Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Water I have a brand new house with all new appliances. I went to turn on my dishwasher and it comes on but no water. I turned on the valve under the sink but I still do do not get ant water... Please help.. Steve
    President:
  • GE Master
  • 2,651 Answers
Reach inside your d/w and jiggle the mushroom shaped float switch located on floor of d/w. should move freely up and down if its stuck up(or something lodged under it your unit wont fill with water
Posted on Apr 08, 2008
Diplomat ADP8322 Does not appear to load sufficient water thereby spray arms not rotaing
Hello there and thank you for choosing fixya
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you're not sure you've shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you'll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you'll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Aug 04, 2011 | Dishwashers
Dirty Dishes
If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Sep 28, 2008 | Whirlpool 24 in. GU1500XTLS Stainless...
Dishwasher is working fine however at the completion of the cycle and when it sits idle it seems to be flooding from under the filter area.Flooding is slow however but causes headaches when it breaches...
Your water fill valve is slowly leaking water into your dishwasher. Your need to turn off the house water valve, to your dishwasher, and see if the problem stops. If it does then replace the dishwasher water fill valve. If it doesn't stop, then you have water coming in through your drain lines, which is highly unlikely. You will have to check to make sure your drain line has a high loop in it, or install an air gap. Good luck, Appliance Specialists
Mar 13, 2011 | LG 24 in. LD-12BW5 Free-standing...
My dishes are still dirty after washing
There might be may reasons. Let me provide you with all the steps :-
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Oct 14, 2009 | Zanussi Dishwashers
Upper spray arm doesn't move. Replaced inlet
Does it feel free to turn? It's water powered and works in conjunction with the water pump. Do you hear the water/booster pump come on?
Oct 04, 2009 | Frigidaire PLDB998A Built-in Dishwasher
Dishwasher not washing or dissolving soap
Do your dishes look cloudy or spotty? If so it is not soap but rather hard water residue. Go to www.dishwasherfilter.com and get a filter that filters the water before it enters your dishwasher. it is very affordable(like 70 bucks) and guaranteed to work or you can return it for a full refund. I bet this will solve the problem.
Jul 02, 2009 | LG 24 in. LDF 7811 Stainless Steel...
Leaves silverware dirty
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
May 23, 2009 | Dishwashers
Turn on, it hums but no water.. the water line is new.
Many new supply lines have a safety valve built in to prevent flooding in case of major malfuction. Floodsaver is one of the brands. They can be identified by a small silver cylinder at the water valve end under your sink. I have found that then valves can close under certain conditions other than a malfunction. Try turning off the supply valve and then very slowly, reopen it. Sometimes, I have had to turn off the water supply valve, disconnect the line to relieve the pressure, reattach and SLOWLY turn the water back on. If this fails, next try the diagnostic procedures here:
http://www.applianceaid.com/boschDW.html#test
best of luck!
Mar 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Water wont stop going in
You stated that your house is new. I see this frequently and what has likely happened is the installer used pipe dope to seal the elbow that screws into the bottom of the dishwasher water valve. They should have used Teflon thread tape instead as the pipe dope will get into the diaphram in the water valve, clog the tiny holes in it and ruin the water valve. The valve on the dishwasher will need to replaced. Hopefully the company that takes care of the warranty doesn't charge you for it. They should back-charge the installer.
Jan 01, 2009 | Dishwashers
Dishwasher - no water coming into it
If there is no water coming in the machine check first the water supply has not a tap and this is closing.
If water is supplied regularly, then the problem is either with the inlet valve or the float switch.
See the following indications from repairclinic:
" Water-inlet valve
Float switch
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it."
Aug 29, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
106 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Ned Halaweh
Ned Halaweh
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
