Question about Samsung SyncMaster 152 B 15" LCD Monitor
Not image. After connect RGB cable to computor screen torn to black ,before sighn fly: "not conectivity"
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 17, 2010
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Double image
Use this link to get company support:
http://www.necvisualsystems.com/SupportCenter/SupportTracker/
Apr 13, 2008 | NEC MultiSync MT840 Multimedia Projector
I tried to hook my wii to the new hd led flat screen but its black and white I tried doing the yello cable to green but it doesnt work and all the other inputs dont have ac jacks its just hdmi hookups
The yellow cable is RCA component and it sould not be connected to the Green port. Why not get a HDMi cable to make the hook up easier? Component RGB connection requires a RGB cable along with a stereo audio cable where as HDMI requires just one.
Jun 10, 2011 | Nintendo Wii Console
How to turn on rgb from lap top to tv.
In order to connect your laptop to your TV using RGB, you need an RGB adapter. RGB is also known as component video; it breaks up a video signal into red, green and blue. laptops do not have RGB outputs. However, many laptops have VGA, DVI or HDMI outputs. An RGB adapter connects the single VGA, DVI, or HDMI cable to an RGB cable, which is actually three different cables tied together. INSTRUCTIONS:
1. Connect either the VGA, DVI or HDMI (in the order of increasing video quality) cable to the VGA, DVI or HDMI port on your laptop, depending on what is available. 2. Connect the other end of the cable to the side of the RGB adapter with the single input. 3. Connect the RGB cables to the red, green and blue ports on the other side of the RGB adapter. 4. Connect the other end of the RGB cables to an available component input on the back of the TV. 5. Tune the TV to the component video input you used through your television's menu. 6. Turn on your laptop. The laptop should now display on your TV screen.
May 30, 2011 | Computers & Internet
Conecting Wii to a Phillips lcd tv. rwy cords. but the picture is in black & white ?? i have sound. tried different connections eg: red to green conections & the only one that works is still black...
it sounds like you may be trying to plug a standard composit video cable (yellow) into a component video input (red, green, and blue)
these are actually two different connections. Most LCD tv's will have both options (sometimes there in weird different spots on the tv tho) if you don't have a standard RGB (red, white, and yellow composite video input) then you may need to purchase a component cable either at a local store or you can get one for $5 on Ebay
hope it helps!
~good luck!
Mar 16, 2011 | Nintendo Wii Console
How do I set up my Elmo to a data projector & a laptop? Specifically, Where do I put the RGB cords - what get's hooked up to what? Thanks!
I am going to bet you got a manual with the TT-02rx that explains the connectivity. If not, you can go to www.elmousa.com and download the manual from the TT-02rx page. Look on page 30.
TT-02rx can be connected in a couple of ways:
1. Directly to Projector - connect a standard VGA cable from the RGB output on the TT-02rx to a RGB (VGA) input on your projector. This will allow you to directly display anything you put under the Elmo camera.
2. USB to laptop, VGA from laptop to your projector. You can connect a standard USB cable from the Elmo to an open USB port on your laptop. From the laptop, you will need to connect VGA cable from output jack to projector input. To view images from the Elmo, you need to have installed the Imagemate software on your laptop first. Elmo can only be viewed thru the software interface.
3. The last option is run VGA from your laptop to VGA input on the Elmo. Then run VGA from Elmo to your projector. This offers the greatest amount of versatility as you can switch between the image on your computer screen and the image on the doc camera. Adding the USB cable as described in 2 above will also allow you to use the digital features such as image capture, reveal, spotlight, etc.
Dec 09, 2010 | Elmo Projectors ELMO TT02RX DIGITAL...
How do I link to the computor
connect up the signal cable. Press Fn and Screen icon in your F keys until the display shows. If it doesn't, probably you will have to choose RGB input in your projector.
Aug 05, 2010 | Sanyo Office Equipment & Supplies
Screen is black when turned on. I eject the game and put it in then it will boot up. when i go to the systems stuff screen goes black again
I suspect you are connected by HDMI cables.
Try RGB cables. HDMI can fail to work on some TVs (HDMI is software based and the versions sometimes don't like each other)
RGB is very close in quality and does not have the problem with compatibility.
Apr 02, 2010 | Sony Playstation 3 (PS3) Console
Shows image but is completly yellow
I had one with the same issue. After checking and rechecking the projector, I found that there was a lose conection between the CPU and the RGB output connection. It's really touchy.
Jan 30, 2009 | NEC VT670 Multimedia Projector
Have a Synkmaster 510n with problem
Confirm this is a monitor problem by connecting toanother working Pc.Also try starting in safe mode and see if you get stable image.If in safe mode you get image your image settings may need to be readjusted.
Samir
Mar 07, 2008 | Samsung 510N 15" Flat Panel LCD Monitor
Samsung SyncMaster 152 B 15" LCD Monitor Logo
70 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
