Question about Refrigerators
GE GSH25JSRF SS Howl!
I have the same exact refrigerator and howling problem that you described in your solution...Where did you buy your replacement parts, and how much did they cost.
Thanks so much.
  • cghunter4 Sep 01, 2008
    Our frig howls and seems to run quite a lot. The noise is very annoying to say the least and has been going on for a long time. A call to GE said this was normal. Ya, right! I have read numerous posts from others having the same issue. They refer to a control board problem and some hae reported replacement of the control board solved the problem. I also read that GE was issuing free boards for some models. How do I find out if this is all true and how do I get a new board.
  • 5clarkes May 29, 2010
    I have the ge gsh25gre ss and have the same problem. I called GE and they refuse to acknowledge that this is a defect. They did however offer to have a service tech come out for $99.95 to diagnose the problem. After parts and labor, we would spend roughly $200 to $250 on a $1000 refrigerator. We are so disgusted with their lack of customer service, that we would rather buy a new KitchenAid rerefrigerator than spend the money to fix a poorly crafted GE refrigerator. Apparently, if you buy GE...you lose! We will never buy another GE product again and we will pass along the problems we have had with GE to anyone that will listen.
SolutionGuy
  • 331 Answers
SOURCE: GE SIDE BY SIDE REFRIGERATOR
Kay, these are known for having faulty evaporator fan motors (failed motor bearings). This is what has failed in your fridge. This is a tedious and time consuming repair, you may want to purchase the evap motor and hire someone to install it for you. Just one of the reasons I recommend this is that 50% of the time, the new motor's wiring harness will not match the harness on the fridge and so must be converted to adapt. The evaporator fan motor is the fan inside the freezer, behind the back panels. If you choose to repair it yourself, UNPLUG THE FRIDGE FIRST! Then remove all items from freezer. Remove all shelves and bins. Remove the ice bin. Remove the lower back panel. You should be able to see the motor now, but you can not access it yet. The motor is mounted in a plastic shell/housing, this entire housing must be removed (along with the related wire harness). Install the new motor and rebuild the unit. This doesn't sound like much, but since you've not done one before, figure 2 1/2 to 3 hour job time. (With practice, it still takes us ~50 minutes) Wiring is CRUCIAL! Take note of EVERYTHING and the way things are routed in there. Otherwise, you won't know if you did it right until you have it rebuilt and plugged back in, if something were mis-wired... you'll know it now. Then have to disassemble to locate the problem. The part number you'll need is #WR60X10185, and sells for ~$45.00 at your local appliance parts retailer. If you hire someone to perform the labor, they won't be able to "soak" you on the part price. The good news is that after the repair is complete, your fridge will cool better AND I've never had a callback on these! (Which means that the replacement motors are MUCH better than the original factory installed ones.)
Posted on Aug 11, 2007
  • 833 Answers
SOURCE: GSH25JSRF SS Issue with water/ice delivery
Are you actually getting water into the fridge? Has the line frosted? You may have to defrost and make sure your freezer is not set lower than 5 degrees F.
Posted on Dec 21, 2007
SOURCE: Howling Refrigerator
I am having the same problem with my GE 2005 refrigerator. Anyone find a solution yet?
Posted on Apr 18, 2008
aasc
  • 1606 Answers
SOURCE: RE: GE model #gsh25jsrf ss. The water does not
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig .
Posted on Nov 01, 2009
heatman101
  • 43501 Answers
SOURCE: Fridge not cooling, freezer not freezing even on coldest settings
From what you are describing, you have a refrigerant leak. The freon has leaked from the system, The compressor will still run and evrything looks fine. To double check you will have to have someone hookup gauges to the system and verify that the charge is lost.
It may be possible to find and repair the leak. This is not always possible as some of the system is virtually inaccessible in many refrigerators.
Make sure if you do have someone repair the system that they evacuate the system very well and do a good vacum test before recharging the system.
This should help you to solve your problem.
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
Crackling when turned on then high pitched howl and sound like vinyl being played loud and having stylus dragged across it is the only way to describe the noise after howl. was being used and did crackle...
You didn't say whether it was one or both channels. The word to describe the noise when using a turntable, back in the days, is called Acoustic Vibration. Your issue is not that. I can be an amplifier oscillating, for the high pitched sound and the crackling could be DC Offset*meaning a damaged amplifier) If you need further assistance, or would like to inquire about a repair, please visit my website at audioserviceclinic.com. Thank you.
Oct 26, 2014 | Audio Players & Recorders
Have a low howl in are refrigator some times what could be the cause it is a side by side g e
One of the two fan motors is most likely starting to go. It would either be the evaporator fan located in the freezer behind the rear panel. Or the condensor fan located behind on the bottom behind the rear panel. They are inexpensive and easy to replace. Here is a couple links that should help
http://appliancehelponline.com/refercondenserfan.html
http://appliancehelponline.com/sxsevapfan.html
Sep 24, 2010 | GE GSL25JFR Brushed Steel Side by Side...
Side by side has a loud howling noise from time to time. Other than that, it functions fine. Any idea what the sound is from? Seems to howl when the cooling mechanism is operating....
I have heard of that happening in a complete neighborhood that provided new homes and appliances. I have not witnessed this myself but exchanging the motherboard is what they had done. How long have you owned it? Sea Breeze
Mar 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model PSC23SGRC SS Serial #RH418861. Refrigerator make a howling noise Dave eci.david@gmail.com
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling noise from rear when in motion
Constant howl....usually wheel bearing.
Howl on acceleration.......usually rear pinion bearing (the bigger of the two on the pinion) in the diff (rear axle)
Howl on de-acceleration....the front (smaller) pinion bearing in the diff.(rear axle)
Aug 17, 2009 | 1994 Isuzu Trooper
GE fridge and dishwasher
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
308 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
