Question about ViewSonic N2000 20 in. LCD HDTV
Blipping power Hi! I just got this TV and for some reason when I turn it on the light around the power button lights up for a few seconds and then the screens blips on for half a second and dies. It will do this every 7 or so seconds as long as it's switched on. Pushing any of the other buttons doesn't do anything and nothing else seems to respond. Any help or advise as to what is happening and if I could fix it would be much appreciated. Thanks! Sam
  • ViewSonic Master
  • 8,457 Answers
Ur tv power on the picture just show up only for a few sec. U still have sound?Yes,than ur LCD inverter board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
Posted on May 16, 2010
Testimonial: "Thanks for your quick response! Once I figure out how to disassemble the tv I'll take your advice. Thanks! "
Power light is red and flashing. when we press the power button it sounds like it's trying to power on the light turns to flashing green for a few seconds and then the power cuts off and turns back to...
Flashing red light in Sony tv indicates that tv got some internal problem and went on protection mode to avoid further damage. Now it needs service/ repair.
Blinking red light also has an error code that has info about possible cause of problem, let me know how many times red light is blinking after 3 seconds ling pause and model number of your tv to provide you helpful info.
Thanks.
Feb 23, 2011 | Sony KDS55A2000 55" HDTV
Hi, We have a 42" hslc10668phz
generally when you get a constant green light all is ok. these different lights indicate different problems within the tv. so the pattern of lights you mention suggests there is a fault of some kind (is there a troubleshooting section in your manual)? either way it needs to be looked at.
Nov 28, 2010 | Hisense Televison & Video
I have samsung lcd lnt4661 model. I had problem with my tv now. when i turn it on after 2 seconds the backlight will turn off which give no picture but there is sound.
There are two possibilities for back light off after 2 seconds.
One reason is back light inverter boards got defective for some reason (this tv has 2 back light inverter boards on either sides) and second possible cause is power supply is not giving out sufficient voltage supply to back light board.
Let me know your expertise level to provide you more technical info.
Thanks.
Aug 03, 2010 | Televison & Video
My Loewe Aconda TV will not turn on - buzzing noise.
My Loewe Aconda 81 HDR TV will not turn on. When I press the power button the green light comes on but the red light stays on with it and after a few seconds the green light goes out and the red light stays on. Any help please.
May 15, 2010 | Loewe Aconda ACO9383 38" TV
Timer light blinks constantly
Is it Mitsubishi WD-52628 TV? please confirm model number.
Unplug TV from AC outlet for couple of minutes, replug back in, turn power ON and check, still same problem?
Lets read error code in TV, press Device and Menu buttons on front of TV at same time for 6 seconds that will activate error code read process. Led will flash in 2 sequence with half second pause. count it and let me know the error code to proceed.
Thanks.
Jun 29, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
ViewSonic N2000 20 in. LCD HDTV Logo
75 people viewed this question
Top ViewSonic Televison & Video Experts
Jaime Hernandez
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
