Question about Kenmore HE2 Plus Front Load Washer
The water doesn't drain Clothes are still wet after the washing cycle
  • 1,998 Answers
Check the pump its located at the bottom of the machine remove the panel if your handy electicaly use a power jumper wire to test your old pump you can order a new pump from marcone or allbrands appliance they will mail one directly to you
Posted on May 16, 2010
Lsw9750pw3 clothes still wet
If there is water remaining after the drain then the drain pump must be checked. Also check the TILT of the washer and must be inclined to the drain side.
If the clothes are wet then the SPIN RPM is insufficient or the program cycle time is not adequate. Please try with another cycle or check the motor, belt, capacitor as the RPM is low.
Jun 28, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not spin at all no code . will drain and tumble back and forth,when it comes time to spin it turns off.
A washing machine is basically a big tub that repeatedly fills with water and then drains, spins to wring clothes dry, and has a device for stirring things up-- either an agitator in the middle of a top-load machine or a rolling drum in the case of a front-loader.
The four cycles that every washer performs are fill, wash, drain, and spin. Though these functions are pretty basic, a number of things can go wrong with them.
There are a number of problems that you can fix quite simply; some issues, however, are better left in the hands of an appliance repairperson.Problems that commonly occur with a clothes washer are discussed in depth below.If your washer doesn't run, be sure it's plugged in and that the receptacle works (the circuit hasn't overloaded). Before working on the washing machine, be sure to unplug it.
To prevent problems, follow good maintenance procedures. Use the right amount of detergent for your washer and your water hardness, make sure the machine is level, and don't overload it for the cycle chosen.
Washing Machine Does Not Fill
If the washer doesn't fill, the water inlet screens may be blocked. Clean or replace them. (Check your owner's manual for the location of the screens; they're often located at one end of the supply hoses, or you may have to remove a panel to access them.) Other reasons for not filling may be that either the timer or temperature selector is broken--both of these are repairs for an appliance repairperson.
Washer Does Not Spin
If your washer doesn't spin, check to see if the clothes have jammed or are unbalanced in the drum before calling a repairperson. Unbalanced clothes will also cause a w
asher to shudder or "walk." If straightening out the load doesn't stop the washer from shaking, look at the feet underneath and be sure they are properly adjusted to keep the washer sitting level on the floor (you just turn them to move them up or down).
Clothes Are Wet After Spin Cycle
If your clothes remain wet after your washer's spin cycle, perform the following diagnostics:
1) Lift the lid during the spin cycle. If the tub is not spinning, you may have a damaged motor coupler. Call a repairperson to replace this part.
2) If the tub is spinning, recheck the load to make sure it is balanced. If you are certain the load is balanced but your clothes are still wet, you may need to call a repairperson to replace a damaged motor pulley, tub bearing, belt, or clutch.
3) You can also follow the troubleshooting steps outlined in "Washing Machine Doesn't Drain." You may have a problem with your drain hose or pump.
Oct 27, 2011 | Washing Machines
Why is it that my washer is not completing the spin cycle,it is still very wet when it stop??
Hello there and welcome to fixya
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these: Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Sep 12, 2011 | GE Washing Machines
HI: My washer will not drain all the water out at the end of the wash can you help me out
Hello there and thank you for choosing fixya
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician. Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess. Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Aug 04, 2011 | Frigidaire Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
Washer is completing all cycles, but water from wash cycle.is left.in washer and clothes are still soaking wet. No water drains out.
check the Lid safety switch, if its shorted the spin cycle won't work, so your left with wet clothes ,, you can jumper the 2 wires together to test the switch , if that makes the cycle work, Replace that switch
Jul 06, 2011 | Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
Clothes wet after spin
Hi, if clothes are wet after spinning, check.......
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning: If it's spinning when you lift the lid, the coupler is fine. If it isn't spinning--and your machine was produced by Whirlpool you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag), a worn clutch (GE/Hotpoint), or a worn motor pulley or tub bearing. Replace the applicable component. Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Apr 13, 2011 | Whirlpool LSR8433K Top Load Washer
Clothes are wet at end of spin cycle
Dear Customer
Please perform the following
Clothes are too wet after spin cycle:
This may be a spin problem or a drain problem
Drain:
  • Make sure the drain line is clear
  • Check the drain hose for a partial blockage
  • Inspect the water pump
Spin:
  • Test the lid switch
  • Test the timer control
  • Test the centrifugal switch
  • Test the water level switch
  • Inspect the motor coupler
  • Inspect the drive belt (belt drive only)
  • Inspect under the washer for soot (clutch)
  • Test the motor
  • Inspect the pulley
  • Test the transmission
Please rate this,Thank u
Dec 17, 2008 | Maytag Washing Machines
Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
Nov 09, 2007 | Admiral AAV7000A
Kenmore HE2 Plus Front Load Washer Logo
94 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
