Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
Tells me ink needs replaced even after putting in new ink.
After i put in a new color ink cartridge it still tells me the ink cartridge needs replaced, i have took out the printhead and cleaned it but that did not help, it has even said on the screen when i turn it on new printhead detected, needs calibration, did that twice and it still tells me my ink is low with a new ink cartridge.
  • 22 Answers
Check your new ink catridge and look for a mini green electronic chip if that is damaged the printer shouldn`t recognize the catridge
Posted on May 16, 2010
Hp 2410 psc all in one has all lights blinking does this indicate that I neeed new cartridge It tells me to remove the right cartridge and then replace it
yes maybe it require to replace the cartridge, but before doing it pls insert the cartridge one by one, i mean put the black ink then observe if the light stop blinking,if yes then the color ink need to replace
Oct 27, 2011 | HP PSC 2410 All-In-One InkJet Printer
Printer does not recognize new ink cartridge
Are you using "refilled" hp cartridges? If so, they may be interpreted as "empty" or a non-hp cartridge if the carrtidge shell was manufactured prior to the recent time that hp began coding the electrics on the same type cartridges. This can also happen if you are using "compatibles". If this is the case, try buying original new hp carts. If that is what you already have, return the cart to the store as defective and as for a replacement.
Apr 28, 2010 | HP Photosmart 3210 Printer
Put new cartridge in but still says low
First off, make sure none of the color cartridges are also low. Then run whatever print utilities came with the printer. I believe you should be looking for the "printer maintenance" feature.
Feb 06, 2010 | HP PSC 2110 All-In-One InkJet Printer
Replaced black ink cartridge and printer keeps asking to replace
The message that persists in saying to "replace black cartridge" could be due to a defective cartridge chip. The chip maintains counts and tells the printer when a new cartridge is installed. If you cartridge is remanufactured, they may have neglected to install a new chip.
Regarding the new fuser not working, I'll have to get back to you on that.
Oct 15, 2009 | HP LaserJet 4600dn Color Printer
Tells me ink cartridges are empty, even after putting new ones in. please help
Hello there,
In this case you need to please remove the new cartridges and place the old one in back and check if they are getting detected then it clearly shows that the problem is with the new cartridges. If the same persists with the old one then try ckeaning the circuit portion which is on the cartridge and the printer. and then check for the same else carrier stall needs to be replaced. Thanks and all the best
Aug 08, 2009 | Lexmark P4350 All-In-One InkJet Printer
Color ink cartridge
hi, if your printer is telling you that you stillhave to replace the cart even if you have just replaced it with a new one, it might be that the one you are installing is defective. you can try installing a different cart. if this issues persist, then i suggest you contck kodak's tech support hotline 800.421.6699
Oct 23, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Print cartridges
  1. When one or more ink cartridges are empty, for example, Black, the LCD shows “Ink Empty Black” and “Open Cover.” Close the printer’s document support and the document tray.
  2. Lift the top cover to the open position until it locks securely into place.
  3. Pull the ink cartridge hook toward the front of the printer and remove the color ink cartridge displayed on the LCD. Place the cartridge in a plastic bag as it may still contain some residual ink and may leak.
  4. Open the new ink cartridge bag for the color shown on the LCD and remove the new ink cartridge. The cartridge cover may come off when you open the bag. This is not uncommon and will not damage the cartridge.
  5. Each color has its own correct position that is clearly labeled and color coded inside the printer. Keep the ink cartridge in an upright position when you insert it into slot. It will only fit in the correct direction. Press down on the ink cartridge until the hook snaps over it.
  6. If you replaced an ink cartridge while “Near Empty” was displayed on the LCD, the LCD may ask you to verify that the replacement cartridge was brand new one. Example: “Did You Change Black? 1.Yes 2.No.” For each new cartridge you installed, press 1 on the dial pad to automatically reset the ink dot counter for that color. If the ink cartridge you installed is not a brand-new one, select 2.
Sep 16, 2008 | Brother MFC-5840CN All-In-One InkJet...
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
Cartridge alignment
It seems a problem with the carriage of the printer
printer needs to be replaced
Apr 21, 2008 | HP OfficeJet 6110 All-In-One InkJet...
My Hp does not recognize my color cartridge?
Sometimes the color bleeds over. Did you wipe down the contacts and clean the heads? Also, most of the cartridges have low ink sensors in the. Even if you have them refilled, they will still show as low ink. The only solution is to buy the new ones.... $$$$$$.
Dec 12, 2007 | Dell 922 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
267 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
