Question about Dryers
Maytag Electric Dryer Stopped Working
Maytag dryer stopped working (model SDE30DAYW - electric). Worked fine, dried a load of clothes, put the next load in and it won't start. Dryer light works when door is open. Checked circuit breakers and that's fine.
  • 2 more comments
  • mlas Mar 30, 2008
    Jiggled the slot where the door tab connects to the dryer (used a paperclip), held the botton in that turns off the light (to simulate the dryer door is closed) and pressed "start" - works like a charm!!! Saved met LOTS of $$ for the service call - THANK YOU SO MUCH!!
  • Anonymous Mar 23, 2014
    Dryer was working fine then I moved and now it is working, but will not heat
  • Anonymous Mar 25, 2014
    have electric dryer it will not get hot at all no matter what setting i put it on
  • Anonymous Mar 29, 2014
    after the dryer stops the end of cycle signal does not work on a GE electric dryer model number GTUP27OEMOWW
    Problem Solver:
  • 16 Answers
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
Yes! This also solved my problem. Closed the door pushing it where the switch is. Pressed a little extra hard. Dryer started working. Brilliant! But shame on Maytag and other American manufacturers for the garbage they make these days.
Posted on May 16, 2013
Our Maytag Centennial Electric dryer is not cycling in auto dry mode but will in timer mode. Any thoughts?
There is a sensor that the clothes have to touch when the drum spins. This sensor measures how wet the clothes are. If you don't have enough of a load in the dryer then the sensor wont detect the dryness. Or it could be a bad sensor or connection or main board.
Nov 02, 2015 | Maytag Centennial 7.0 Cu. Ft. Super...
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
Doesnt dry clothes, every opening i have unclogged,even outside vent is clear.basket rolls but heat is room temp. no matter what setting.
Hi, I experienced the same problem with my Maytag electric dryer. I finally fixed the problem after I checked the actual vent pipe (which allows air to discharge to the outside of your home). What I found was quite surprising. I found was a mouse nesyt in this pipe. Once I removed the mouse next,m my electric dryer worked fine. Just a thought. Good Luck!
Jan 09, 2011 | Roper REX4634KQ Electric Dryer
Our dryer stopped heating up and will not dry clothes
tif it is most likley the element has gone bad they usually cost about 45 dollars and if you can find a friend to help you replace it its not that hard best bet is to call a used appliance store they usually have them new and in stock do not try going to the manufacture they will charge you double for the same exact part
Apr 12, 2010 | Maytag SDE3606A Electric Dryer
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Dryer willnot heat
heating eliment is most likely burned out. Better off getting new dryer. But if that is not an option then call a repair person that can replace the heating element.
Nov 22, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer model mde3000ayw
you want to start at high limit thermostat or thermal fuse
its white and has two small wires
it sits on the heat tube
it could be black too
it is shaped like a warped ball
and is rather flat
sears has them in stock
ive included the part number to help
307473
Oct 09, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer is not heating air
Sounds like the heating element or coil is out, but it could also be the board to. At any rate, if your not getting any heat what so ever, its more than likely electrical and its best to take it in. If it gets some kind of heat, then you might try cleaning out your dryer vents really good, and also in the dryer. Hope this helps.
Jan 02, 2009 | Maytag SDE3606A Electric Dryer
Dryers Logo
1,406 people viewed this question
Top Dryers Experts
