD screen has black and red colrs + a green vertical line
Reset the video card, and if that doesn't work it sounds like the card is dying. How old is the card?
Apr 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
TV: vertical colored lines on TOSHIBA TV Model 36ZP46P
HAI,1.REPLACE SOME CAPICTORS IN HORIZONTAL SECTION.
       2.ADJUST FOCUS ON LOD(EHT TRANSFORMER).
       3.REPLACE HORIZONTAL OUTPUT TRANSISTOR.
Jul 05, 2008 | Televison & Video
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Jan 15, 2008 | JVC AV-48WP30 48" Rear Projection...
Green vertical line on the right side of screen
if someone found a solution for the verical line please post it. the laptop has never been hit and the vertical line just showed up there...
Nov 26, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Multiple vertical colored lines on DVD player screen
check this out http://www.techlore.com/forum/thread/12629/
Sep 26, 2006 | Audiovox D2010 Portable DVD Player with...
Samsung HL-R4667W Rear Projection Television Logo
152 people viewed this question
Jerry Greenberg
Jerry Greenberg
